maf-t users
Old Jun 8, 2006 | 10:30 AM
Rusty's Avatar
maf-t users
Hey, I will be installing new pulley, injectors, and maf-t this weekend. I just wanted to see what everyone's experience was using the maf-t to tune the car. I've talked to intense-racing about what settings to use. With a 2.85" pulley and 42.5lb/hr injectors, they told me to set the maf-t to C 1. Unfortunately I do not have a wideband, or well, any other method to monitor A/F right now. So I just wanted to see what other people's experiences were with using the maf-t on their ss s/c's.
Old Jun 8, 2006 | 10:38 AM
Saki XL's Avatar
I ran into this same issue without having a Wideband... I ended up getting a couple of CEL's and throwing my car into limp mode before I just gave up and set it to E-3. I'd like to do more tuning but a wideband is definately needed for me.
I'm also running on a 2.6" pulley and 42.5lb/hr Injectors.
Old Jun 8, 2006 | 10:52 AM
Rusty's Avatar
so with a 2.6" pulley and 42.5 injectors you are set to E-3? how does it run?
Old Jun 8, 2006 | 10:55 AM
Bad GTP's Avatar
First off, make sure your DIP switches are set properly to ON-OFF-OFF-OFF. You shouldn't need to stray far from C-1, unless you have an aftermarket intake, and if so, then you really need to tune it with a wideband.
Those injectors will only support a 2.80" supercharger pulley up to 6,500 RPM, or a 2.90" supercharger pulley up to 7,000 RPM. You are risking major engine damage by having injectors that small with that much boost.
Old Jun 8, 2006 | 10:58 AM
Rusty's Avatar
sh*t. i already have the injen cai installed and will be installing the 2.85" pulley and injectors this weekend. any recommendations on which way to tune the maf-t with the intake? i'm assuming make wot slightly richer?
Old Jun 8, 2006 | 11:03 AM
CobaltBurst's Avatar
Thats the same thing i was thinking..... 2.6" pulley with 42.5lb injectors, didnt sound like enough.
Old Jun 11, 2006 | 12:44 AM
Rusty's Avatar
i finally got everything installed (2.85" pulley, 42.5 injectors, bkr7e plugs, and maf-t). the plugs are gapped at .35 and maf-t set to C 1. I also have an Injen CAI. the car pulls strong, but in the lower rpm range it seems to almost bog a little bit and runs kind of sluggish. i was wondering if anyone has a similar setup and has any advice. do i need to check the plug gaps? or should i adjust the base setting on the maf-t?
Old Jun 12, 2006 | 08:20 AM
Rusty's Avatar
anyone?
Old Jun 12, 2006 | 08:30 AM
cybcow's Avatar
Well you should listen to Bad GTP and definitely go with the base settings if you don't have a wideband tuning device. I suggest rather a professional tune (INTENSE / HPTuners software) or at minimum an Aeroforce gauge so you can see how its running using the base settings Bad GTP talks about.
Old Jun 12, 2006 | 10:04 AM
Rusty's Avatar
I am using the base setting that he talks about "C 1".
Old Jun 12, 2006 | 10:05 AM
djt81185's Avatar
on off off off setting c1 plugs gapped at .045 using the intense plugs worked perfect for me...
Dan
Old Jun 12, 2006 | 10:32 AM
Anthony's Avatar
Dan
.045 thats to big of a gap .035 works well for me..c1 on off off off 268hp 234tq 2.8...
Old Jun 12, 2006 | 10:54 AM
*TRIX*'s Avatar
you live near the same elevation as me soooo i have a 2.85 from zzp and injectors
and im running on off off off c-1 OR c-2 it depends on the weather because of how rich the car wants to run
and im 2 steps colder with my plugs
Old Jun 12, 2006 | 10:57 AM
djt81185's Avatar
trust me its not to big...if u add more boost it will be...my car ran like crap on .035... .045 made it run like a champ. The guy who did all the tuning told me to run that and it made such a difference.
i dynoed 272whp and 256wheel tq on the setup i listed...tho it was a simulated dynojet run
Trust me it works The more gap u can run without blowout the more complete combustion u get for more power...basic engine theory...i said the same thing about too big until i tried it and it ran great.
Dan
Supercharged06SS
Dec 11, 2022 04:47 PM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
