Lets play guess the problem...
Ok so say you WOT and gauge shows full boost but rpm's are slow to rise above 3k and speed is slow to rise as well.
Sometimes it all the sudden kicks in and u feel it and rpms jump up and so does speed - boost gauge still showing normal full boost.
Car is 100% stock except for normal maintenance.
82k on the clock.
No cell or anything.
Any ideas?
82k on the clock.
Any ideas?
82k on the clock.
Any ideas?
82k on the clock.
Any ideas?
not clutch slip. It's most likely a clogged cat. A lot of people here have experienced the same problem, and have reported the cat being the culprit. Although, if you really want to rule out clutch slippage, turn the car on and put it in 5th. If it stalls, your clutch is fine; but if the engine stays on, you got a slipping clutch.
when i get on it, boost goes to full, rpms stick around 3k slowly rising and i mean slowly.
lack of power, feels like u just aren't going anywhere, then all the sudden it may take off
or not.
umm it sounds kind of odd..
i dunno how to explain it, it doesn't sound normal thats for sure.
kind of higher pitch....then i would expect.
or not.
what about boost control module?
I know that the back nipple on mine spins around...
I don't remember it doing that when I got it...
so maybe it has a leak from it? i dunno.
anyone else nipple on the back of it spin around?
