Official Turbo LSJ thread!!!
Old Jul 2, 2013 | 05:39 PM
  #5901
mrbelvedere's Avatar
Right. There are several ways to approach the MAF issues.
3.5 inch MAF tube section
ZZP MAF Mini AFC Air Fuel Controller
If you hit the end of MAF you can tune around it on a dyno. This could be more difficult on a remote tune.
tuning around it is not the right way when there are better options available
Old Jul 2, 2013 | 05:51 PM
  #5902
c130aviator's Avatar
agreed, hoping to continue to work the car as money and time allows. I am daily driving 24 psi and 19 degrees right now (the 430whp graph). To get the car safe at 27 psi I need a fuel pump, a Mini AFC MAF controller to fix the over running MAF and more crank case venting on my short list.
Old Jul 2, 2013 | 06:03 PM
  #5903
Area47's Avatar
Rent me! per hour
if you're running out of maf at 472whp you have some other issues to work around.
with a larger maf section you will lose resolution down low, but gain control up top.
Old Jul 2, 2013 | 08:05 PM
  #5904
Tjolley's Avatar
Increase the maf housings size.
Old Jul 2, 2013 | 08:25 PM
  #5905
mexi_loco's Avatar
When are you going to get that 20g up and running? Excited to see what you are going to do with it.
Also the numbers could be questioned and I dont blame people being skeptical of the 20g but with e85 you can lean on it more, our heads flow well, and the results are repeatable on a very expensive eddy current braked chassis dyno. There was a corvette running on the dyno the weekend I dyno'd my car, he put down 600whp for comparison on NOS. I feel my numbers are fairly accurate. There were many more runs than just what I have listed above and all of them were within 10whp of the given psi we saw on the dyno. I have graphs for the numbers above but we were running 460's consistently in the 12-13 afr range while messing with my BRFPS. I just ran out of fuel pump.
Not too long now. I just have little things I have to do now. The main thing is that I have to uninstall my head and send it out for porting and polishing. I've been distracted because of a certain paypal dispute about a head I bought recently. Other than that, just need a timing chain kit, and install.
The head will consist of mostly stock parts, save for some valve springs from zzp. I also need to revise the breather system as well. After that, I'm still debating on buying a fuel pump off of a local. Just out of curiosity, what size injectors are you running? Also, what are you gapping your plugs at?
As for fuel, I've been on e85 for a while, so I know full well about what it can do.
I'm also thinking about getting some nitto nt555's for the front, but I'm not sure where to get them, how wide, and if they come in 18's (don't really want to switch back to 17's).
So, basically, another 2 grand or so, and she'll be ready to go!
Old Jul 2, 2013 | 08:49 PM
  #5906
nwss's Avatar
Not like any of you care but I'm picking up an ap1 s2k Saturday and well....we all know how much they love 6262's and 500+ whp
Old Jul 2, 2013 | 08:51 PM
  #5907
Magz_rule's Avatar
Alright guys.. I need help. Have the 252et zzp kit. Dw300 pump, id1000s, ottp return system for fuel. New set of bk7res gapped to .30. It started as a misfire when I got into full boost. And by misfire I mean car jerking my engine is going to blow the **** up misfire lol. It's now turned into anytime I'm over like 50 percent throttle it'll do it. It's not just a small miss or something. It's catastrophic... I'm at a loss. It's throwing no codes. Normal driving while not using the gas to heavy it's fine. The only code it's thrown while doing this was for the MAF being maxed out. Always got that though so I'm assuming that's got nothing to do with it. Where should I start? Thanks for any help guys.
Old Jul 2, 2013 | 08:58 PM
  #5908
mexi_loco's Avatar
I remember that a vacuum line on my buddy's lk9 would pop off occasionally. Maybe try there first. Have you actually done a boost leak test?
Old Jul 2, 2013 | 11:28 PM
  #5909
Killa SS's Avatar
Any one using ID2000cc or bosch2000cc injectors? Any feed back
Old Jul 3, 2013 | 07:14 AM
  #5910
randomname's Avatar
What exactly is a MAF T and what does an Air Fuel Controller do exactly? Sorry for the nub questions, I come from the land of N/A V8's lol
Old Jul 3, 2013 | 09:33 AM
  #5911
MP Cobalt's Avatar
Originally Posted by ItalianJoe1
Definitely a clutch/TOB issue, the hard shifting is because you are not fully releasing the clutch when trying to shift. Time to drop the trans!
I was thinking tob at first because it always makes that damn chatter noise, but then if I'm at a dead stop and put it into first you hear this horrible noise that i cant even explain the sound. So idk if its the clutch or tob or a bad bearing in the transmission or maybe even my clutch rod is bent from my old hypersingle clutch
Old Jul 3, 2013 | 10:37 AM
  #5912
SupaCharged06's Avatar
Maf t is I'm pretty sure just the section of pipe the maf screws into. Apparently if you put a bigger housing there it helps the scaling issues with our pcm.
No clue on the controller
Old Jul 3, 2013 | 11:21 AM
  #5913
a maft is not a section of pipe the maf sets in
go read
MAF Translator
Old Jul 3, 2013 | 12:14 PM
  #5914
randomname's Avatar
go read
MAF Translator
Thanks for the link! I was reading and was thinking I could buy that and use the stock LS1 MAF from my GTO to replace the MAF on the SS. Unfortunately, I'd need to buy another LS2 MAF since the IAT is integrated into those sensors (5pin LS2 vs 3pin LS1). I guess I could always get a breakout harness and drill/tap a hole for an IAT sensor but it's probably cheaper to just buy a used LS2 MAF. What is the diameter of the stock throttle body on an 07 SS?
Old Jul 3, 2013 | 02:33 PM
  #5915
Area47's Avatar
Rent me! per hour
stock ecm won't run them.
Old Jul 3, 2013 | 03:09 PM
  #5916
randomname's Avatar
You can't tune the stock ECM for ID1000's? Or did you mean you can't run them on stock tune?
Old Jul 3, 2013 | 03:16 PM
  #5917
mexi_loco's Avatar
I believe he commented about id2000 injectors not id1000
Old Jul 3, 2013 | 03:25 PM
  #5918
randomname's Avatar
Oh I see now, derp.. lol
Old Jul 3, 2013 | 04:59 PM
  #5919
Killa SS's Avatar
Why is that? How does the ecm run zzps 190s?
Old Jul 3, 2013 | 05:44 PM
  #5920
Area47's Avatar
Rent me! per hour
outside help. IE a band aided assistant.
Old Jul 3, 2013 | 06:55 PM
  #5921
BLAZIN07SS's Avatar
I'm too JDM for you
x2...and honestly these damn id1000's with the ott return kit provide a **** ton of fueling.
Old Jul 3, 2013 | 07:07 PM
  #5922
armcclure's Avatar
You couldn't use flow rate vs volts AND scale cyl volume down 50 or 75%?
Old Jul 3, 2013 | 08:45 PM
  #5923
Area47's Avatar
Rent me! per hour
you're not pushing 900whp on e85. there is a fine line here and 2kcc injectors are not the answer. if you are out of injector on 1kcc injectors you have a fuel issue and it is not the injectors. build a fuel system.
Old Jul 3, 2013 | 08:47 PM
  #5924
Killa SS's Avatar
Id like 600whp on e85. I have 80s and a walbro 255. injectors are near maxing at 460whp on a s256et.
Old Jul 3, 2013 | 08:52 PM
  #5925
Bad-A-SS's Avatar
No brfs or rsfs?
