Official Turbo LSJ thread!!!
#2126
listen to my video that i posted not too far back. its the flutter sound that happens when you let off the throttle. Its air that is left in your chargepiping that your BOV didn't/couldn't vent so the air is slamming back against the compressor wheel of the turbo.
#2127
that sounds like a bad thing. so basically i'll have to take my housing off and drill and tap a fitting in to the vaccum line and tap it to another? It just started last night never noticed it before only notice at small amounts of boost and doesn't do it all the time
#2129
oh ok so first off. i have a soft spring in my bov now because it stays open at idle. and second i have a tial bov. hmmmm so i wonder if thats coming from my turbo or wastegate?
#2131
just scanned through a the past few pages. My greddy blowoff flutters all the time lol. I get a little bit of that crisp sound at the end if I'm full boost. Mine has an adjustable spring but I swear no matter if I adjust it harder or softer I never noticed a difference.
#2132
#2135
Everyone calm down! Chances are for most of you that you dont have compressor surge. Turbos make different noises at times. wastegates and BOVs will "flutter" as pressure fluctuates. In ideal situations, the BOV and WG will make a crisp sound everytime. BOV goes PASHA, wastegate goes WHOOSH, compressor surge goes CHE-CHE-CHE post videos of your cars like FrossB did and Ill tell you what is making what noise.
#2138
well actually i should ellaborate lol i opened up my BOV and found two springs. One larger one and one smaller one. the smaller one had considerably less tension and was about half the height. For ***** and gigs i took the small spring out and left the larger one in. Not one bit of surge and it still holds 26psi strong.
#2141
Just installed the tial q I bought from zzp. Is it really supposed to hang open this much at idle? I heard people say it hangs open a little, but this doesn't seem right. It's wet outside so i couldn't really get on it, but seems to be holding boost fine. I'm just worried about something getting sucked in the motor when I'm idling.
#2142
If your maf is after the BOV you will be fine. What are the chances something is going to end up in that space? You should be good.
I should see if mine is open at idle. Mine would be more of a worry when its wet out because its near the ground. Oh well, nothing happened yet.
I am finally getting good charge pipes made for a decent price! Steel under the car and goes to a slight oval where it goes through the oil pan passage then aluminum after the IC. All custom and for around 250$. Not bad since guys around here wanted to charge me double and more.
#2143
#2145
#2147
if you really really were that worried about it i suppose you could make a "shield" around where the diaphragm opens similar to a turbo screen material.
#2148
Yea apparently its ok. I'm just glad there is absolutely no flutter and the response of the tial is great. I might fab up some mesh around it for peace if mind. Do you think cutting up an injen hydrosheild would be a good idea. Never seen one in person don't know if it'll flow enough air when the bov releases air
#2150
