Official Turbo LSJ thread!!!
Old Aug 7, 2013 | 10:45 PM
  #6326
Killa SS's Avatar
Hey guys. My tuner needs help tuning my car with the new ID1000s i just put in and getting my speedo correct with the new 6spd. Any one help? My afrs are 10.3 wot. Im on e85. Turbo swap. I can email logs
My idle jumps a bit. Any help is appreciated
Old Aug 7, 2013 | 10:49 PM
  #6327
SylverSS/SC's Avatar
It looks to be over the ports but I'm not sure. I'm back from work in 2 weeks and I'll get a picture then
I'm not looking to go over 400 Hp. -6an isn't big enough?
Old Aug 7, 2013 | 10:56 PM
  #6328
EXsoccer1921's Avatar
That's only a 3/8" hole.
Old Aug 7, 2013 | 10:57 PM
  #6329
I mean I guess 4 of them would suffice at -6. But I would run at least -10 or -12.
Old Aug 7, 2013 | 11:08 PM
  #6330
Worst case is I'll use my spare and weld bigger ports on it
Old Aug 7, 2013 | 11:17 PM
  #6331
armcclure's Avatar
For which line
Old Aug 7, 2013 | 11:21 PM
  #6332
Lines coming from the valve cover.
Old Aug 7, 2013 | 11:32 PM
  #6333
ItalianJoe1's Avatar
I have a file setup for ID1000's and E85 from Blazin's car, if you wanna shoot me a copy I can see what's different and advise. Italianjoe1@hotmail.com
FWIW, the idle will never be perfect, if you are running enough fuel pressure to support solid boost. What is your base pressure? IIRC Josh's car is around 50psi and the idle is a bit higher than stock to be smooth, but the injectors are 3x the size of stock so that's to be expected. The car drives awesome though.
Old Aug 8, 2013 | 12:07 AM
  #6334
Killa SS's Avatar
Base fuel pressure is 52psi.
Ill have him email the file to me and get it over to you asap. Thank you
Old Aug 8, 2013 | 12:09 AM
  #6335
Ok at that pressure you should be fine, I believe we are under 90% IDC at 26psi. E85 needs fuel like a ************
Old Aug 8, 2013 | 03:06 AM
  #6336
c130aviator's Avatar
Your idle as italianjoe said wont be perfect, the thing to make sure is that your stft and ltft are within a few percent. You afr, crusing, and just drinving around in general should bounce around 14-15, under WOT depends on your boost level but if you are referring to e85 stoich then 10.3 is bad as you have indicated.
Old Aug 8, 2013 | 05:21 AM
  #6337
armcclure's Avatar
And your theory here?
Old Aug 8, 2013 | 07:04 AM
  #6338
BLAZIN07SS's Avatar
I'm too JDM for you
my base pressure is at 43psi
Old Aug 8, 2013 | 07:59 AM
  #6339
armcclure's Avatar
I'm surprised that's enough for you... What's your idc and afr at redline?
Old Aug 8, 2013 | 08:07 AM
  #6340
Killa SS's Avatar
Well he doesnt seem to think he needs to adjust cells individually. Hes richining and leaning all cells together. I dont like this. First he tells me hes tuned a few LSJs and now hes like im the first one..... im still waitinf for him to email me the tune
Old Aug 8, 2013 | 09:39 AM
  #6341
BLAZIN07SS's Avatar
I'm too JDM for you
duty cycle sits around 80-83% and it's 11.8-11.9 in gasoline afr with e85
Old Aug 8, 2013 | 09:54 AM
  #6342
InfraRedline's Avatar
Is he a subaru tuner by chance?
Old Aug 8, 2013 | 09:55 AM
  #6343
Killa SS's Avatar
Lol I dont think so name is scott. Lives in mich and has a turbo 3800 fiero that ran a 10.00 1/4mile
Old Aug 8, 2013 | 10:46 AM
  #6344
mrbelvedere's Avatar
The vc port IS a fresh air inlet. Study some basic physics. At part throttle the post tb vac is greater than the intake tube, so the check valve in the head/IM pulls vac on the case. It wouldn't do any good to just suck on the case though; the while point it to get the vapors out. That's what the fresh air inlet is for.
Some of you really need to do some research on how the system works. It's NOT that ******* hard to understand.
incorrect
Originally Posted by Tjolley
The idea is fresh air in the crank case.
Helps cool the air coming out of the vc to turn the oil vaper back into a liquid.
not on the lsj
Same basic principle as big blocks except they introduce fresh air through one valve cover and it works it's way over to the other and into the vacuum ports on the throttle body
lol
An internal combustion engine is built around a series of hollow cylinders, in each of which is a moveable piston designed to glide up and down inside it. A mixture of air and gasoline is pumped through a system of tubes called the intake manifold through each cylinder's intake valve (or valves), where a spark from a spark plug causes the mixture to explode in the open space at the top of the cylinder called the combustion chamber. The pressure from this explosion drives the piston in the cylinder downward, where it causes the crankshaft to rotate. The rotation of the crankshaft not only pushes the piston back up into the cylinder so it can do all this again, but it also turns the gears within the car's transmission that eventually make the car move. Meanwhile, the rising piston pushes the air and gas left over from the explosion back out of the cylinder through an exhaust valve.
However -- and this is where crankcase ventilation comes in -- a certain amount of that mixture of air and gasoline is pulled down by the piston and slips through the piston rings into the crankcase, which is the protective cover that insulates the crankshaft. This escaping gas is called blow-by and it's unavoidable. It's also undesirable because the unburned gasoline in it can gunk up the system and produce problems in the crankcase. Until the early 1960s, these blow-by gases were removed simply by letting air circulate freely through the crankcase, wafting away the gases and venting them as emissions. Then, in the early 1960s, positive crankshaft ventilation (PCV) was invented. This is now considered the beginning of automobile emission control.
Positive crankcase ventilation involves recycling these gases through a valve (called, appropriately, the PCV valve) to the intake manifold, where they're pumped back into the cylinders for another shot at combustion. It isn't always desirable to have these gases in the cylinders because they tend to be mostly air and can make the gas-air mixture in the cylinders a little too lean -- that is, too low on gasoline -- for effective combustion. So the blow-by gases should only be recycled when the car is traveling at slow speeds or idling. Fortunately, when the engine is idling the air pressure in the intake manifold is lower than the air pressure in the crankcase, and it's this lower pressure (which sometimes approaches pure vacuum) that sucks the blow-by gases through the PCV valve and back into the intake. When the engine speeds up, the air pressure in the intake manifold increases and the suction slows down, reducing the amount of blow-by gas recycled to the cylinders. This is good, because the blow-by gases aren't needed when the engine speeds up. In fact, when the car is up to speed, the pressure in the intake manifold can actually become higher than the pressure in the crankcase, potentially forcing the blow-by gases back into the crankcase. Since the whole point of positive crankcase ventilation is to keep these gases out of the crankcase, the PCV valve is designed to close off when this happens and block the backflow of gases.
Old Aug 8, 2013 | 11:27 AM
  #6345
Tjolley's Avatar
Y do u think the port on the back over the valve cover has vacume wen the car isnt boosting.
An increased size is good to alow better flow
Old Aug 8, 2013 | 11:54 AM
  #6346
it has vacuum from the intake side not the engine side plug the hole and see what will happen
Old Aug 8, 2013 | 11:57 AM
  #6347
Tjolley's Avatar
Mine has vacume pulling into the valve cover
I checked it lastnight
Old Aug 8, 2013 | 12:06 PM
  #6348
im gonna have to call bull **** on that and this is how I know when I bought my intake from ottp I put it on fired up the car and setting there idling about 10 min the dipstick popped up I didn't think anything about it went to meet a buddy and on the way home the dipstick belw out and oil was everywhere the next day cleaned **** up and got to looking and you run the engine and hear the pressure building in the engine pull the vent line off of the the intake and air pressure would run out of the vent line after looking at the intake I seen they put the bung on for the vent line but didn't drill the hole so I drilled the hole problem solved
Old Aug 8, 2013 | 12:10 PM
  #6349
Tjolley's Avatar
Wen vacume drops the valve in the mani closes.. So if u boosted even a lil with out the vc vent pluged it will blow the dip stick oit.
Old Aug 8, 2013 | 12:17 PM
  #6350
not at idle it dose not shut
