Official Turbo LSJ thread!!!
Old Oct 21, 2011 | 03:34 PM
  #851
EXsoccer1921's Avatar
what do you mean
Old Oct 21, 2011 | 06:37 PM
  #852
selfinfliction's Avatar
needs moar psi's in here!
Old Oct 22, 2011 | 10:00 AM
  #853
05Slowline's Avatar
what are you guys usin to reflect heat off the **** around the turbo and wastegate an ****, i used some reflective heat tape but now that it's cold out its losing its stickyness lol....thinking about just gettin a blanket for it and lettin whatever of my tape falls off just stay off haha..
Old Oct 22, 2011 | 02:02 PM
  #854
i don't have anything back there, so..nothing haha. but i've thought about getting a blanket for the turbine housing
Old Oct 22, 2011 | 03:12 PM
  #855
slvr 04 rl's Avatar
i dont have anything back there either and I cant fit a blanket over the turbo. It already bumps the firewall sometimes anf I cant even fit my pinky finger behind the turbo.
Old Oct 22, 2011 | 03:16 PM
  #856
jonnymerk's Avatar
what do you mean
It was 35 everywhere.
Old Oct 22, 2011 | 04:06 PM
  #857
05Slowline's Avatar
well **** guess i wont worry bout it then lol....
another question for anyone using the tial 38mm mvs wg...i was half throttle in 3rd and hitting 25-30 psi lmao so i have an issue there...are you guys running anything to the top port of the wg? i have a fitting on my hscp right after the coupler from the turbo, that goes into the zzp mbc, out of it, and to the bottom wg. then i have just a reference off the intake mani to the top port of the wg...tials diagram was somewhat vague lol. this is without the mbc turned up at all so that shouldn't have any effect on it btw should just be running off the spring in the wg which said .6 bar spring in it.
Old Oct 22, 2011 | 06:04 PM
  #858
i have a precision 46mm so they may be ran different. but i have it set up as bottom nipple of wastegate -> boost controller -> intake manifold. i don't have anything on the top nipple. it was like that with my old turbo setup as well but instead of the line going from the mbc to the manifold it went to the hot side pipe.
Old Oct 22, 2011 | 06:42 PM
  #859
05Slowline's Avatar
so you just have the top port open to atmosphere? thats what i was reading on dsm forums that have the 38mm mvs also maybe that's my problem i'll have to pull it off plug it and find out lol thanks.
Old Oct 22, 2011 | 08:13 PM
  #860
BLAZIN07SS's Avatar
I'm too JDM for you
Zzp's boost controller is a regulator style. Ask them about the vacuum routing. I know it has two lines gong to the wastegate. It's not like a standard boost controller
Old Oct 22, 2011 | 08:27 PM
  #861
i'm back on the hallman mbc
Old Oct 22, 2011 | 08:58 PM
  #862
05Slowline's Avatar
yea i pmd ryan lol fkin car
Old Oct 23, 2011 | 10:07 PM
  #863
jittjoey's Avatar
I have the zzp kit for the turbo swap... i have 90% i should say lol... i need suggestions ... full turbo manifold or the turbo adapter plate... what are the benefits of either, and are there andy good tuners in ne ohio... i live 45 mins from youngstown, 45 mins from pittsbutgh pa and about 1 hour from akron...any help is taken with open ears thanks in advanced
Old Oct 23, 2011 | 10:08 PM
  #864
mexi_loco's Avatar
just get the saab manifold from zzp or ttr's manifold. I honestly wouldn't keep the stock intake manifold unless you're planning on staying low boost for a while.
Old Oct 23, 2011 | 10:21 PM
  #865
jittjoey's Avatar
"just get the saab manifold from zzp or ttr's manifold. I honestly wouldn't keep the stock intake manifold unless you're planning on staying low boost for a while."
__________________
No im def not staying at low boost... im getting stage 2 cams spring and retainers, turbo swap and a few mounts too for this month... then axles and random **** next month.... looking for a how to on the turbo lsj swap... how hasnt anyone done this yet lol... and pointers from anyone? and i need to know if there are any tuners with experience or should i just buy the hp tuners myself?
Old Oct 23, 2011 | 11:15 PM
  #866
InfraRedline's Avatar
Check your thread on RLF lol we had the same issue on my friends 30r evo when we were tuning. Swapped the vac line to the lower wg barb and left the top one open (or plugged...now I forgot lol), but the important thing is that it worked on the lower barb
Old Oct 24, 2011 | 12:25 AM
  #867
Ryan@zzp's Avatar
Originally Posted by tlanzetta11
Okay, got a problem. Today on my way to college, i pull onto the highway and i do a 2nd gear pull into third. All of a sudden, it feels like my car hit a brick wall. Sputtering badly when accelerating. Manage to get into a parking lot off the highway, and look under the hood. Nothing is loose. No smoke, No weird smells. I couldnt be late to class so i got it to make it to school which was about 10 min away. after class i had to get home and it made it home. checked the plugs, all of the intercooler connections, literally everything is normal. What could this be? Once im over 3500 rpm and you give somewhat of alot of throttle it boosts like normal. Very rough idle. When pressing the throttle steady, it idle surges up and down. Cant seem to figure it out took all the piping off and checked for anything. Absoutly nothing. Any ideas?
Sounds to me like you popped a rocker off.
Old Oct 24, 2011 | 03:08 AM
  #868
BlkWdoSS's Avatar
There isnt a How-to for turbo install because there would be too many people screw their cars up. If you do not know how to install a turbo, pay someone else to do it. Its too easy to screw up.
If you need pointers, then please ask specific questions. As with any modification, there is always slight to moderate fitment issues, there is the possibility of specialty tools, and takes a good sense of mechanical knowledge. If you are going to turbo your LSJ, get an idea of how you will handle crankcase ventilation. Also, Map out your entire kit prior to install, get a game plan and stick to it. Don't waste time with missing fittings and trips to the store.
DO NOT JUST BUY HP TUNERS AND ATTEMPT TO TUNE YOUR CAR. Find a tuner! I do suggest buying HP Tuners for monitoring and logging. It will help you to display information relative to issues so that your tuner can identify and correct them quickly. It doesnt have to be a tuner from here. Most late model GM shops have experience with HPT and can help. Or you can go the route of Trifecta, Vince does some nice liberal tunes that will be plenty safe for getting you started.
l8r,
PD
Old Oct 24, 2011 | 12:31 PM
  #869
jittjoey's Avatar
l8r,
PD
Thanks ... And as far as hp tubers I wasn't gonna tune myself but thought it would be good to have someone send a canned tune that will get me to a Dyno shop atlases ... Then have it for the future mods ie cams and what not
Old Oct 24, 2011 | 12:36 PM
  #870
jittjoey's Avatar
As far as the install I can't find anyone around.... I live in Ohio 45 mins from Pittsburgh Youngstown , hour from Akron and 2 from Cleveland ... Surely there's gotta be someone
Old Oct 24, 2011 | 02:13 PM
  #871
how far are you from kentucky?
Old Oct 24, 2011 | 05:23 PM
  #872
jittjoey's Avatar
7 hours to my brother in laws place in ft Knox
Old Oct 24, 2011 | 09:01 PM
  #873
startingline05's Avatar
what do you guys think is the best t3 gasket to use is?
I need to purchase another one and i just want so input one a pretty dependable gasket.
Old Oct 24, 2011 | 09:09 PM
  #874
BLAZIN07SS's Avatar
I'm too JDM for you
zzp's t3 gasket has worked perfect for me. Lathered it in copper permatex before install and have had no issues. Make sure you use lock washers on the bolts as well
Old Oct 24, 2011 | 09:12 PM
  #875
thats my prob.
i started getting a bad exhaust tick and when i checked i was missing 2 bolts holding on the turbo. so i will deff ou lock washers
i figured the gasket is screwed because of this so i am getting a new gasket
