Official Turbo LSJ thread!!!
Old Oct 17, 2011 | 04:06 PM
  #776
Chevycobaltss3's Avatar
Mark suck a weiner you troll.. Oh btw i love you no homo!!
Old Oct 17, 2011 | 04:08 PM
  #777
BlkWdoSS's Avatar
Lol, I havent had a lot of time and there isnt much space to work in, It will be gone soon enough. So other than the mat lol, no other comments?
l8r,
PD
Old Oct 17, 2011 | 04:13 PM
  #778
buy a lnf... i mean **** a lsj !!!!!! I like it tho. good job
Old Oct 17, 2011 | 04:27 PM
  #779
EXsoccer1921's Avatar
what turbo manifold are you running? i expected more of that 366 to be showing
Old Oct 17, 2011 | 04:54 PM
  #780
just took a trip to texas and had been getting some nasty blowby out the exhaust. just took the intake off and just my ******* luck.
coupler on the intake had a good puddle in it as well. turbo only has ~3500 miles on it.
Old Oct 17, 2011 | 04:56 PM
  #781
nwss's Avatar
well i just started my conversion..here goes a few grand =)
Old Oct 17, 2011 | 05:59 PM
  #782
BlkWdoSS's Avatar
Im running the one off of Robert's (USMCFieldMP) car. It's a custom design, only 2 were made, the one that I have and the one that is on 06black's car. Yea it is hard to see the turbo with all of those tubes, Ill upload a picture from the bottom so you can see it lol.
l8r,
PD
Old Oct 17, 2011 | 06:02 PM
  #783
new breather setup. have the can sitting under the drivers headlight.
and just for fun while i have the intake off
Old Oct 17, 2011 | 06:04 PM
  #784
BlkWdoSS's Avatar
what size feed and return are you using? its possible that its not your turbo and just simply over oiling or crankcase ventilation issues. Im going to be adding a vacuum pump to mine very soon.
l8r,
PD
Old Oct 17, 2011 | 06:06 PM
  #785
i'm gonna do a compression test tomorrow to hopefully rule out ring failure. but it just recently started doing this, never did it before this weekend. not sure on the feed line size, its damn small though. and the return is huge. actually i think i have a picture just a sec.
Old Oct 17, 2011 | 06:11 PM
  #786
i also checked the drain line to make sure it wasn't plugged and its not. there is also oil on the brake booster right under the BOV.
Old Oct 17, 2011 | 06:16 PM
  #787
BlkWdoSS's Avatar
the feed looks small enough and the return looks like its at least 3/8" possibly 1/2". I thought this was a brand new motor, why would it have ring failure? has it seen WOT much since the rebuild? how long was it broken in? and when was the last time the valve seats were inspected?
l8r,
PD
Old Oct 17, 2011 | 06:27 PM
  #788
yeah whatever zzp uses for the feed and return is what i've got. it is a brand new motor, which is why i hope to god a ring didn't fail hahah. but by the sound of the exhaust and the idle, and the lack of CELs, i'd say i'm fine there. hardly sees WOT, only a few times on the street since the break in oil +3 passes at the track. after picking it up at the shop i did an oil change at about 400 miles with another round of brad penn engine break in oil. had that for 2k miles then brad penn 5w30 went in
Old Oct 17, 2011 | 06:28 PM
  #789
theres also oil on the brake booster under the BOV..
Old Oct 17, 2011 | 06:41 PM
  #790
BlkWdoSS's Avatar
hmm sounds like crankcase issues, which im beyond positive is my main issue right now lol speaking of, where did you get the oil cap fitting? thats way sweeter than just drilling it
start with a vacuum pump and see if thatll get it done, but in all actuality, all turbos have a tiny leak due to the seals that are in them
more pics of mine:
l8r,
PD
Old Oct 17, 2011 | 07:20 PM
  #791
terry11's Avatar
Run a restrictor
Old Oct 17, 2011 | 07:33 PM
  #792
more pics of mine:
l8r,
PD
if it were crank case and oiling issues, i would have had this problem on the first engine. and 2,500 miles ago on this engine.
Old Oct 17, 2011 | 07:35 PM
  #793
Originally Posted by terry11
Run a restrictor
if i needed a restrictor. everyone with the zzp oil line kit would need one. and they dont.
Old Oct 17, 2011 | 07:38 PM
  #794
ULWizSS's Avatar
Hope you figure it out shortly, best of luck Bro
Old Oct 17, 2011 | 07:45 PM
  #795
BlkWdoSS's Avatar
not necessarily, you did mention that you just switched from break in oil over to 5w-30, the break in oil wouldve been thicker, meaning the leak wouldve been much smaller or non existant due to the thickness
also, mine doesnt start doing it until its been in boost, since you were driving the car non aggressively during break in and have since taken it to the track then it is possible that it has just begun pushing past the seal.
l8r,
PD
Old Oct 17, 2011 | 07:47 PM
  #796
the switch to 5w30 and going to the track were in mid september. and i also drained out 2qts today when i got home and put in 2qts of Valvoline SAE50 racing oil to combat just what youre suggesting. so we'll see what happens.
Old Oct 17, 2011 | 09:02 PM
  #797
terry11's Avatar
Not everybody checks their car as regularly as you. A restrictor is always good to have bb or jb. It's a 5 dollar part to test out so there isn't much to loose
Old Oct 17, 2011 | 10:46 PM
  #798
Matt M's Avatar
It's not likely that the turbo is bad. Usually in these cases, when you correct the crankcase pressure issue the turbo oil leak clears up. It could be boost getting past the pcv valve.
Old Oct 18, 2011 | 01:27 AM
  #799
BlkWdoSS's Avatar
I hope it all clears up with this, if that doesnt work then a vacuum pump may be in order
your still running the stock dead head style fuel system? either way did you check out the pics that i posted where you can actually see the turbo? lol
l8r,
PD
Old Oct 18, 2011 | 01:50 AM
  #800
yeah i saw the pictures. looks pretty good
yeah i got everything installed. putting the intake back on tomorrow morning. but since the maf was clean im debating on whether or not to take off the piping and give it a good cleaning. last time this happened on the 3076 setup i tipped the intercooler on its side and oil just drained out. i calculated about 2qts of blowby in 450-500 during this trip. looking in the exhaust tip though the inside of the exhaust is coated.
were you able to take a look at the video i linked in that email?
