Methanol Injection!
Old Apr 16, 2006 | 02:46 PM
06noscobaltss's Avatar
Methanol Injection!
Is anyone on here running methanol injection. I was looking at the SNOW Stage II kit. Includes everything and a MAF to finely tune it. Lookin at like 400 bucks though. Is anyone on here runnin this or any others. Also where can I find other kits?
Old Apr 16, 2006 | 02:57 PM
Xenozx's Avatar
I know a dude in a redline that has this. Said its good for about 10 HP on a cobalt/redline. If 10 HP is worth that money to you go for it, I would rather invest in stage kits/smaller pulley. its supose to clean things out too, but I dont think its worth it to be honest.
Old Apr 16, 2006 | 03:08 PM
Chevypowered's Avatar
I think it would be very worth it, i was looking into doing it but the only thing is that the jet needs to be after the S/C which might not be too bad if you drill and tap a hole in the intake manifold and put the sprayer there. I would go for it.
Old Apr 16, 2006 | 03:19 PM
2K5SS/SC?'s Avatar
That's is the best way to do it, but I really don't want to go there until it's absolutely necessary.
Old Apr 16, 2006 | 03:21 PM
Bad06SS's Avatar
Check out www.alkycontrol.com. Julio is a great guy and really knows his stuff! He can set you up with a complete kit that has a progressive controller that rocks! Trust me, it's worth it.
Old Apr 16, 2006 | 08:57 PM
mken's Avatar
I believe Selfinfliction has already had adventures with it, last summer if I remember correctly. He took it back off because of issues, but I don't remember if he said what they were, possibly just because of the other parts he was being a guinea pig for. You might want to PM him and see if he has any suggestions or experiences to share with you.
Old Apr 16, 2006 | 09:42 PM
03gobluecobra's Avatar
I think to fully utilize Methanol you need to increase your timing. We can't do that until someone releases some tuning capabilities for us.
Old Apr 16, 2006 | 09:44 PM
selfinfliction's Avatar
yep.. it's not worth the hassle on our cars unless you're running some major mods. the only real benefit we could get from it is keeping KR down at 18-20psi and on hot days it would help build boost just like on cool days.
here's the tutorial i wrote up on installing one (the only thing not in this how to is how to hook up the boost sensor and wire it into the fuseblock)
www.ricermath.com/injection.htm
Old Apr 16, 2006 | 09:55 PM
CobaltCoupeCrazy's Avatar
Exclamation Don't do it!!
Methanol is bad for your car; it needs to be bulit for methanol. That's even in the owner's manual. Don't use any fuel containing methanol and don't use octane boosters with MTBE.
Scott
Old Apr 16, 2006 | 10:16 PM
Scott
holy moly! if you wouldn't have said that i would've ran a water meth mix and blew a hole right through the time continuim causing exhistance to end as we know it!
it's not bad if used correctly
Old Apr 16, 2006 | 10:30 PM
eastcoastz's Avatar
I think methanol injection will eat the Teflon coating on the rotors of our blowers.
Old Apr 16, 2006 | 10:47 PM
The methanol will eat up seals and such; it's corrosive. This is why you can't run Ethanol in a non-ethanol compatible vehicle. Extra care has to be taken to protect against the alcohol fuels.
Old Apr 17, 2006 | 01:24 AM
silverSS's Avatar
Meth=Bye Bye LSJ
Old Apr 22, 2006 | 10:22 AM
1fstss's Avatar
use nitrous... methonol will eat your blower up!!
Old Apr 23, 2006 | 03:43 AM
maxpit's Avatar
It wont eat it up if you drill them into the intake manifold.
Old Jul 10, 2006 | 03:47 PM
SnowTech.3's Avatar
Originally Posted by Cobalt_Supercharged
I would cool the intake air the faster and easier method. An ice chiller box for the IC fluid.
The problem with that is it gets used up right away. Water-methanol injection can be used every day on a daily driver, as well as at the track.
Old Jul 10, 2006 | 03:49 PM
SnowTech.3's Avatar
Methanol won't "eat up" your blower unless you remove you blower and soak it in a vat of methanol. Even then it won't happen like its acid or something.
Water-methanol has been injected through thousands and thousands of Eatons for hundreds of thousands of miles.
Old Jul 10, 2006 | 03:57 PM
SS33's Avatar
Incorrect the Gen V M62 blower rotors use a new coating, no more Teflon
that aside, the best way to do this is to add an adaptor plate allowing the Meth to be sprayed after the blower
Old Jul 10, 2006 | 05:00 PM
Bad06SS's Avatar
It's not just the power gain from it itself that rocks. It's the fact that you can run alot of boost and timing without KR. That will make the car much faster!
Old Jul 10, 2006 | 05:09 PM
06blackg85ss's Avatar
I'm in need of meth inj.... hopefully my motor holds together til I get it... even though I get 0 kr at 19.5 psi, I'm goin with a smaller pulley and could def use its benefits. or just get nitrous
Old Jul 11, 2006 | 01:53 AM
ReMz's Avatar
obviously the risks are there... but you could say that about almost every aftermarket part.
lol. "use nitrous".... like that is sooo much better
go for it imo
06blackg85ss
83
Jan 18, 2017 04:35 AM
SlowSaturn
Sep 28, 2015 11:03 AM
roadrunner132
Sep 16, 2015 09:13 AM
Bluelightning
Sep 8, 2015 05:18 PM
Macgyver2484
Sep 2, 2015 05:44 PM
