Le Riceburners OFFICIAL Build Thread
#704
Vibes? VIBES???? I drive a plastic car with auxiliary chain delete on custom Powell rotated solid race mounts. I DON'T WANNA HEAR ABOUT YOUR "VIBES"
#709
that's bs just because you yield the bolt dose not make it bad or need replaced you should measure the length of the bolt and if the length is correct then the bolt is fine others have reused the main bolts with no ill effect also and some have reused the head bolts
#724
