Lets play guess the problem...
Old Jul 31, 2009 | 05:06 PM
Sh0nuff's Avatar
Ok so say you WOT and gauge shows full boost but rpm's are slow to rise above 3k and speed is slow to rise as well.
Sometimes it all the sudden kicks in and u feel it and rpms jump up and so does speed - boost gauge still showing normal full boost.
Car is 100% stock except for normal maintenance.
82k on the clock.
No cell or anything.
Any ideas?
Old Jul 31, 2009 | 05:11 PM
Raven SS's Avatar
limp mode
Old Jul 31, 2009 | 05:12 PM
Sh0nuff's Avatar
Wouldn't that throw a cell?
Or show or say something?
It does get above 3k just not very fast.
Old Jul 31, 2009 | 07:30 PM
damien's Avatar
Intercooler pump
Old Jul 31, 2009 | 07:39 PM
Mindrot's Avatar
Originally Posted by Raven SS
limp mode
And a little to the left
Old Jul 31, 2009 | 08:00 PM
HunterKiller89's Avatar
82k on the clock.
Any ideas?
clogged cat...
Old Jul 31, 2009 | 08:03 PM
Connor05's Avatar
cobalt with a vtech and a turbo
Old Jul 31, 2009 | 09:53 PM
ShortStack's Avatar
Originally Posted by HunterKiller89
clogged cat...
^^ Good Answer.
or
Something is causing ALOT of kr...
Old Jul 31, 2009 | 10:48 PM
Sh0nuff's Avatar
ic pump works fine.
wouldnt doubt the cat...
not sure about limp like i said it gives no cell or msg..
what about clutch slip?
Old Jul 31, 2009 | 11:07 PM
Chase0224's Avatar
ic pump works fine.
if it was clutch slip im pretty sure youd be able to feel it.
Old Aug 1, 2009 | 01:27 AM
damien's Avatar
get the cat checked out should be under warranty
Old Aug 1, 2009 | 01:35 AM
mexi_loco's Avatar
not clutch slip. It's most likely a clogged cat. A lot of people here have experienced the same problem, and have reported the cat being the culprit. Although, if you really want to rule out clutch slippage, turn the car on and put it in 5th. If it stalls, your clutch is fine; but if the engine stays on, you got a slipping clutch.
Old Aug 1, 2009 | 10:21 AM
StevesBlack06's Avatar
this sounds so much like when my clutch went out. i would hit it and the boot would jump way up and the car wouldnt go anywhere.
Old Aug 1, 2009 | 10:38 AM
lsjwannabe's Avatar
Rpm's go up when the clutch is slipping and you don't go faster. What does the car sound like when you get on it?
Old Aug 1, 2009 | 12:14 PM
Sh0nuff's Avatar
when i get on it, boost goes to full, rpms stick around 3k slowly rising and i mean slowly.
lack of power, feels like u just aren't going anywhere, then all the sudden it may take off
or not.
umm it sounds kind of odd..
i dunno how to explain it, it doesn't sound normal thats for sure.
kind of higher pitch....then i would expect.
Old Aug 1, 2009 | 12:17 PM
Preston's Avatar
check your vtek solenoid
Old Aug 1, 2009 | 12:41 PM
rocketrex's Avatar
cat my friend..
Old Aug 1, 2009 | 12:43 PM
BumbleBee's Avatar
sure your not in 5th gear in a 40 roll?
Old Aug 1, 2009 | 09:46 PM
Sh0nuff's Avatar
rotflmao more like any gear at 2800 or 2900 or even 3k at that...doesnt matter
gun it and u get full boost with pretty much no power..
now i can say the cat does not glow...
Old Aug 1, 2009 | 10:33 PM
KillerBee's Avatar
Cat or BPV?
Old Aug 1, 2009 | 11:01 PM
Sh0nuff's Avatar
what about boost control module?
I know that the back nipple on mine spins around...
I don't remember it doing that when I got it...
so maybe it has a leak from it? i dunno.
anyone else nipple on the back of it spin around?
Solaris99
28
Mar 15, 2017 01:22 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
justinchinn
Oct 2, 2015 12:18 PM
Tupp
Sep 30, 2015 08:18 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
