Lean Code P0171
Old Mar 14, 2010 | 06:33 PM
gpro's Avatar
Lean Code P0171
Ok, I've been getting this code for a while, tried some fixes, but it still comes back.
Here is the history of this issue in chronological order.
1. Cleaned MAF and noticed there where the intake hose connects down to the air box, that the connection is folded and probably leaks.
(2 months go by)
2. Got GM Stage 2 Installed, mechanic friend of mine 'said' he fixed the intake piping, but I have not checked it yet.
(3 months go by, but less that 100 miles of driving)
3. Hit a puddle with the front-driver side tire and the code came back almost immediately, and now keeps coming back.
So, what should I do now? Running over that puddle at the same time the code came back leads me to think that it might possibly be a dirty MAF.
FYI, I do not have a CAI.
I was also thinking about new spark plugs possibly, any opinions on that? I figured it couldn't hurt anyway since my car has 37,000 miles on it now.
Old Mar 14, 2010 | 06:35 PM
CTcar's Avatar
(2 months go by)
Do you have a CAI? I have injen and i get this code on and off all the time. I just ignore it till the CEL turns off haha
Old Mar 14, 2010 | 06:37 PM
gpro's Avatar
Nope, no CAI.
Old Mar 14, 2010 | 08:10 PM
G11's Avatar
G11
im not sure but i have this same exact problem since i have had the gms2 reflash...
Old Mar 14, 2010 | 08:37 PM
Zach06CobaltSC's Avatar
The p0171 and p0172 is a rich/lean code. This happens when your fuel trims are not within a certain limitation. When it gets extremely cold, or warmer your fuel trims can change and cause this code. Just simply get it cleared and hope it stays off, or get a good solid reliable tune.
Old Mar 14, 2010 | 08:38 PM
calicobaltSS's Avatar
try getting your ECu recalibrated....I have a K&N typhoon intake and had this code come up alot....had it reflashed...hasnt been back since...
Old Mar 14, 2010 | 09:02 PM
It wasn't the reflash that did it unless it was with a newer gm stage tune file. It was more then likely the fact that the battery was disconnected, the code was cleared, and never came back again and or they disabled the code or when they reflashed the code it just hasn't popped up again.
This code is common when the weather changes for a lot of modded guys and we see it all of the time when our fuel trims are out of whack. Just simply delete the code with a scanner or get a better tune. If you have a gm stage 2 tune only though gm should do "something" about it to make that code go away.
Go to autozone and have them clear it.
turbochargedss2012
Sep 20, 2023 12:17 PM
tomj77
Oct 4, 2015 11:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
