anyone know where i can get a tvs i love supercharged 4 cylinders
im jealous of everyone in this thread...thats a built TVS saying he's jealous BTW LOL
(Post 5983494)
technically, i could say on pump gas. cause it was 110octane from a local speedway....from the pump, but i'm not a douche like that :lol:. but my real pump numbers are still unheard of lol
heap 1 same issue as billig
http://i370.photobucket.com/albums/o...1/IMAG0371.jpg heap 2 new im http://i370.photobucket.com/albums/o...1/IMAG0426.jpg heap 3 http://i370.photobucket.com/albums/o...1/IMAG0360.jpg bay looks like shit right now she won't even try to crank lmfao :) |
(Post 5983618)
Precision 6262 lsj I tuned. 443whp on 21psi on 93 octane, no meth :p:
just wait till i get the batmowheel on there. or even just the 198s still on the billet wheel. hahah. the only reason i'm not in the 500s on pump and 700s on 110 is the injectors |
(Post 5983494)
(Post 5983671)
billet s262, 443whp on 20psi 91octane, no meth, unported head. :p::p:
well duh, over stock it definitely makes a difference. but over a ported head on stock cams?? definitely not
(Post 5983715)
It was also basically stock. Diamond pistons, arp studs, that's it :) revving to 7200rpm. Just saying they are heard of ;)
(Post 5983716)
well then go dyno again now that you got all 4 valves and run some more timing.
I cant wait to do my swap. I know it will be worth it. All i hear is good news lol
if by good news you mean open wastegate, then yes thats all you'll hear
lmao^^^^ HEY!!! am internal wastegate :( i like it though :)
I would go turbo if I had the money, but I think i'd push the limits of a S/C first. Plus cops round here hear a BOV or spooling they are on you like stink on shit..... now for some reason they don't give a shit about the blower. odd. They used to love my old 2G GSX with big front mount, and greddy BOV, and open dump.
IMO it takes alot of work, time, and more money to really get to max 300whp on an m62. With turbo the least your will make is between 315-330whp just to start. then its just a matter of turning up the boost and some tunning and done. :) so i think its just better to save up the money and go for it, i mean its everyones choice unless you really like the blower..
lol remember the days when you were the shit if you had a 2.8 or lower pulley and 60's on a m62 and running meth?????
hahaha i rememeber when the gms2 on the lsjs where moppin everything up lol. even srt4s and everyone respected cobalts after that haha.
what alternator, tensioner, and belt do i need for my turbo swap? im keeping my A/C.
i happen to already have a tensioner from a 2.4. i see ZZP sells a turbo swap kit for this belt drive assembly swap but i could prob get the shit cheaper separate and get a core charge for my original alternator |
the 2.2/2.4 belt, alternator, and tensioner. or get an idler pulley in place of the stock blower pulley
trust me you're better off buying the zzp kits there's so many little things included only reason i didnt get the kit is the cp would be diff on my car lol
am using the 2.4 tensioner, 2.2 belt and stock alternator just welded lol :) works good for me
If i'm in a position to drop 3k or more on a turbo swap i will. In the mean time I'll be picking up the little odds and ends to go for 300hp. I have a 2.7 already, highflow DP, and header. Just need 80's, gauges, and a good dyno tune. I'm dealing with a fail dealership over getting my simple motor swap done right, so a ZZP s2 may be in the works paid for by insurance.
shit i'mma put a 5.8L blower on mines car and wooo wooo past you!
My current setup:
Bought Parts: -Hahn 20g turbo -ZZPerformance Log-style manifold -Tial 38mm Wastegate -Hahn Sheet metal Intake Manifold -Hahn 3" Downpipe -Vibrant 3" Cat-back exhaust -HKS Super SQV bov -Monotron 80lbs/hr injectors (from ZZP) -OTTP gen. 1 return style fuel system -GM 3 bar MAP sensor from ss/tc stage I kit -Genuine SAAB Intercooler -Oil feed/return line from ZZP -3.5" MAF tubing from ZZP Custom Parts (fabricated by Kratos Koncepts): -Charge pipes -Short Ram Intake -Turbo-to-downpipe exhaust piece -Open dump tube from wastegate This doesn't include the guages I had to buy b/c I was a douche and didn't prepare properly. Here's my "build" thread: https://www.cobaltss.net/forums/2-0l...-story-240486/ Problems: (1) First problem came when I started with the wrong parts. I bought a HAHN turbo manifold (beautiful piece of artwork) that ended up being for a 2.2 j-body ecotec. FUUUUUUUUUU. That was a real hit to the nuts. Had to order a part from ZZP (along with some misc. stuff) while it was on backorder. EFIN FUUUUUUUUUUUUU. Had to sell the beautiful manifold to some wet-back in Mexico City just to get my money back. Double-EFFIN FUUUUUUUUUUUUU..... (2) Next came the dreaded fuel pump recall...my car had it, but for some reason my car's VIN was not part of the recall. FUUUUUUUUU. Thankfully, my crafty buddy at Kratos Koncepts jerry rigged something that works perfectly. (3) Then came the issue with the replacement throttlebody bolts I bought. They weren't from GM, so as we were tuning, I went WOT and some how two of the bolts were chilling in my wheel well. Created one interesting lean condition....FUUUUUUUUUUU. (4) Now I'm dealing with a smoking issue...but thanks to rob (usmcp), I'm reworking my pcv system so that I can hopefully get the issue resolved. Otherwise, I will need a restrictor and fix it that way. Either way, this problem plus problem no. 3 means that all tuning is at a stand still. Anywho, I will be installing a boost controller as well during the down time. Future Plans: Internal work (pistons, rods, maybe port the head, or just buy one and build it) and crank the boost to over 25psi. Then after I run that sum-bitch down, I might switch over to a BW...but that's a wish list that comes with everything else (engine and then some). Pics, vids, and other shit can be found in my "build" thread. Or you can just friend me on FB and you'll see my photography there. |
