long road to ruin
Old Aug 10, 2008 | 12:25 AM
  #176
lsjwannabe's Avatar
Ditch the stock tires
  #177
hatrickstu's Avatar
Originally Posted by Area47
the bonus thing about this pulley size and cams is the low end lack of torque. less chance of spinning out of the hole at the track. middle of second and third. all bets are off
yea, you too need some tires. get some, run mid 12's (or better) thenwe can respect you that much more. id LOVE to see this beast on some good tires
pot calling the kettle black!
Last edited by hatrickstu; Aug 10, 2008 at 12:25 AM. Reason: Automerged Doublepost
Old Aug 10, 2008 | 10:13 AM
  #178
HOT CARLS SS's Avatar
How much did the TVS blower set you back Area? How much hp/tq can you expect with the TVS on a stock cam with a 3.1 pulley VS a 2.75 after you tune for it? Also what do you mean by 7gph is that a different fuel pump?
Old Aug 10, 2008 | 10:36 AM
  #179
ralliartist's Avatar
7gph is the injector size for his water/meth injection. 7 gallons per hour
Old Aug 10, 2008 | 10:46 AM
  #180
06black's Avatar
Originally Posted by ralliartist
throwing the smallest pullies on just to get more air flow isn't always the brightest idea, he's gonna run into MAJOR heat issues. FYI.
ehhh....
with his engine the ability to flow much more air you wont run into as much boost stacking nor as much PD across the intake manifold with the same size pulley as a "stock" engine car. Tus his AIT's wont suffer until he starts to attain a larger cylinder air mass that would cause air to back up and build boost.
its not just RPM that causes heat, its the extra air by compressed ageist its self in a consistent volume that does. the tvs will only put out X amount of air per rev thus, he'll need more revs to build pressure. as the delta-P jumps so will head flow....but also heat, however it wont happen on his motor until he gets the rev's needed to build more "boost"
so once again, with that CR, head work, ect the engine will use a much larger portion of the air put out by the tvs, thus requiring smaller pulleys to build enough positive pressure that will generate the needed head flow for big power.
Old Aug 10, 2008 | 11:19 AM
  #181
victory_red_SS's Avatar
LSX RWD S/C conversion
Originally Posted by 06black
ehhh....
Well that makes me feel better. I chose to get the 70 & 63 mm pulleys and I can borrow the 75 for the initial tuning from a local TVS test pilot.
Hopefully the engine is back on it's way tomorrow. The block passed the zyglo test and is being assembled this weekend.
Old Aug 10, 2008 | 11:23 AM
  #182
Herndon_High_SS's Avatar
Great news!
Old Aug 10, 2008 | 01:08 PM
  #183
INFE's Avatar
I really need $2300 for that new blower
Old Aug 10, 2008 | 01:25 PM
  #184
Area47's Avatar
Rent me! per hour
my tires are fine. i really don't feel the need to break the drivetrain right now. that who lack of fund deal doesn't set well with me and my daily driver.
id rather spin than break something, and the whole stock clutch thing isn't going to hold et streets as it is. me personally. id prefer the tires to be the weak link in traction devices, not the axles or the clutch.
call me silly, but spinning doesn't bother me a bit
Old Aug 10, 2008 | 01:30 PM
  #185
06blackg85ss's Avatar
411whp
/thread.
lol
j/k man. Nice step up right there. 340 whp = beginning of the fun zone with this cars.
Old Aug 10, 2008 | 01:33 PM
  #186
Area47's Avatar
Rent me! per hour
Originally Posted by 06blackg85ss
411whp
/thread.
lol
now i just have to keep and eye on my injectors. idc is pushing mid 70's vs the low to mid 60's i was pushing on the m62
::sad face::
i will say the car is an absolute riot above 5k rpms now
Old Aug 10, 2008 | 01:35 PM
  #187
06black's Avatar
411whp
/thread.
lol
***** week son!
bring it!
Old Aug 10, 2008 | 01:36 PM
  #188
Damn, which injectors you running again?
I sometimes hit 82% on the 79's at peak boost when it's cold, but usually only 72-73.
as for the top end power, that's why I did the turbo swap, I like having traction down loe (but the abilty to completely rip the tires loose through 120+mph when I want to lol)
***** week son!
bring it!
***** going down this fall man.
I'm hitting the dyno again with the new pump and injectors since I never dyno'd the current setup yet. 411whp was with a 17.2 afr and a burnt out fuel pump on 60's. If I had time to put the meth in she'd be making 430-440whp no prob on pump gas
Last edited by 06blackg85ss; Aug 10, 2008 at 01:36 PM. Reason: Automerged Doublepost
Old Aug 10, 2008 | 01:38 PM
  #189
lsjwannabe's Avatar
trans its only a matter of time
Old Aug 10, 2008 | 01:39 PM
  #190
EatonTVS07's Avatar
::sad face::
you should deff go to kcir next friday
by the way area the guy that owned my car before me found me and turns out you tuned his car with 42's and a 2.8 and meth, i only have a 2.9 no meth, i'll need to make some money and see if you can retune it it runs rich and is pulling 30* is the most i've seen on the interceptor
Old Aug 10, 2008 | 01:43 PM
  #191
you're entitled to your opinion, but so far so good. not a single problem so far
Old Aug 10, 2008 | 01:44 PM
  #192
lsjwannabe's Avatar
your car is a mutant but it can only take so much i pray for it every day lol.
Old Aug 10, 2008 | 01:47 PM
  #193
Area47's Avatar
Rent me! per hour
im still on the 60's paul
also keep in mind, i don't make peak power till about 74-7500 rpms now due to the blower and cam combo. idc screams above 7200
cobaltcc. i KNEW hat car looked familiar. if need be, i have the stage 2 tune file for that car i can load into it for the time being.
Old Aug 10, 2008 | 01:48 PM
  #194
lsjwannabe's Avatar
funny how that works isn't it.
Old Aug 10, 2008 | 01:51 PM
  #195
Area47's Avatar
Rent me! per hour
it's weird wild stuff
Old Aug 10, 2008 | 01:52 PM
  #196
EatonTVS07's Avatar
lol i figured somebody would recognize it.
would that make the car run any better?
Old Aug 10, 2008 | 01:53 PM
  #197
it definitely is, I dunno how it still holds together. But it's still in good shape
Old Aug 10, 2008 | 01:55 PM
  #198
Josh@ottp's Avatar
Give it time, all good things must come to an end.
Old Aug 10, 2008 | 01:56 PM
  #199
nice, yeah I'm still waiting for the time to do the cams on my car and a few other things. might just hold off and do the whole motor at once. with the stock cams my peak is a little above 6200 or so
oh that I know. I got 2 cars and all the parts necessary to rebuild the car sitting in storage at my job/ Should it die, it will be back stronger pretty quickly
Last edited by 06blackg85ss; Aug 10, 2008 at 01:56 PM. Reason: Automerged Doublepost
Old Aug 10, 2008 | 01:57 PM
  #200
CBodnar's Avatar
411whp
/thread.
lol
307 whp
/thread
lol
