Official Turbo LSJ thread!!!
Old Nov 7, 2011 | 10:24 PM
  #976
jonathan923's Avatar
i would but its too dark outside. i will take some pics up tomorrow
Old Nov 7, 2011 | 10:25 PM
  #977
BLAZIN07SS's Avatar
I'm too JDM for you
fkn lol you guys are going to laugh
Old Nov 7, 2011 | 10:34 PM
  #978
lmao. mayybeee.....lol
Old Nov 7, 2011 | 10:36 PM
  #979
mexi_loco's Avatar
josh, what are you giggling in your corner about?
Old Nov 7, 2011 | 10:37 PM
  #980
BLAZIN07SS's Avatar
I'm too JDM for you
jon's pcv setup
Old Nov 7, 2011 | 10:38 PM
  #981
mexi_loco's Avatar
the way you make seem, it's like he's going to post pics of a fat chick sucking pressure through the pcv nipple...
Old Nov 7, 2011 | 10:48 PM
  #982
oh man what a great idea but its probably worse than that haha
Old Nov 7, 2011 | 10:56 PM
  #983
slvr 04 rl's Avatar
hahha now i really want to see this.
Old Nov 7, 2011 | 11:00 PM
  #984
BLAZIN07SS's Avatar
I'm too JDM for you
funny part is that his car burns no oil and it doesn't even have a pcv valve
Old Nov 8, 2011 | 12:27 AM
  #985
EXsoccer1921's Avatar
on my old 3076 setup the can and filter got clogged. so i took off the can, cut the top off a dr pepper can and just had the hose empty into it. got me back home on base and no dirty engine
Old Nov 8, 2011 | 04:08 AM
  #986
BlkWdoSS's Avatar
so a nipple will be added to your intake? what if you dont have an intake? lol
l8r,
PD
Old Nov 8, 2011 | 04:10 AM
  #987
i already have one on my zzp intake. its just plugged right now. the way i picked it up from them was with a tube going from the valvecover to the intake, and the breather filter on the valvecover
Old Nov 8, 2011 | 06:42 AM
  #988
05Slowline's Avatar
lol i just have the back of the valve cover going to the ground right now
Old Nov 8, 2011 | 08:28 AM
  #989
slvr 04 rl's Avatar
^^^same here with a hose to the ground, and i had the same looking stuff exsoccer had on his oil cap and thought it was just condinsation. but i lifted the head i think cause i kept loosing coolant
Old Nov 8, 2011 | 03:37 PM
  #990
yeah i ran it to the ground on the old setup after i just gave up haha
Old Nov 8, 2011 | 04:29 PM
  #991
Ryan@zzp's Avatar
The LSJ crank case ventilation is horrible. Once you turn the boost up if you are only using the nipple on the back of the cover you will start blowing your dipstick out. If you have a powder coated valve cover it gets even worse.
Old Nov 8, 2011 | 04:36 PM
  #992
yeah cleared my out didn't you? i think i remember you explaining what happened when theyre powedercoated
Old Nov 8, 2011 | 04:47 PM
  #993
MTE's Avatar
MTE
Wow 40 pages of fail Lsj's, lol JK.....
Old Nov 8, 2011 | 06:24 PM
  #994
thread revived.
ss/sc turbo swap cobalt - YouTube
Old Nov 9, 2011 | 06:04 AM
  #995
BlkWdoSS's Avatar
what happens to crankcase ventilation when they are powdercoated?
l8r,
PD
Old Nov 9, 2011 | 08:36 AM
  #996
BLAZIN07SS's Avatar
I'm too JDM for you
there is plastic in the lsj valve cover that melts and blocks the port. mine doesn't have any plastic though i removed it
Old Nov 9, 2011 | 08:40 AM
  #997
slvr 04 rl's Avatar
you removed the stock nipple right? also, what about the baffle inside the valve cover? should that also be removed?
Old Nov 9, 2011 | 08:54 AM
  #998
BLAZIN07SS's Avatar
I'm too JDM for you
yep i removed the stock nipple and welded a -10an fitting. i also removed the metal shield over the cam and took out all the plastic, then tack welded the shield back on
Old Nov 11, 2011 | 05:06 PM
  #999
Ok guys heres my TOP SECRET Oil breather set up. Burns no oil and so far it has proven to be affective and cheap. no issues yet
and thats as she sits with the blown tranny waiting for the new tranny to be installed and some upgrades coming soon!
Staged axels
brembo brakes
80s
Tune
Old Nov 11, 2011 | 05:34 PM
  #1000
throw in the zzp stage 2 cams, race gas, and ramp it up to 30psi and see what happens. hahah
thats basically how i had my old "breather" setup on the 3076. only difference is my dump tube was coming off the rear nipple and dumping under the car
