Max WHP for a 2.0L
Old Apr 20, 2006 | 08:56 AM
yangee's Avatar
Max WHP for a 2.0L
What is the maximum WHP a 2.0 stock can take before we need to play in the engine??
300WHP, 350WHP or moore???
Old Apr 20, 2006 | 08:59 AM
3fo893013L's Avatar
300WHP 350WHP on moore???
um 300 whp before something bad happens..
Please do a search, you will find what your looking for, this topic has been discussed several times.
Old Apr 20, 2006 | 09:01 AM
memphisr24's Avatar
We don't know yet. No one has that much power yet going through the engine. Only time will tell.
Old Apr 20, 2006 | 09:07 AM
FAST06SS's Avatar
I'm at almost 280 now which i think is close to the limit of the stock pistons. Will be upgrading soon
Old Apr 20, 2006 | 09:21 AM
plyboy-illest's Avatar
yea i think anythgin close too 300 would need some piston work done
Old Apr 20, 2006 | 09:23 AM
memphisr24's Avatar
I want the stock compression pistons forged....I don't want to change the compression ratio
Old Apr 20, 2006 | 10:04 AM
JCswoosher2's Avatar
how much would a piston install cost? buying the Intense pistons and install?
Old Apr 20, 2006 | 10:09 AM
BLKSS's Avatar
280whp sounds like the limit to me. More than that and you have a ticking time bomb without the proper mods.
Old Apr 20, 2006 | 10:42 AM
Zenkat's Avatar
290 whp is the limit of the stage1/2 injectors.
Old Apr 20, 2006 | 10:52 AM
WHAT!!!! really. is this true?
Old Apr 20, 2006 | 11:18 AM
FAST06SS's Avatar
850.00 for the labor + piston's
Old Apr 20, 2006 | 11:42 AM
see thats not that bad. because u can up the boost a good bit when u have aftermarket pistons right? but then its worrying about the stock Supercharger. Whats the HP max for the Intense Injectors?
Old Apr 20, 2006 | 11:47 AM
Bad06SS's Avatar
If you go with higher compression pistons, you should actually be able to drop boost but still make the same power. You won't have to spin the blower so fast to make power. Unless you're crazy like me and Rob, we'll probably up the compression AND run a 2.6" pulley.
Old Apr 20, 2006 | 12:56 PM
bluecobaltss06's Avatar
I've heard the stock internals can take up to 450.
Old Apr 20, 2006 | 01:22 PM
03gobluecobra's Avatar
I don't know of anyone who has lost pistons yet to having too much power. We don't have the mods yet.
Old Apr 20, 2006 | 01:35 PM
Bad06SS's Avatar
Correct, nobody has yet. Once tuning software becomes available, then we'll start seeing where the true weaknesses are. At that time, we can do more serious stuff like cams, head, tubo swaps, etc. According to a reliable source, the stock pistons fail somewhere close to 325 to 350 flywheel horserpower. 280 whp is roughly ~322 flywheel horsepower, which is right there. As for the rest of the engine, the rods and the rest of the internals are forged, and the valve springs seem to be the only weak link in the valvetrain. Again, we won't truely know the weakness'es untill we can tune different setups.
Old Apr 20, 2006 | 02:19 PM
silverSS's Avatar
what parts are forged?
Old Apr 20, 2006 | 02:31 PM
Jmc007's Avatar
Not true buddy, where did you find that ?
Old Apr 20, 2006 | 02:41 PM
mrdoc442's Avatar
In the gmperfpormancedivision.com
"Build Your Own" 300 + HP ECOtec feature, which is download-able, at http://www.gmperformancedivision.com/ Click/highlight Performance Pulse, then click on Performance Articles, the bottom choice of the four choices you are given. Then click on http://www.gmperformancedivision.com.../23/ecotec.pdf. They start with a 205 H/P S/C ECOtec, describe the steps, including accompanying pictures required for the buildup. In the first paragraph of this article is stated "Most of the components used to build this engine are bone stock - a testament to the capability of the production pieces. The after-market performance components needed to make this big power per Liter (like 150 h/p/L) include high flow injectors, forged aluminum pistons, higher spring rate valvesprings, more agressive camshafts and a new calibration and controller." The entire process of building a 300 + H/P 2.0L S/C ECOtec is well documented with steps and pictures. The engine dyno graph at the completion of the buildup looks like just North of 300 H/P and right at 250 lbs.ft torque. (With shorty tube header-stock wiring harness etc.) I recognize you were talking wheel H/P, but this will get you in the ballpark at any rate. There are lots of free downloads and a wealth of information/data available from GM including the GM Sport Compact Performance Build Book which details buildups of the 2.2L ECOtec in stages to 250 H/P, from 250 H/P to 400 H/P, from 400 H/P to 600 H/P, from 600 H/P to 1000 H/P, and from 1000 H/P to 1400 H/P, again documented step by step with photographs and parts lists. There is also an automatic 4T65 Racing Transmission build-up, a Phase 5 Cobalt, along with Cobalt Grand Am Cup St Class Racing Series car documented at http://www.gm.com/company/gmtunersou...build_book.htm
Doc
Old Apr 21, 2006 | 09:39 AM
FAST06SS's Avatar
Doc
Sad part is, we are higher than that already WITHOUT getting into the motor Wait til i install the internal parts that they did
Old Apr 21, 2006 | 10:34 AM
max_boost's Avatar
I'm tired of waiting, less posting more building, lol.
Old Apr 21, 2006 | 11:08 AM
PuSha050's Avatar
just a quick question, bc i didnt follow his project much... didnt twincharged have more then 300whp on stock internals or was he not puttin out that much power?
Old Apr 21, 2006 | 11:16 AM
Bad06SS's Avatar
Even if you would've followed closely, you still wouldn't know. He didn't post any dyno sheets or get any track times, so it's all estimated.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hhrfreek
Jun 4, 2016 11:25 PM
footballplaya3k
Sep 28, 2015 11:14 AM
jas09ss
Sep 26, 2015 01:06 PM
