Methanol Injection Help
Old May 18, 2010 | 06:06 PM
thebucky84's Avatar
well now im in a debate.. im looking at 2 different kits.. one will inject off of boost pressure and the other taps off of the maf sensor. which one is the better of the two?
Old May 18, 2010 | 07:01 PM
Bl4des's Avatar
it doesnt matter i have mine set up with the map sensor but i am going to change it to the boost line
if you some how get a bad connection with the map sensor and you dont spray meth say bye to your motor
Old May 18, 2010 | 07:08 PM
thebucky84's Avatar
hmm ok.. yeah i've been leaning more towards the boost pressure one. seems more reliable, and for my application i want to start injecting meth at a certain boost pressure. also seems easier as well.
Redefined1's Avatar
if you dont spray your motor will pull timing. shouldnt be that much of a problem.
Old May 18, 2010 | 10:24 PM
Bl4des's Avatar
is has nothing to do with timing meth adds unmonitored gas and when you spay you need to take fuel away. so if you are not spraying your car goes really lean and blows up
Old May 18, 2010 | 10:33 PM
Redefined1's Avatar
i dont know if this is correct but when your car pulls timing doesnt it also need less fuel at that point, putting you back in to a safer range when the meth fails to spray? i could be dead wrong on this.
Old May 18, 2010 | 10:37 PM
BlackJackSS's Avatar
ya it will start knocking. the car will automatically put it in safe range. thats what the knock sensors are for.
Old May 18, 2010 | 11:59 PM
Bl4des's Avatar
well if you are like me and run a good amount a meth you will do damage to your motor if it doesnt spary but if you are not spaying that much you should be fine
Old May 19, 2010 | 12:02 AM
ive only got a 3ghp nozzle. i didnt really wanna go overboard.
Old May 19, 2010 | 12:09 AM
Bl4des's Avatar
i am running a 7 gph and it runs great i am think of going bigger and a 2.6
Old May 19, 2010 | 12:11 AM
  #36
u think a 5ghp would be ok with my 2.8?
  #37
thebucky84's Avatar
i talked with the alcohol injection guys yesterday and they said a 7gph nozzle would be fine for me.
Old May 19, 2010 | 12:12 AM
  #38
Bl4des's Avatar
yeah you could go with a 7 gph if you wanted you just need to tune for it
Old May 19, 2010 | 12:14 AM
  #39
RooTBeeR's Avatar
i have a 10, and one want a 10?
Old May 19, 2010 | 12:26 AM
  #40
well how much of a difference could a 5 make...
Old May 19, 2010 | 01:24 PM
  #41
Bl4des's Avatar
it depends. how hot does your car get after a 3rd gear pull and how uch timing are you running on your set up now
Old May 19, 2010 | 02:05 PM
  #42
24* and it only got to about 30* hotter than ambient air temp.
it was about 75 out that day.
Old May 19, 2010 | 02:23 PM
  #43
Bl4des's Avatar
i dont know how much it would really be able to help you but you could pulley down and go with some more meth and make some more power
Old May 19, 2010 | 10:21 PM
  #44
devilsown's Avatar
What do your inlet air temps look like? any kr? It honesty can make a pretty good diffence going from a 3 to a 5
you can try bigger. imo if you go any bigger more than likely you are going to need to increase you % of meth in the mix to make a 10gph nozzle work.
Old May 20, 2010 | 12:06 AM
  #45
Bl4des's Avatar
i use 75% meth and 25% water
i think i am going to keep my 7gph and add a 3gph after the supercharger
06blackg85ss
83
Jan 18, 2017 04:35 AM
SlowSaturn
Sep 28, 2015 11:03 AM
roadrunner132
Sep 16, 2015 09:13 AM
Bluelightning
Sep 8, 2015 05:18 PM
Macgyver2484
Sep 2, 2015 05:44 PM
