Official Turbo LSJ thread!!!
Old Jun 28, 2013 | 06:05 PM
  #5876
c130aviator's Avatar
Old Jun 28, 2013 | 10:15 PM
  #5877
574's Avatar
574
Can anyone point me in the right direction to oil return and feed flanges for my precision turbo? I found these but I don't want to order if it won't fit.
Oil & Water: Turbo Oil Inlet And Drain Flanges
Old Jun 29, 2013 | 12:48 AM
  #5878
randomname's Avatar
I've tried searching for an answer to this question but had no luck.. When do I need to worry about maxing out the MAF (I think I may be close to maxing it)? Also, if I wanted to use an LS1 MAF from my GTO would that work?
Old Jun 29, 2013 | 12:54 AM
  #5879
you will get the MAF is out of range P code and CEL... then you are out of range. LOL I get it all the time so I deleted the notification. Tuned around it and commanded more fuel in PE.
Old Jun 29, 2013 | 01:22 AM
  #5880
randomname's Avatar
Ah ok, do you know if I could use the stock LS1 MAF I pulled off my GTO in the event I want to go bigger? I know I'd need to tune for it. I want to shoot for 420whp on a mustang dyno.
Old Jun 29, 2013 | 01:26 AM
  #5881
There are guys here with a larger map and then you scale it to fit inside the crappy coded lsj ecm (254kPa max table). But its really unnecessary. To each their own, it affords them things they wanted in their tune. I am tuned for map up to 3000 rpm, then it doesnt matter after that. Map just becomes a way to watch the pressures in hpt until 254, then I watch what its doing on my gauges or the dyno. MAF is more important on our cars for turbo purposes.
Old Jun 30, 2013 | 06:42 PM
  #5882
574's Avatar
574
Will this work on my precision turbo?
ZZPerformance - Oil Feed & Return Line Kit for Ecotec #ZZ-OFL-ECT
Old Jun 30, 2013 | 07:58 PM
  #5883
mexi_loco's Avatar
It should work. That's what I used for my s20g. Your turbo isn't water cooled, correct?
Old Jun 30, 2013 | 08:44 PM
  #5884
When are you going to get that 20g up and running? Excited to see what you are going to do with it.
I have a ton of info that i have gathered on the 20g, its become an obsession cause I was trying to find the diamond in the rough. Its old tech and although popular on JDM stuff its still not a very sought after turbo. Get a pencil cause I am about to unload my findings for it.
Well our TD06/TD05 10cm turbo is actually a very well put together setup. Bill Hahn chose this pieced together turbo out of years of racing them on DSM cars and later the Ecotec and SRT4 cars. They never made the power I did because most of his customers were throwing a kit on and calling it good. There may be a few of unheard customers running these things into the PSI I did this past week. But I have been the only one getting back to him regularly with progress on my build.
Our 20g hits its peak efficiency at 25-30 psi depending on the flow of other components so the old saying that 25 is it on the internal waste-gate is garbage. With the Ecotec head ported and a 3" exhaust it flowed well into the 27 psi before loosing efficiency on the ported LSJ Ecotec head. At 28 psi I started see the power decrease and tq increase about 5 ft lbs.
So on E85 we can throw lots of fuel at this turbo that usually would create heat over a given psi depending on the engine it was bolted to and still make power instead of heat.
ITS ALL ABOUT E.
So on our cars it looks like we make 27 psi on E before dropping in power. Also for every 1 psi of boost on the 20g I was seeing 10whp.
Feb 2013 Dyno pulls (bad bearings, 10,000 miles on turbo)
At 15 psi I was at 338
At 20 psi I was at 400
At 22-23 psi I was at 420
June 2013 Dyno pulls (rebuilt turbo by me with Mitsubishi Heavy Industry parts, stock fuel pump on afr numbers)
At 18 psi I was at 388 11 afr
At 27 psi I was at 472 13 afr
At 28 psi I was at 462 (dropped in efficiency) 13 afr
At 24 psi I was at 430-440 (messing with the brfps) 12 afr
Also the numbers could be questioned and I dont blame people being skeptical of the 20g but with e85 you can lean on it more, our heads flow well, and the results are repeatable on a very expensive eddy current braked chassis dyno. There was a corvette running on the dyno the weekend I dyno'd my car, he put down 600whp for comparison on NOS. I feel my numbers are fairly accurate. There were many more runs than just what I have listed above and all of them were within 10whp of the given psi we saw on the dyno. I have graphs for the numbers above but we were running 460's consistently in the 12-13 afr range while messing with my BRFPS. I just ran out of fuel pump.
Old Jun 30, 2013 | 09:37 PM
  #5885
574's Avatar
574
Thanks, it's oil cooled
Old Jul 1, 2013 | 02:26 AM
  #5886
SupaCharged06's Avatar
Almost done with my build! /excited. This may be a dumb question, but how did zzp plumb their wastegate vacuum lines, to the Saab intake manifold?
Old Jul 1, 2013 | 08:40 AM
  #5887
MP Cobalt's Avatar
hahaha officially have the worst luck with my car lately. Low on power and everything and bought new wheel setup and haven't been back on dyno recently. Need a new left axle and possible transmission now. Car sounds normal until I put it in gear ( any gear) and it gets hard to shift at times and gets a horrible whistle noise or sounds like someone is dragging a tin can across pavement. Going to check transmission fluid here on Friday I hope that is the issue, but the question is where did it go if that's the issue
Old Jul 1, 2013 | 11:55 AM
  #5888
For sale sign lol. Good news is you can get a drivers side axle from the parts store, passenger side you can't, atleast in my experience. Only makes nose when in gear could be your tob too. Does the noise change in neutral when you play with your clutch?
Old Jul 1, 2013 | 02:18 PM
  #5889
MP Cobalt's Avatar
Yeah the noise only happens when you push the clutch in and put it into any gear and is stiff and hard to get in and out of gears.
Old Jul 1, 2013 | 03:06 PM
  #5890
BLAZIN07SS's Avatar
I'm too JDM for you
Lol they are the same exact axle. completely interchangeable
Old Jul 1, 2013 | 08:33 PM
  #5891
ItalianJoe1's Avatar
Definitely a clutch/TOB issue, the hard shifting is because you are not fully releasing the clutch when trying to shift. Time to drop the trans!
Old Jul 1, 2013 | 08:41 PM
  #5892
Could be tob
Old Jul 1, 2013 | 08:43 PM
  #5893
I've read this before but GM has different part numbers? And when i had my axles out they were different lengths. Unless I'm just crazy which could be..
Old Jul 1, 2013 | 09:03 PM
  #5894
They say left and right on them from the factory but they can be swapped back and forth, they are the same size.
Old Jul 2, 2013 | 12:35 AM
  #5895
Bad-A-SS's Avatar
Just dropping this in here. Finally got a video just wondering if I should cut the muffler off and just have it full 3in straight piped. What's yalls thoughts?
Old Jul 2, 2013 | 02:24 PM
  #5896
Bad-A-SS's Avatar
What kind of specs would be great for a aggressive street cam???
Old Jul 2, 2013 | 02:29 PM
  #5897
zzp stage 2 is as agressive and proven as they come. I just had a set in my garage, I just sold them. My perfect cam is the stock LSJ cams. They have a great powerband and have no need to be upgraded on a street car, even when you start making bigger power. Love my stock cams.
Old Jul 2, 2013 | 02:57 PM
  #5898
Bad-A-SS's Avatar
Well then I might just go with a fully ported n polished head, diamonds, n sleeves from mrb for my engine build
Old Jul 2, 2013 | 05:07 PM
  #5899
mrbelvedere's Avatar
There are guys here with a larger map and then you scale it to fit inside the crappy coded lsj ecm (254kPa max table). But its really unnecessary. To each their own, it affords them things they wanted in their tune. I am tuned for map up to 3000 rpm, then it doesnt matter after that. Map just becomes a way to watch the pressures in hpt until 254, then I watch what its doing on my gauges or the dyno MAF is more important on our cars for turbo purposes.
saying maf is more important for turbo purposes is an incorrect statement
if you are maxing out the maf then you need to rescale if you still run out of maf then you can add a bigger maf tube or you can add a maf t to the system
lsjion dose good port work
Last edited by mrbelvedere; Jul 2, 2013 at 05:12 PM. Reason: Automerged Doublepost
Old Jul 2, 2013 | 05:19 PM
  #5900
Right. There are several ways to approach the MAF issues.
3.5 inch MAF tube section
ZZP MAF Mini AFC Air Fuel Controller
If you hit the end of MAF you can tune around it on a dyno. This could be more difficult on a remote tune.
