My "Large" ZZP Parts Order I'm About to Fire Off - Comments?
Old Jul 29, 2014 | 02:12 AM
boostbalt's Avatar
Hi guys,
I'm about to pull the trigger on a big ZZP order for my 06' LSJ. I based this order on research I've done to max out the M62's potential. This being said, I've put everything in this order I believe I need except for:
  • HP Tuners VCM
  • Wideband Guage (I'm total newb here, please recommend solutions)
So, please comment on what I hope are the final parts I need to round out my M62 LSJ build (keeping in mind I run a 2.8" on 60#'s already):
Thank you very much for your advice!
PS: Does ZZP give discounts on orders over $1,000?
PPS: I need a new fuel pump, hence, the pump.
Old Jul 29, 2014 | 03:21 AM
footballplaya3k's Avatar
A lot of people like the AEM UEGO, but I went with a PLX because it has a brain box that can be connected to HPTuners.
Old Jul 29, 2014 | 04:20 AM
SunburstSS's Avatar
AEM UEGO connects to HPTuners as well for data logging
Old Jul 29, 2014 | 06:17 AM
BlackielawlessSS's Avatar
mmmm zzp
Old Jul 29, 2014 | 07:21 AM
Staged07SS's Avatar
Administrator
Administrator
Save $100 and skip the intake manifold spacer.
It's not needed, and usually ends up causing a leak.
Old Jul 29, 2014 | 08:14 AM
mrbelvedere's Avatar
you do not need the fuel pump or the coupler or the plug or the spacer
your not going to max out the m62 potential with just bolt on **** if you want to do that step up to the plate and port the head resleeve the block run a set of 11to1 pistons a good set of rods and cams and valve springs an ati dampener find a great tuner and run some spray
Old Jul 29, 2014 | 08:22 AM
Looking to save money i have a longtube catted 2.5" exit setup for sale
Old Jul 29, 2014 | 08:47 AM
yellow dragon's Avatar
This ^
Old Jul 29, 2014 | 08:52 AM
JapEatr's Avatar
South Central *********
Snout plug is reusable when servicing the coupler. M62 only holds 4oz of oil.
Old Jul 29, 2014 | 10:46 AM
iToastie's Avatar
Also don't bother with the LS4 TB.
Old Jul 29, 2014 | 10:57 AM
JapEatr's Avatar
And that zzp header had a 2 bolt flange from header/dp that has a tendency to leak
Old Jul 29, 2014 | 11:02 AM
I would not sat that
Old Jul 29, 2014 | 11:14 AM
jonathan923's Avatar
This. minus sleeving the block & spray would be a nice setup.
no need to sleeve a block or run spray to run a good daily 300whp m62 setup.
all i see in that list is more waste of $$ than gains.
Old Jul 29, 2014 | 11:21 AM
there is a need if the bores are not round then things do not seal up and nitrous is the cheapest hp available and when tuned accordingly makes for a very fast and reliable setup
Old Jul 29, 2014 | 11:29 AM
JapEatr's Avatar
nitrous is good for you, try it and see for your self
Old Jul 29, 2014 | 11:36 AM
i know is good. i personally like it. but most are afraid of it just because there afraid to try it on there cars until they sit on a car with spray
Old Jul 29, 2014 | 11:52 AM
hoytshootr's Avatar
take the throttle body off. i ran one on the m62 and it wasnt bad but you can pick one up on here used for 80$
Old Jul 29, 2014 | 12:07 PM
JapEatr's Avatar
#bowtechforlife
Old Jul 29, 2014 | 12:17 PM
hoytshootr's Avatar
get serious, get hoyt
Old Jul 29, 2014 | 12:19 PM
hoytshootr's Avatar
i guess you might only need a bowtech down in texas with those scrawny deer... up in wisconsin the deer have some size to them! bowtech doesnt cut it...
Old Jul 29, 2014 | 12:28 PM
JapEatr's Avatar
elk hunt in Chama, NM passed right thru, could have taken out a second elk haha
thread offically derailed by archery talk haha
Old Jul 29, 2014 | 12:30 PM
hoytshootr's Avatar
touche... lol now days with the technology, all bows are top of the line. its all personal preference.
Old Jul 29, 2014 | 12:37 PM
JapEatr's Avatar
agreed i just think everytime you post to remind you that if Geronimo shot a Bowtech, we would all be speaking Apache
Old Jul 29, 2014 | 01:03 PM
hoytshootr's Avatar
that would of made the difference eh?? haha
Old Jul 29, 2014 | 01:08 PM
Spawne32's Avatar
their mid length header kit sucks, i regretted buying it the day i received it. Id recommend the stainless steel ebay longtubes.
https://www.cobaltss.net/forums/gene...review-304942/
