Lysholm 1.6 Twinscrew - En route to power!
Old Sep 23, 2011 | 09:16 AM
  #601
Leafydialupking's Avatar
Originally Posted by 100% METH
if only lysholm used the same bypass system as the magnuson superchargers... a open/close valve and a diaphragm
You could use a blow off valve. It would take some spring work to make sure its open all the time and closes under boost.
Old Sep 23, 2011 | 11:05 AM
  #602
chood711's Avatar
Like they said . Just trying to get a head to junior so he can finish it up. So if anyone has or kbow where one is ill buy it if the price is good. I want junior to port one for me anyways.
Old Sep 23, 2011 | 09:57 PM
  #603
100% METH's Avatar
I think i saw someone selling a head for $400 on here recently
Old Sep 25, 2011 | 02:43 PM
  #604
euthanasia's Avatar
Buy it so I can port it and toss it on your car
Old Sep 25, 2011 | 10:38 PM
  #605
100% METH's Avatar
haha wanna replace my rings and bearings then...
I think we've proven how much the stock pistons can take abuse.
Old Sep 25, 2011 | 11:35 PM
  #606
euthanasia's Avatar
As long as your not blowing smoke and got good oil psi your good lol. Keep beating on it
Old Sep 25, 2011 | 11:49 PM
  #607
100% METH's Avatar
oh I am lol
The 2.6 pulley is going to be yours to use shortly... almost sourced my 2.5 pulley
Old Sep 26, 2011 | 08:48 AM
  #608
RooTBeeR's Avatar
Man pulley = Screamin'!
Old Sep 26, 2011 | 12:49 PM
  #609
100% METH's Avatar
Just ordered my 2.5 pulley yesterday
Euthanasia 2.6 is all yours Just pick up a stg 2 belt
zzp 5 bolt 2.7, 2.8 and 3" all for sale.... $35 + priority mail... i think its $4.95 for the small flat rate box.
Old Sep 26, 2011 | 07:52 PM
  #610
chood711's Avatar
i think its the one i just bought.
Old Sep 26, 2011 | 09:59 PM
  #611
BlackMagic's Avatar
You are sending it out to Euthanasia right? So we are back in business?
Old Sep 26, 2011 | 10:14 PM
  #612
chood711's Avatar
yes sir...as soon as i get it, it will be on its way to cali to meet the magic of euthanasia
Old Sep 26, 2011 | 11:19 PM
  #613
100% METH's Avatar
Horay once its together let us dyno it!!!!
Old Sep 27, 2011 | 02:29 PM
  #614
Jmc007's Avatar
Had the pleasure of taking a drive in a COBALT SS/SC with one of these amazing compressors attached.
Some cliff notes...
lsj mods:
- Ported head
- 60 lb injectors
- 12gph 50/50 water/meth on california **** 89 OCTANE
- badmab 1.75" - 3" shorty hdr
- 2.5" highflow catted DP
- 2.5" spintech catback
- Ported intake manifold
- LS4 TB
- 3" ZZP intake
- 3.8" (20.5 psi, 243 kpa) Pulley spinning the blower lazily to 12,657 RPM by 7400 RPM.
- What I consider a lazy 5 minute put together tune... . Adders turned off.. cot, p.p.,...trq management... etc...
How to describe my initial thoughts...? At first I didn't think much of it... did a quick 1st to 2nd... whoopity doo.. spins tire... congrats... Considering it's putting out 20 psi, it should least do that.
Started a 40 in 2nd and took it all the way through mid way of 4th. Pulls like a freight train on the top end... if we were able to rev past 7400 it would just keep going, and going, and going...
Pleased to report... iat1 100*, iat2 135* by 7400 on nothing more than water/methanol and a completely stock cooling system (stock endplate, stock h/e).
Over all, round of applause to Euthanasia for fabricating such a kit in a extremely short amount of time in his laboratory .
I'm looking forward to the lucky few who purchased this supercharger. I hope you really step up and provide the data logs, dyno pull comparisons, and proof this community needs. Without testing and progression, you have nothing.
Also... if in fact you do have a ported head... I highly recommend you try the 3.4" pulley... you'll thank me later. Don't add timing where it doesn't need to be!!!
For those of you on e-85... i #$^$#^@$^& @#!@^^ you!
For those of you running **** and water/methanol... dont be afraid to step up the nozzle.
Don't let this become a expensive doorstop
06 SIC SS's dyno results on EUTHANASIA'S LYSHOLM TWINSCREW 1.6 KIT
3.25 pulley @ 26 psi (last update he gave)
14* timing
Any plans to re-dyno with a bigger exhaust (and of course better tune)?
Old Sep 27, 2011 | 04:54 PM
  #615
ebristol's Avatar
There is KR at the top of that tune. My guess is that it could not handle any more timing.
That car needs E85.
Old Sep 27, 2011 | 05:42 PM
  #616
BlackMagic's Avatar
the graph doesn't match the mods/car it was on... you took two irrelevant posts and put them together.
Old Sep 27, 2011 | 05:48 PM
  #617
selfinfliction's Avatar
Some cliff notes...
lsj mods:
- Ported head
- 60 lb injectors
- LS4 TB
- 3" ZZP intake
14* timing
just as expected, have to use something with a **** ton of mods to make it seem like the kit puts down any power. ported head will add 30+hp, so this is right in line with a tvs.
Old Sep 27, 2011 | 05:58 PM
  #618
thedubsack85's Avatar
Did you not notice 89 octane?
Old Sep 27, 2011 | 06:38 PM
  #619
BlackMagic's Avatar
It's on 14 degrees timing definitely not at or even near full potential.
Old Sep 27, 2011 | 06:45 PM
  #620
if my math is correct, his 89 octane would be almost 94 octane without taking into consideration any of the btu modifying effects of water on top of the meth. I would guesstimate, it puts him in the neighborhood of 97-100 ish octane.
now if he did that much power on 87 octane and no meth, that would be impressive
pump gas no water or meth, stock timing 400whp is attainable
Last edited by selfinfliction; Sep 27, 2011 at 06:46 PM. Reason: Automerged Doublepost
Old Sep 27, 2011 | 08:09 PM
  #621
chood711's Avatar
if you want to. go for it....
Old Sep 28, 2011 | 12:04 AM
  #622
defo98's Avatar
"adjusting some things and then going back. pulling the blower and intake manifold back off..need to machine part of the intake away to open it up for more flow.. choking at 5000 or so RPMs "
this was also a problem when he dynod it so it wasnt running right either and it still made good power...
Old Sep 28, 2011 | 01:23 AM
  #623
100% METH's Avatar
I'll give it the beans no worries...
Old Sep 28, 2011 | 03:20 AM
  #624
You must not understand CA gas as IT"S SHITTY! even if it's 91, Lol for barely pushing the timing these are great number's, Better Tq then most who stay S/C!
Old Sep 28, 2011 | 07:04 PM
  #625
we've all got excuses... mine would've put down more power if the dyno was facing downhill with a breeze from the rear
