Is my Ingalls ETD installed correctly?
Guys I need some input. I installed my Ingalls ETD according to spec, but after reading all of this about brackets bending, I wanted to make sure that it's in there properly. Thanks.
The ingalls and the brackets should all be parallel to each other, or at least as close as possible to parallel. I haven't taken any pictures of mine, else I would post them up so you could see. Your brackets and dampner do not look quite right. If you put the bracket in the groove as Matty suggested that should straighten everything out.
That is going to bend...
You have to make sure it is straight..
also the rubber o ring goes against the bracket..not the nut
contact me with ?'s
robs@ingallseng.com
contact me with ?'s
robs@ingallseng.com
the o ring was b/w the bracket and the shock. i just reinstalled it. It looks right now....i put the bracket in the groove... it's less noisy now. I have to say I'm pleased
Thanks
Originally Posted by automobiliben
Is there anyway that you could post up pics of it installed correctly?? Mine should be here next week and I would like some detailed pics to make sure I get everything correct.
Thanks
Thanks
those blue brackets look pretty nice
both look kinda off angle , but could be just the pics
my friends redline , is pretty straight , and i think that is the key to keeping them from bending
The blue is DupliColor MetalCast spraypaint...3 coats.
Delta coupe
Sep 30, 2015 08:11 AM
