Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LSJ Performance Tech (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/)
-   -   Official Turbo LSJ thread!!! (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/official-turbo-lsj-thread-258476/)
jonathan923 Aug 12, 2011 12:56 PM
Since i believe theres quite a few of us turbo lsjs now, i think its time to start a New thread based on everyones setups weather custom turbo kits, or brand quality kits. Also i think it would be helpful if we have new lsj comers that want to gain some knowledge on turbo lsjs and what or how to start in order to get real boost and power on their Balts.
-Post pics of set up
-Problems
-How to
-Innovations
-Ideas
-Vids
-All the good stuff
Lets start! :)
Am running the Hahn stage V currently on 16psi
-S20g Turbo Int WG
-Custom 3" exhaust with obx racing muffler
-AEM wideband
-Turbo Smart BOV
-Turbo Smart Boost Controler
-60lb Injectors
-HP tuned
heres a pics when my build took place and when finished :)
http://i761.photobucket.com/albums/x...88/godess3.jpg
http://i761.photobucket.com/albums/x...88/godess2.jpg
and when finished
http://i761.photobucket.com/albums/x...baltlevel5.jpg
Lets keep this thread going!
:cssNET::twothumbs
BLAZIN07SS Aug 12, 2011 12:57 PM
too much to list :lol:
~G~ Aug 12, 2011 12:58 PM
there are more turbo LSJs then supercharged. That's why i stuck with the supercharger... I want to be the rare car.
BLAZIN07SS Aug 12, 2011 01:00 PM
rare and slow :lol:
jonathan923 Aug 12, 2011 01:02 PM
yea thats for sure. but do it anyways! lol :P you are one of the key members for this kind of threads lol
hawlyns711 Aug 12, 2011 01:11 PM
anyone using an LNF manifold w/ upgraded turbo (heard on LSJ it hits the coolant pipe in the rear)? are most of you guys running an external wastegate? what about oil feeds and taps what did everyone do for that? and boost controllers does everyone rely on just their wastegate springs?
jonathan923 Aug 12, 2011 01:35 PM
I havent seen anyone using an lnf manifold on an lsj. the manifold i run doesnt hit the coolant pipe, neither does the ones ive seen in other turbo lsj setups. Am runng internal wastegate which is set to 16psi. for your oil lines, is a must to tap your oil pan so you can conect the drain from the turbo to the oilpan. On the oil feed line we use a bolt that conects on the top of the block right under the turbo manifold, take the bolt out and use an oil fitting in order to run the oil feed line through there.
hawlyns711 Aug 12, 2011 02:00 PM
thanks there jonathan that info is helpful.
what size hose/line did you use for the oil feed and drain for the turbo, is it hard line or braided?
jonathan923 Aug 12, 2011 02:51 PM
no problem man. i used a stainless steel line for the oil feed as for the drain line i just have a regular braided hose. works good so far.
07BoostedG5 Aug 12, 2011 02:53 PM
click :)
startingline05 Aug 12, 2011 02:57 PM
noice!!!! go ahead and count me in as one of the slow lsj turbo cars aswell.
and while we have this thread up. how the F%*K do you get the damn belt tight. i am starting to get a squeeky belt and its bugging the hell out of me.
the only way i could think of doing it is putting the belt on with the tensioner on loose. the i push it down as hard as i can and tightened it. is this wrong lol?????
BLAZIN07SS Aug 12, 2011 03:11 PM
you shouldn't have to loosen anything on the tensioner. the tensioner gets bolted into one place and you should just have to use a pry bar to loosen some tension off of it to slide the belt on
Phyrric Aug 12, 2011 03:13 PM
I shall be a member of this thread soon depending how much I can milk out of student loans when already having florida prepaid :cssNET:
hawlyns711 Aug 12, 2011 03:18 PM
damn you florida residentls, lucky SOBs!!! my cousing in that area rub it into me, probably too much.
as for turbo why did everyone remove their m62 and not just keep it pushing boost?
startingline05 Aug 12, 2011 03:19 PM
this is y you sir are an fcotm winner
jonathan923 Aug 12, 2011 03:23 PM
because we all got tired of the m62s lol. too much work to make good power. As of now we have 4 Turbo LSJs in the squad :twothumbs
true that lol. and what tensioner are you using?
BLAZIN07SS Aug 12, 2011 03:23 PM
cause a turbocharger is a much more efficient compressor
jonathan923 Aug 12, 2011 03:24 PM
^^^^what are we doing for your Bday sir!
BLAZIN07SS Aug 12, 2011 03:27 PM
i want to go to indoor karting! they are having a bunch of events this weekend though so it would be stupid busy. maybe next weekend?
startingline05 Aug 12, 2011 03:29 PM
this one that comes with the zzp kit. i hardly ever drive the car so it just hasnt been that important to me to even try to fix the belt problem yet lol.
BumbleBee Aug 12, 2011 03:33 PM
I'll have to post some pics soon, cool thread idea.
Also, Jonathan how long have you been running that setup?
jonathan923 Aug 12, 2011 04:04 PM
ive been running this setup since Feb this year, not one issue so far thank god lol. ive been running it strong and raced alot of people with it. only thing is see affecting me in the near future is the clutch, which am running a stock lsj clutch. So yea i think it has lasted pretty long :)
Chevycobaltss3 Aug 12, 2011 04:06 PM
Yeah bro too much to list O:-).. :-P
BumbleBee Aug 12, 2011 04:37 PM
Good to hear.
How many miles on the car?
INFE Aug 12, 2011 04:53 PM
Not rare Just unwanted! :lol::lol::lol:
