Le Riceburners OFFICIAL Build Thread
Exactly. He runs stock shafts at high rpm all the time. You running deletes is better for the motor. Although I couldn't stand my deletes so I put stock shafts back in when I did my 2nd motor. The vibes drove me nuts on the highway.
My car has stock balance shafts, powell s1 trans mount & SS/TC rear trans mount, and I get a nice bumpity bump from the idle of the cams in the cabin.
No bad vibes or rattles though.
that's bs just because you yield the bolt dose not make it bad or need replaced you should measure the length of the bolt and if the length is correct then the bolt is fine others have reused the main bolts with no ill effect also and some have reused the head bolts
if you want to get rid of the vibes balance the engine it gets rid of it
I have heard of reusing head bolts, but I always buy new ones. Better safe then sorry. I haven't checked, but does ARP make bolts for the ecotec? RB, I am in the 100k club. I plan on checking my engine out, but if it looks fine, I will just build it.
Depends how you and the tune treat it. Time will tell.
But hey.. like you said............ #YOLO!!!!!!!!!!!!!
They make head studs. I'm sure they make bolts that would work, though.
Yeah I know. That's why I said deletes are better for your motor. If and when infra's bottom end croakes I'm interested to see the inside of it.
also in the build book they use some high strength bolts of some sort for the rods and main bolts. be wary for those who use the book for building, the torque specs are different from stock!!
