Is my Ingalls ETD installed correctly?
Old Jun 27, 2006 | 10:59 PM
sethallen's Avatar
Guys I need some input. I installed my Ingalls ETD according to spec, but after reading all of this about brackets bending, I wanted to make sure that it's in there properly. Thanks.
Old Jun 27, 2006 | 11:07 PM
KeystoneSC's Avatar
It looks right...from here it's all about adjusting to what suits you best. Mine's at 12mm and working great!!
Old Jun 28, 2006 | 06:30 AM
Matty's Avatar
In the second pic, I have mine set into the groove in the mount. So the Ingalls brace can't move.
Old Jun 28, 2006 | 08:50 AM
KeystoneSC's Avatar
Good catch...I didn't even see that. It must have been all the Sam Adams last night...LOL.
Matty's right...drop the bracket into the grove (between the first and second fin on the engine side.
Old Jun 28, 2006 | 09:18 AM
rnjmur's Avatar
The ingalls and the brackets should all be parallel to each other, or at least as close as possible to parallel. I haven't taken any pictures of mine, else I would post them up so you could see. Your brackets and dampner do not look quite right. If you put the bracket in the groove as Matty suggested that should straighten everything out.
Old Jun 28, 2006 | 04:21 PM
sethallen's Avatar
thanks for the help guys... i will adjust that today
Old Jun 28, 2006 | 04:30 PM
zer0's Avatar
how hard was install? Thinking about getting one..
Old Jun 28, 2006 | 05:17 PM
Matty's Avatar
Follow the instructions and it is very easy. On a scale of 1-10 maybe a 3.
Old Jun 28, 2006 | 05:42 PM
robstamina's Avatar
That is going to bend...
You have to make sure it is straight..
also the rubber o ring goes against the bracket..not the nut
contact me with ?'s
robs@ingallseng.com
Old Jun 28, 2006 | 05:57 PM
sethallen's Avatar
the o ring was b/w the bracket and the shock. i just reinstalled it. It looks right now....i put the bracket in the groove... it's less noisy now. I have to say I'm pleased
Old Jun 29, 2006 | 07:20 PM
automobiliben's Avatar
Is there anyway that you could post up pics of it installed correctly?? Mine should be here next week and I would like some detailed pics to make sure I get everything correct.
Thanks
Old Jun 30, 2006 | 09:27 AM
rnjmur's Avatar
I will get out the camera and take pictures of mine this weekend.
Old Jun 30, 2006 | 12:03 PM
KeystoneSC's Avatar
Thanks
Here you go!
Old Jun 30, 2006 | 02:45 PM
97cavie24ls's Avatar
those blue brackets look pretty nice
both look kinda off angle , but could be just the pics
my friends redline , is pretty straight , and i think that is the key to keeping them from bending
Old Jun 30, 2006 | 06:06 PM
KeystoneSC's Avatar
It's just the angle of the pic...
The blue is DupliColor MetalCast spraypaint...3 coats.
Old Jul 3, 2006 | 11:59 AM
robstamina's Avatar
OMG those blue brackets look GREAT!!!
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
