Official Procharger Build Thread
Chevy, Do we have a number of guys that are in on the deal as i am getting all the material so we will have no down time...etc
Edit: also picking up 5 c-1 head units so the first 5 will have there kit via next day air (fedex)
I wasent very inpressed by the TS. But the peices and look are fantastic. I think that its going to be a great upgrade for people just trying to peak over 300 whp. It will take a few more mods then just the swap but its ok. Very nice looking though. I wish I had a CNC machine in my area.
With a not so small pulley, much less heat, and the beggining stages of his tuning and what not, I would say that the numbers that were put down were pretty good for a Mustang Dyno. It's an upgrade from the M62, people shouldn't shoot it down so quickly.
Back on topic though, I'm lookin forward to seeing the results on this build as well.
A little update for you all. I will be getting the supercharger by this weekend. Then its nothing but installing and some mics items. Then off for tuning in las vages thanks to some good friends at one of there local performance shops. I will post some pics of th procharger in a couple of days. So stay tuned!!!
Also i will probably post on that TS setup...but why is he running meth injection? isnt that the point of running a bigger SC so you dont have to band aid the setup?
ok back on ProCharger subject...i guess that is one thing about ProCharger you can make obscene hp numbers on pump gas! i know i put down 550whp on my vette on 91 octane no meth/alk injection here
But we are talking LSJ...so with the colder intake temps and higher CFM should be interesting and there should be no need for Alk/Meth on this setup.
Do we have any power estimates on what she will put down????
I'm really curious to see the actual torque curve. On the twin screw swap I saw it was a bit more peaky than the m62 which imo even with higher numbers, will probably make for a slower car at the track.
Although I believe the procharger will blow the twinscrew away in all departments for the simple reason that its being used within its designed limits.
I look forward to see what the procharger will put down both on the dyno and the track and I don't think I'm going to be disappointed.
So i say 15psi...260whp with bad tune...bump up to 17psi and good tune 300whp and 20 psi should be right around 350whp with a conservative tune.
Last edited by Speed Mafia; Aug 21, 2007 at 02:39 PM. Reason: Automerged Doublepost
