long road to ruin
Old Aug 9, 2008 | 07:20 PM
  #126
victory_red_SS's Avatar
LSX RWD S/C conversion
Originally Posted by Area47
lol. rod. it's not that hard to tune the car. 8.0:1 is a bit on the weak side though. so much for low end fun.
as for the tvs. it gets **** done for a mild blower car.
i did however make a c5 vette my bitch today. he was none to thrilled
We can thank Diamond for that as the pistons we ordered never arrived after weeks of hollow promises. In the end I had the Wiseco's sitting there so they got used.
No having said that doesn't these pistons allow for me to run the small pulley? I already have all the other mods.
Old Aug 9, 2008 | 07:23 PM
  #127
Josh@ottp's Avatar
Ya I would def run the small pulley. Maybe even a lil shot, but with your luck I don't know. lol
Old Aug 9, 2008 | 07:28 PM
  #128
No shot for me.
Now do you have the two smaller pulleys available???
Old Aug 9, 2008 | 07:31 PM
  #129
Josh@ottp's Avatar
No shot for me.
Ya we have every size. What one are you looking for? 2.75
Old Aug 9, 2008 | 07:35 PM
  #130
I am not sure which sizes there are. In metric I believe I have the 80mm. I believe there are two smaller than what I have. If so I would take both of those just to be covered.
Old Aug 9, 2008 | 07:38 PM
  #131
Josh@ottp's Avatar
There is a 75mm and a 70mm that harrop makes but we can make even smaller if you find you need them.
Old Aug 9, 2008 | 07:41 PM
  #132
PM sent.
I think for now the 70 & 75 will be the place to start. I am not sure of the blowers efficiency range before producing to much heat.
Old Aug 9, 2008 | 07:42 PM
  #133
EdCobaltSS's Avatar
area, are you still running 10:1 and 272's?
Old Aug 9, 2008 | 07:43 PM
  #134
M-Dub's Avatar
He is running the GMR cams now not the 272s
  #135
SSdan's Avatar
He never ran 10:1.
Stock motor, GMPP cams.
  #136
EdCobaltSS's Avatar
oh ok
Old Aug 9, 2008 | 08:01 PM
  #137
Area47's Avatar
Rent me! per hour
box stock motor sans valve train and cams.
rod. you're going to have to run at least a 2.9 pulley to get the torque down low. with the 3.1 pulley i have, which would be a 80mm i believe. you can watch the boost come up slowly, then for some reason at 4500-5k all hell breaks loose and it's game over.
Old Aug 9, 2008 | 08:32 PM
  #138
ralliartist's Avatar
I'm willing to bet it's your cams, I bet stock cams don't act like that.
  #139
06black's Avatar
Rod i have some idle scale numbers for you to run with your car, it'll get you more then on the way.
also, with a huge boost, turbo car CR that you now have,i would toss the smalles pulley i could at that car.
a forged motor with a 8:1 CR is just SCREEEEEMMMMMMMMING for 30psi!
plus, you going to have to run a smaller pulley to cram the air mass down the throat of the motor to make any kinda power outside of ultimate top end.
I'd start your car with a 75mm pulley, get basic tuning done, then go thro OTT and get a 70, or a 65mm pulley and try that, your not going to see the cylinder air mass needed for medium-big power with out mucho boost. that stock intake is gonna cause some issues as well sir.
Old Aug 9, 2008 | 08:35 PM
  #140
throwing the smallest pullies on just to get more air flow isn't always the brightest idea, he's gonna run into MAJOR heat issues. FYI.
Old Aug 9, 2008 | 08:40 PM
  #141
Josh@ottp's Avatar
the tvs doesn't produce as much heat as the m62, he also has a ported head and cams so he has room for the air to flow.
Old Aug 9, 2008 | 08:59 PM
  #142
I understand that, but a blower is still gonna create heat. I think we already proved this when people threw a 2.5 pulley on the m62 and now years later, people are proving they can make more power on slightly larger pullies.
It's like a viscious cycle. So I wouldn't think it'd be smart to just throw a 50mm pulley on when he can probably make more power on a 70 or 75mm because of the heat issues that will surface with the tiny 50mm.
Old Aug 9, 2008 | 09:12 PM
  #143
CBodnar's Avatar
man so much money spent to make that power lol
Old Aug 9, 2008 | 09:14 PM
  #144
how much money have you put into your car to make your power?
Old Aug 9, 2008 | 09:17 PM
  #145
Darkmanx's Avatar
Thats the reason he said that im guessing less than 1k
Old Aug 9, 2008 | 09:19 PM
  #146
Jimmys2007CobaltSS/C's Avatar
wow nic numbers 342 whp holy ****
Old Aug 9, 2008 | 09:26 PM
  #147
schamsy's Avatar
Low 12's?
Old Aug 9, 2008 | 09:33 PM
  #148
Josh@ottp's Avatar
Ya with a 2.5 on a m62 the blower is overspun and way out of it efficiency range. Where as the htv isn't over spun with the 2.5 and is still very efficient.
Old Aug 9, 2008 | 09:34 PM
  #149
That's the same reason I asked, and I doubt he spent less than 1K. I can see 1K wrapped up in just the gm stage 2, and then another 500-1K wrapped up in the nitrous, and then the other misc. parts.
Sounds like it would cost the same to me. But that's why I asked how much has he spent.
Old Aug 9, 2008 | 09:36 PM
  #150
EdCobaltSS's Avatar
what kind of boost would the tvs push with a 2,5?
