methanol mixing from washer fluid
i have been doing alot of searching and i need to know how to make 50/50 mix methanol and water i have acces to unlimeted amouts of washer fluid from work and the msds sheet says the fluid is 35% methanol. so do i add 3 or 4 bottles of heet per gallon to get it aound 50/50. i have herd 3 bottles of heet from half of the spots ive looked and 4 bottles of heet from the other half. which is it?
Dude, go to the hardware store and buy some Methyl Hydrate (Methanol) and some distilled water.
Combined its probably cheaper than those bottles of Heet.
Not to mention, washer fluid has a lot of detergents, dyes and other junk in them.
Hell you can buy those water cooler jugs of distilled water for like $20 bucks and Methyl Hydrate is a few bucks a gallon.
if you buy the -20* mix ( found at any gas station around here anyway ) its a 50/50 mix. i add one bottle of yellow heet per gallon of washer fluid and im good. this was recommended to me by the owner of snow/performance himself.
so if i did buy the methyl hydrate, what exactly is it and what is it used for from the hardware store
i thought it was only like 30% or so meth? straight windshield washer fluid that is
Yeah a -20 should be like 30% methanol. Go to a speed shop and buy methanol for like $3 a gallon. Mix whatever % you want with distilled and good to go. Still safe on the windshield too. I use 75% methanol in the windshield all the time.
and it is a -20 fluid
and the nearest speed shop is about 3 hours away from me
ive acualy herd the oposite josh at ottp said that the methanol will ruin the paint of you car eventualy so i also ordered a trunk mount tank. and as i said earlier i have access to the msds sheet for our washer fluid and it says right on the front page 35% methanol
what i do is mark a line on the washer fluid bottle where the unopened level is. pour half of it out. add 3 bottles of HEET and then fill it up with the washer fluid till it reaches the line.
have you ever had a problem using washer fluid? seeing as everyone says there contaminents in it.
has anyone ran into problems with the washer fluid rather then straight methanol and water
