Octane Boost
Old Aug 18, 2007 | 01:50 PM
kenhebe's Avatar
Octane Boost
What is everyone's opinion towards octane boosters? Are they safe? What are the pros and con's to using them. Are they a waste of money?
Old Aug 18, 2007 | 01:51 PM
05redline's Avatar
Waste of money
Old Aug 18, 2007 | 01:57 PM
lsjwannabe's Avatar
x2 when you runa hgher octane you need to retune to make more power
Old Aug 18, 2007 | 02:01 PM
kenhebe's Avatar
I figured as much, but I just wanted to poll everone here. I figured since the gas is watered down now with Ethanol, maybe some octane booster would help bring it back to normal.
lsjwannabe's Avatar
i have not noticed a difference in my cars performance
Old Aug 18, 2007 | 02:07 PM
Pyros777's Avatar
Anybody know how much a meth kit would boost octane?
Old Aug 18, 2007 | 02:08 PM
lsjwannabe's Avatar
some people say close to 110 depending on the mix
Old Aug 18, 2007 | 02:10 PM
RJSS's Avatar
Ethanol has a higher octane than the gasoline, so if anything the gas is "watering down" the ethanol.
Old Aug 18, 2007 | 02:15 PM
DrPuttsSS/SC's Avatar
Higher octane just keeps the engine from pinging. Only makes a difference on a radical engine with high boost or high compression, and only if the computer can adjust the timing to take advantage of it. Does nothing for a mild untuned engine, hence waste of money.
Old Aug 18, 2007 | 02:21 PM
Pyros777's Avatar
I seem to recall someone testing meth injection with the Stage 3 PCM, which has a tune for 100 octane. I dont remember his results, but I wanna say they were only slightly worse than actual race gas. I cant find the thread though so if anybody knows what I'm talking about please post up the link.
edit: nevermind I had my facts mixed up. Heres the thread: https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/gm-stage-3-methanol-injection-installed-67970/
Originally Posted by RoelSS
Ok just got back from the track and here are the results:
Outside Air Temp: 104 degress F
Elevation 2710' above sea level
Best run with Methanol + 100 Octane (100 mode on): 14.80 @97mph.
Best run without methanol & 100 Octane mode off: 15.30 @93mph
Just for comparison, there was a stock SS SC running high 15's at low 90's mph. He was stock with the exception of the exhaust.
My buddy ran his 240sx with a turbo clip, air to air intercooler, injectors, turbo back exhaust, hks boost cntroller LSD diff, ect clutch, oil cooler, and over sized radiator.
His best time was 14.2 @ 98mph.
Also want to say whats up to the GM eternal guys that were up threre!!
So in conclusion the meth injection doesn't work properly if you let stage 3 inject it. In other words only nitrous will work. It felt sluggish and slower when I let the PCM spray it in. So I by-passed it to my dash switch directly and I sprayed it & it worked much better. It would probably work better if I get it HP tuned. I don't plan on getting HP tuned, so im going to purchase my Nitrous kit on Monday, & remove the Methanol. So the methanol is going up for sale. Also, im going to put in my electric cut out.
The last time I ran my 14.90 was with stage 2, intake, exhaust & 2.8 pulley & the weather was in the 65-70 degree range at night. So i must admit that 100 octane & methanol did help and if the temperature was better, it would have definetly broken in a 13.
Laters!
Old Aug 18, 2007 | 03:57 PM
05redline's Avatar
You do know for every octane point it only bumps it up .1? So it would take an octane booster with 10 points to make it one octane level higher. You would be better off just buying the higher octane at the pump.
Old Aug 19, 2007 | 02:47 PM
kenhebe's Avatar
93 octane from Shell is all I ever purchase. I was just curious about Octane boosters. Didn't know much about them. Don't think I will ever buy any.
Old Aug 19, 2007 | 02:51 PM
an0malous's Avatar
good quality octane boosters will help if you are getting knock.
NOS Racing Formula
Lucas
Torco Accelerant
the quality ones will explain to you right on the bottle that they ARENT the 0.1 point snakeoil that people believe they are these days.
those i just listed above will raise your octane up to 60 points....or 6 full octane points.
I have seen the proof of them working in front of my own eyes on my interceptor gauge.
but if your car is running fine right now, with no knock....adding an octane boost basically wont help you.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
