Losing Boost
Old Sep 25, 2006 | 08:45 PM
sethallen's Avatar
Losing Boost
Title explains it all. GM Stage II, 2.8" pulley, Injen CAI
When I first got the 2.8", I was getting 17.3-17.4 PSI at the top of second gear.
I could only muster a 16.8 today....and it actually dropped from 16.8 to 16.6 just before I hit redline. Haven't noticed anything else noticable. Whats the deal here?
sethallen's Avatar
and climate temperatures were closely matched
Old Sep 25, 2006 | 09:02 PM
RJSS's Avatar
Was your car under similar conditions too? Perhaps the engine temp was a little hotter, this could also account for the drop in max boost since during the time you were revving it up the heat could have been working against you. I am assuming you were in the same gear as before. Also, could your intake filter be dirtier?
Old Sep 25, 2006 | 09:06 PM
sethallen's Avatar
the filter could very well be dirtier....will i have to take off my damn wheel and the wheel well cover to look at it?
Old Sep 25, 2006 | 09:33 PM
RJSS's Avatar
I am not sure because I haven't seen mine since putting it on but I would think so. Maybe you can get away with taking just a few screws out of the wheel well and pulling it back to peer inside. Or, if you don't have the time just open it up even once in a while to check and make sure you don't keep systematically losing boost. Good luck and keep us posted.
Old Sep 25, 2006 | 11:07 PM
pmerritt's Avatar
your belt could be stretching and you may need to tighten it just a bit.
Old Sep 25, 2006 | 11:19 PM
memphisr24's Avatar
I took my cai off after about 5000 miles. I had the K&N with drycharger covering on it. WOW, when I took that cover off, dirt started to pour out. It was trapped between the cover and the outside of the filter itself. I was surprised. But now i'm running the stock intake and looking to go to the airbox mod
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
