Official Turbo LSJ thread!!!
Old May 15, 2012 | 02:58 AM
  #2226
BlkWdoSS's Avatar
Originally Posted by slickss24
car is finally fixed!!! after taking it to get tuned for the new turbo he was making tons of changes to the fuel system to lean it out but it wasnt working so we started checking every sensor after disconnecting the map sensor i cut my finger on the bottom of the intake mani and reached under to see what was sharp and turns out my manifold cracked the whole bottom weld accross the manifold this is the 4th time this mani has crack all in dif places. so i got my buddy who works for a fab shop to weld it tonight and what do u know the car runs like a champ!! the tune is still very rich but atleast its boosting right now and not cutting out at 8psi
that sux, what mani are you running?
Old May 15, 2012 | 06:51 AM
  #2227
05Slowline's Avatar
Originally Posted by Chevycobaltss3
Lnf sc?
Originally Posted by jonnymerk
got it so in a nutshell earlier spool up?
earlier spool up while maintaining power level of a bigger wheel
hahn i would guess
Old May 15, 2012 | 09:19 AM
  #2228
brideout_8's Avatar
I am getting ready to install my fuel return line from ottp. I had a couple questions before I started.
1. I know how to connect the reg and run the lines to the tank. My fear/question is how much of a hassle is it to replace the pump and get it to fit?
2. I read at idle you should be running around 51psi. That is from the how to. Is this correct? Running 80s with the DW200 pump.
3. Will I need a tune to be able to drive to and from work. (Already have a tune allowing me to drive it) Like 5 miles. No boosting just getting around. I have a dyno setup for friday.
Old May 15, 2012 | 09:37 AM
  #2229
BLAZIN07SS's Avatar
I'm too JDM for you
51psi is a little on the higher side but you can do it no problem. car should drive around fine. the pump isn't hard at all. you just have to dremel off some little tabs to let the pump sit correctly
Old May 15, 2012 | 09:57 AM
  #2230
MP Cobalt's Avatar
the turbos that come with the zzp kit are ball bearing right? i have a 256et and inbetween shifts it like takes a little bit for the turbo to spool back up. is this normal or should i check something?
Old May 15, 2012 | 11:03 AM
  #2231
USMCFieldMP's Avatar
Rattlesnake Race Shop
No. It's Journal Bearing. When you shift... your BOV dumps all the pressure/air out of your piping... so it takes a little bit of time to re-pressurize the system. The way to beat that is to NLS.
Old May 15, 2012 | 05:04 PM
  #2232
MP Cobalt's Avatar
Damn there journal bearing ehh FTP I need to find a ball bearing that would help a little bit and its a big delay. Or would a 50/50 bov help?
Old May 15, 2012 | 05:34 PM
  #2233
05Slowline's Avatar
i don't have an issue like that where its ridiculous, mine builds up almost right away after shifting i have the 252et though..
bb/jb isn't a maker or breaker imo lol i love mine.
Old May 15, 2012 | 06:23 PM
  #2234
BLAZIN07SS's Avatar
I'm too JDM for you
My s256 has practically no delay in between shifts.
Old May 15, 2012 | 10:22 PM
  #2235
MP Cobalt's Avatar
so there might be something wrong? last thing i wanna hear
Old May 15, 2012 | 10:56 PM
  #2236
05Slowline's Avatar
what bov
Old May 15, 2012 | 10:58 PM
  #2237
MP Cobalt's Avatar
tial what ever model comes with the full swap
Old May 15, 2012 | 11:05 PM
  #2238
05Slowline's Avatar
sounds like tuning maybe, hard to say without actually being in the car seeing what is happening. mine doesn't hold boost through the shift but it's a split second before it's back.
Old May 15, 2012 | 11:18 PM
  #2239
MP Cobalt's Avatar
idk how a tune could change how the turbo spools back up though
Old May 15, 2012 | 11:30 PM
  #2240
05Slowline's Avatar
lol. like i said theres way too many factors that can affect it, tune being one. timing, afr's, etc all play into the turbos actions to an extent. I wonder what role dfco would play into it out of curiosity. I don't claim to know everything or be a tuner by a long shot but I have a handle on how most things work with it lol.
Old May 16, 2012 | 02:40 AM
  #2241
BlkWdoSS's Avatar
the extended tip spools up similarly to a ball bearing unit. there are tons of factors that could cause a slow spool back up, but really
where are you shifting at?
are you WOT?
are you NLS?
how long is the delay?
have you boost leak tested?
Is your BOV opening completely?
Is your WG opening completely?
are either of these closing completely?
what boost controller?
how much boost?
where do you normally get full spool?
what tune?
Old May 16, 2012 | 08:43 AM
  #2242
jonathan923's Avatar
the tune can deff make a difference in a turbo spooling time, the leaner down low the faster you spool up. if your afrs are 10.0 in lower rpms at wot then you have a much slower spool time.
Old May 16, 2012 | 12:13 PM
  #2243
MP Cobalt's Avatar
ugh this is going to be a headache lol I'll try to get a video of what its doing. I shift at like 6500 to 7000rpm, and i can't tell if the bov or wastegate are opening fully or closing lol its hard to tell while driving the tune is a tune zzp gave me and everything and my buddy finished up so tweaks with added boost on the dyno to get rid of slight knock and adding and cutting fuel and timing and sorts
Old May 16, 2012 | 12:24 PM
  #2244
I think having a zzp tune might be one of the problems. Maybe you should get it fully checked by someone that tunes cobalts and works with hp tuners man
Old May 16, 2012 | 01:01 PM
  #2245
rivaladore's Avatar
Mp cobalt you live in pa go to BYT!
Old May 16, 2012 | 02:02 PM
  #2246
05Slowline's Avatar
^ lol
Old May 16, 2012 | 02:05 PM
  #2247
BLAZIN07SS's Avatar
I'm too JDM for you
maybe you shift like a grandma?
Old May 16, 2012 | 02:06 PM
  #2248
MP Cobalt's Avatar
BYT? no idea where ther at or anything, and Josh i'm shifting like ricky bobby
Old May 17, 2012 | 12:52 AM
  #2249
rivaladore's Avatar
Backyardturbo.....located in east stroudsburg, pa if you want a street tune. Or if you want to be dyno tuned he prefers to go to a place in Pottstown, pa I think. Backyard Turbo or check out his Facebook page. He's pretty busy so you might have to wait a couple of weeks for an appointment.
Old May 17, 2012 | 01:04 AM
  #2250
If you shifted like Ricky Bobby... you wouldn't lose boost at all in-between shifts.
Even when I was on the journal bearing PTE SC5031E, I didn't have slow spool problems after shifting.
More than likely, your problem is a combination of slow shifting and using a base tune. Probably a little bit of shifting too soon, as well. Shifting at 6500 is for fgts. Shifting before 7000 is also for fgts. 7000 to 7200 is optimal. I shifted at 7400 on a stock long block for over 60,000 miles. Also, the tune ZZP provides is a base tune. Too many people get into the thinking that this should be a top notch tune. It's not. It's a base tune. It's designed to be safe and to get the car running so that it can make its way to a dyno for proper tuning.
