Official TVS Thread!!!
Old May 5, 2013 | 11:48 PM
  #5751
advise's Avatar
Looks like i have a defective exhaust cam
Just put in the stocker no leak
Old May 6, 2013 | 04:33 AM
  #5752
wRcKLes's Avatar
My tvs just showed up at my door step yesterday! Anyone got a 2.8 pully for it they want to get rid of?
Old May 6, 2013 | 07:44 AM
  #5753
Omnigear's Avatar
Originally Posted by Melon
How long does a 3 gallon tank last u guys?
depends on how hard you are on boost.
5gal can last me 3days to a week.
Old May 6, 2013 | 08:00 AM
  #5754
armcclure's Avatar
??? How?
FYI stock cams exhaust has 363 in the middle.
Zzp cams exh is the one with the hex.
Old May 6, 2013 | 08:23 AM
  #5755
Good stuff! Fred tuning it?
Old May 6, 2013 | 10:55 AM
  #5756
Melon's Avatar
I really don't get into boost often. I live across street from where I work so I walk mostly to work. Then school is only like 5 miles away tops. Never really get the chance. I try and enjoy when traffic allows tho or when I am goin to my buddy's and get to hope on freeway
Old May 6, 2013 | 11:17 AM
  #5757
advise's Avatar
??? How?
Flat lobe has some lift in it causing a leaky valve on my #4
Old May 6, 2013 | 11:53 AM
  #5758
armcclure's Avatar
That's just unheard of. Hopefully they'll take care of it no problem.
Old May 6, 2013 | 12:11 PM
  #5759
advise's Avatar
Found it odd myself....
Changed the exhaust to the stock cams, no issues
Old May 6, 2013 | 12:18 PM
  #5760
mrbelvedere's Avatar
did you check out the roller and a excessively warn guide will cause that also
Old May 6, 2013 | 12:38 PM
  #5761
advise's Avatar
All the rollers look fine, guides only have 7k no wear on the supertech valves
Old May 6, 2013 | 08:46 PM
  #5762
advise's Avatar
Base circles are .020 larger then the stock cams.... anyone have a set of comps to measure up
Old May 6, 2013 | 10:38 PM
  #5763
wRcKLes's Avatar
He will be as soon as I get my hands on a 2.8 pully for this. Where did you get yours from?
Old May 6, 2013 | 11:32 PM
  #5764
Found it on here. Damn near brand new. Fred tuned it.
Old May 6, 2013 | 11:55 PM
  #5765
wRcKLes's Avatar
Good stuff, I may just buy it new
Old May 12, 2013 | 01:31 PM
  #5766
Verbatim's Avatar
So I got about 30K miles on my tvs spinning the 3.14" pulley and the needle bearings have started to make a lot of noise; YAY.
I know ZZP does the rebuild for around 200$, but has anyone used Stiegemeier for rebuilding work?
They are local for me and it would save on shipping costs and possible turnaround time.
I'm trying to track down everything I need in a rush and do some figuring; But if I'm not able to port and polish the head(just springs and studs), should I just stick with the 3.14" pulley until I can get the head taken car of or will I be safe throwing the 2.7 or 2.6 pulley I have?
Old May 12, 2013 | 01:59 PM
  #5767
100% METH's Avatar
Hello my cobalt is slower than yours :p
Call them and find out
Zzp is quick and easy
Old May 12, 2013 | 02:06 PM
  #5768
Verbatim's Avatar
lol, oh herro;
I will be tomorrow.
**** happens, just gotta deal with it then move the problem down to the lower end
Old May 12, 2013 | 04:33 PM
  #5769
Powell Race Parts's Avatar
Steig is good I have used them. Dont blame the TVS until you check the timing chain guides. I made that mistake.Was not the needle bearings when I thought it was. lol
Old May 12, 2013 | 04:42 PM
  #5770
100% METH's Avatar
This seems to be plaguing a few people lately.
Old May 12, 2013 | 04:47 PM
  #5771
Verbatim's Avatar
I wish it was the guides actually; cause I can get the timing kit thru work and put it on my account thru work. but when I used my stethoscope at the shop on saturday, all the noise if from the blower.
And since all my tools are at the shop, I cant get started on it till monday...Only tools I have at the house are standard sockets and wrenches for working on the nova and chevelle.
And since my current boss is a gigantic ***** about me working on my car(even off the clock), I cant pull the motor at the shop(lift, all my tools located right next to the lift, ect.) But he can work on his/buddies **** whenever he wants...
So I will be doing all of it at the house with jackstands and my less than adequate compressor
Hopefully Stiegemeier will be able to work on it; I just realized that I will be in st. charles tuesday for my last automotive diagnostic class of the year...almost perfect timing for me to deal with all this.
Old May 12, 2013 | 05:39 PM
  #5772
If I am right, then I reserve the right to be a bigger ***** than your boss about it... thats because I did all the same diagnostics you did. But thats not enough.
So.... when you take the TVS apart do the front nose case first, inspect, and if the needles look fine and the grease on the rotor shafts is nice and blue, put it back together and move to the front of the motor lol.
As far as timing chain guides etc, its about that time in the life of these motors, and their age, and the way folks rev the crap out of them, that the front end of the motors need care and attention.
Old May 12, 2013 | 06:27 PM
  #5773
Verbatim's Avatar
Oh, I forgot to post a little bit of info on here; the noise is the loudest on the back of the blower(TB side) on the rotor closest to the head.
The engine has 74505 it
other than the tvs and little crap, it is all stock
Never have gone over 7K,
Just for ***** and giggles, when I get to work, Ill pull the belt off and fire it up for a couple seconds; of course, pulleyboys tool is at work...
Every now and then when its below 40degrees-ish out, when the car has been sitting I do get the belt chirp like sound from the timing set(took me a while to find that little bastard of a noise)
If I do decide to pull apart the blower myself, do I need to replace any gaskets or orings when cracking it open?
Ive never gotten into a blower before, doesn't scare me but knowledge is good before I jump into it
And if your right about the timing set, I will immediately order a set of the f23 rotated mounts that I have been neglecting to order for a couple months
Old May 12, 2013 | 06:59 PM
  #5774
lol@ rotated mounts. NP.
the front nose has no gasket iirc. O rings? I like to use hylomar on it. I never did get torque specs on the bolts, ZZP say tight.
getting the needle cases out is very difficult.
Old May 12, 2013 | 07:28 PM
  #5775
armcclure's Avatar
Are they open back like the m62?
