Max WHP before internals
Old Nov 20, 2007 | 07:57 PM
11secSRT4's Avatar
Just as the title stats. What can the 2.0 handle before things come apart? Thanks
Old Nov 20, 2007 | 07:58 PM
Shortbus's Avatar
it all depends on the tune and how your taking care of heat etc...most have mixed feelings about this.
Old Nov 20, 2007 | 07:59 PM
skymynx's Avatar
that depends. where in ct are you from?
Old Nov 20, 2007 | 08:21 PM
chevysalesman614's Avatar
depends on wether or not you dump the heaton supercharger. we're not really sure yet. 1 guy has gone turbo and put down 326/290 to the wheels, and the tuning is still not complete. (some kind of problem with maxing out the MAF tables in HPtuners.)
people have maxed out the eaton and made around 280-290whp.
theres people with good numbers not on this list, but it gives you an idea.
1. 06blackg85ss 326 whp, 290 wtq Verified Dynojet TK, DP, E, T, I, 60s
2. Mezzano 281 whp, 260 wtq Verified 2.6, I, WI, 60s, DP
3. Area47 280 whp, 265 wtq Verified 2.7, 60s, I, H, DP, E, WI, T
4. DTM2188 271 whp, 260wtq Unverified Dynojet
5. M-Dub 262 whp, 236 wtq Verified GM2, 2.85, GMH, DP, E, I, T
6. PlaysWitCars 260 whp, 242 wtq Verified 2.7, 60s, DP, E, I, T, HE
7. QuikSilverSS 257 whp, 232 wtq Verified I, GM2, 2.8
8. liolixli 255 whp, 236 wtq Verified I, H, DP, T, 60S, 2.7
9. red06s/c 246 whp, 223 wtq Verified GM2, 2.9, E, I, HE, H
10. chevysalesman614 245 whp, 214 wtq Verified 2.9, 42s, I, E
I= Intake
H=Header
GMH=GMPP Or Other Than Stock Exhaust Manifold
DP= Aftermarket Down pipe
E=Cat-back exhaust
T=Tuning
P=Underdrive Pulley
DR=Drag Radials or Slicks
ST=Street Tires
60s= 60# injectors
42s= 42# injectors
N2O=Nitrous
TK=Turbo Kit
0.0" Will specify pulley size for the SS/SC's
WI=Water/Meth Injection
PB= Ported Blower
GM= GM Stage 1
GM2=GM Stage 2
GM3=GM Stage 3
DP=Aftermarket Downpipe
CD=Cat Delete
HE=Aftermarket or 2cnd Heat Exchanger
TB= Ported or aftermarket throttle body
PH= Ported or aftermarket head
IM= Ported,aftermarket, or better than stock intake manifold
C= Cams
M62= Stock Supercharger off a Cobalt SS/SC
WR=Weight Reduction
Old Nov 20, 2007 | 08:23 PM
skymynx's Avatar
hey thats my list lol. guess its a good thing i got bored the other day and made it. need to go to the dyno so i can put myself on the list lol.
Old Nov 20, 2007 | 08:30 PM
XM15's Avatar
Is that you Nick? Ted sent you to find out before he slaps the GT3071R on the SS, didn't he?
If thats not you, disregard the above comment, and welcome to the site!
Old Nov 20, 2007 | 09:52 PM
11secSRT4's Avatar
[QUOTE=XM15;1684393]Is that you Nick? Ted sent you to find out before he slaps the GT3071R on the SS, didn't he?
If thats not you, disregard the above comment, and welcome to the site! [/QUOTE
Just wondering if I need to get the mop ready in the dyno bay. Thanks for the welcome I've been on here awhile but never started a name.I like to keep up with things I work on)
Old Nov 20, 2007 | 09:59 PM
skymynx's Avatar
srt4 do you really run 11 seconds or hoping to run 11s
11secSRT4's Avatar
Bristol
XM15's Avatar
You might need a mop. It depends on how far they push it. There won't be the heat from the M62 to worry about, and I'm assuming Ted will be fairly conservative with the tune at first. I've heard guys on here complain about the MAF tuning though. I guess there is only a 2 bar map in HPT (or something like that) which hurts the tuning efforts at higher psi. When do you plan on having the SS on the dyno? I need an excuse to stop on by.
He ran an 11.89 I believe.
Old Nov 20, 2007 | 10:01 PM
skymynx's Avatar
oh ok damn. thats mighty impressive. must be a beast of a car.
Old Nov 20, 2007 | 10:03 PM
XM15's Avatar
360 whp
Here's a link to some of the problems one of the members is having with his turbo setup:
https://www.cobaltss.net/forums/show...=77947&page=62
Old Nov 21, 2007 | 07:04 AM
11secSRT4's Avatar
I'm going to be pretty deep into the kit today if anybody wanted to come and check things out your more then welcome.Jannetty Racing in Waterbury,CT.(you know you want one XM15 you should stop in)
Old Nov 21, 2007 | 08:41 AM
skymynx's Avatar
yea ive been debating a turbo kit. ill know for good once i see what you guys put out on the turbo'd lsj. cause if its only slightly over 300 idk if im gonna do it. (come spring ill prolly be a little over 300)
Old Nov 21, 2007 | 11:37 AM
Area47's Avatar
Rent me! per hour
most of the issue about barfed motors comes from heat. then excessive cylinder pressures. which is why cams are cool.
Old Nov 21, 2007 | 06:34 PM
skymynx's Avatar
i've talked to people that have done cams. doesnt seem to be worth it to them from what i understand. do you say otherwise area?
Old Nov 21, 2007 | 06:38 PM
06blackg85ss's Avatar
well I dunno what;s going on with my car yet... running a compression and leak down test tomorrow on it.
But anyway, been driving it at @330+whp (finally somewhat tuned) daily and it's been fine, still averaging 28-29mpg and I drive to and from manhattan everyday in rush hour lol.
but I think if my car didn't do that random lean spike at 24psi the other day, she'd still be happy.
Upgrading the fuel system in a week also since I think that is part of my tuning problem
Old Nov 21, 2007 | 06:45 PM
Area47's Avatar
Rent me! per hour
depends on how you look at it.
it could possibly make the engine itself live longer.
why? not as much pressure. i won't know if cams are worth it myself untill i buy some.
Old Nov 24, 2007 | 09:10 AM
skymynx's Avatar
yea im gonna find out weather or not a ported head is worth it by finally doing it this winter.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hhrfreek
Jun 4, 2016 11:25 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
footballplaya3k
Sep 28, 2015 11:14 AM
