Official TVS Thread!!!
Old Sep 12, 2013 | 11:47 AM
  #6801
InfraRedline's Avatar
Originally Posted by ThexGovenor
Staying TVS taylor?
Originally Posted by JapEatr
better be or taylor owes me first born
I better not have kids...lol
Originally Posted by shroogis
Just throwing this out there...my old LSJ ran around 185psi each cylinder and my LNF hits 155psi. Same tester used on both.
That's odd. The 3 running LSJ's we have tested and the LNF we tested were all within 10psi of each other. Even Blue's car when it got tight when he was down here on 1,000 mile diamond pistons and total seal rings made near 160psi on the 2 good cylinders and 135-140 on the cylinders thats had some scoring on the upper walls.
I won't think too much into it as its never skipped a beat and is consistent with other healthy motors. Although she turned 70k miles last night, almost brought a tear to my eye.
Old Sep 12, 2013 | 12:13 PM
  #6802
Bluelightning's Avatar
Got Bewst?
We raced with my stock motor that had 210 compression across the board and we were dead nuts even. Your motor is solid.
Old Sep 12, 2013 | 12:14 PM
  #6803
SSfamilywagon's Avatar
Oh ok I get you now. The second inline pump becomes the feed pump. Yeah I would definitely like to see pics to better understand
Old Sep 12, 2013 | 01:10 PM
  #6804
Killa SS's Avatar
Does powell have an surge tank set up for the LSJs? Sorry if I missed the post that he does. Not on here all that much
Old Sep 12, 2013 | 01:24 PM
  #6805
JapEatr's Avatar
South Central *********
He custom built me one
Old Sep 12, 2013 | 02:11 PM
  #6806
ThexGovenor's Avatar
Dont play coy with me. PM me your plans, I promise not to tell.
Old Sep 12, 2013 | 02:22 PM
  #6807
574's Avatar
574
Old Sep 12, 2013 | 05:47 PM
  #6808
I will make a thread with all my plans soon lol still in the "planning" process. Lots of new things happening.
Old Sep 12, 2013 | 05:51 PM
  #6809
Got Bewst?
The fastest hybrid Prius you've ever seen.
Said too much......
Old Sep 12, 2013 | 05:59 PM
  #6810
You've soiled my secret! SOILED IT!
Old Sep 12, 2013 | 06:33 PM
  #6811
574's Avatar
574
https://i.imgur.com/tHw0b.gif
Old Sep 12, 2013 | 06:36 PM
  #6812
You've spoiled my secret! SPOILED IT!
Fixed
Sounds good man. Can't wait to see whats in store!
Old Sep 16, 2013 | 04:04 PM
  #6813
The soiled thing was actually a spongebob reference Classy, I know.
4 days until I leave for the track with a ton of friends for the weekend! The car tried to keep me from going the other night. Did a 1-2 shift and it died. Was popping fuel pump fuses and relays so I trailered it to my shop and dropped the tank and found the heat shrink on my spliced wires had cracked and were arcing to the metal guide dowel in the canister...scary thought lol. Re-insulated them and drilled some holes in the canister and disconnected my factory regulator finally. Runs well again!
Also, do not drill holes in the sides of the canister, even towards the bottom. I did that, along with some on the bottom, and now if the car is under 3/8 tank it will go lean a few seconds after you get on it. Another thing to fix this winter. Looks like I'll be going down the track with a full tank.
Old Sep 16, 2013 | 04:53 PM
  #6814
JapEatr's Avatar
surge tank will fix that too
Old Sep 16, 2013 | 05:00 PM
  #6815
Killa SS's Avatar
Whats powell use for a tank and pump? And lines? Im thinking dual pumps for the hp I wanna put down on E85. How much did he charge you? That website really needs to get up and running with prices and links and ****.
Old Sep 16, 2013 | 05:03 PM
  #6816
It never did in any gear but 4th before I gutted the canister like a wild boar I shouldn't need a surge tank next year though. It interests me though, and I'm all for overbuilding.
Old Sep 16, 2013 | 05:34 PM
  #6817
JapEatr's Avatar
custom built surge tank, in line Bosch 044 pump, custom lines
Old Sep 18, 2013 | 07:03 PM
  #6818
So im going to the drag strip for the first time ever in my life friday. Will be running on street tires. Due to thexgovenor driving mod im guessing my best time will be 15s Any tips for me?
Old Sep 18, 2013 | 07:07 PM
  #6819
Powell Race Parts's Avatar
Dont go.
Old Sep 18, 2013 | 07:14 PM
  #6820
Dont go.
whys that? First time ive had one close (~10 min)
Old Sep 19, 2013 | 02:02 AM
  #6821
06cobalt racer's Avatar
do not try to leave the line hard. try and take it easy the first couple times so u get used to it
Old Sep 19, 2013 | 07:29 AM
  #6822
Thanks man. I had heard to launch at like ~2300 rpms but I think ill just ease into it.
Old Sep 19, 2013 | 07:51 AM
  #6823
robertmichaels's Avatar
Just figured I would post this here too...made 363whp and like the post states we are still tuning, having an issue with MAF/MAP correlation causing it to go into limp mode
https://www.cobaltss.net/forums/dyno...363whp-302483/
Old Sep 19, 2013 | 08:13 AM
  #6824
574's Avatar
574
Burn that clutch
Old Sep 19, 2013 | 10:16 AM
  #6825
Leave the line easy and shift to 2nd quickly but don't mash the gas right away. Just like on the street. You'll easily run somewhere in the 13's without even trying. I did a street tire run a couple years ago the first time out on the TVS and 2.9 just for ***** and was just playing around and ran a 13.5. Ran a 13.6 stock blower and a 13.4 in my friend's M62 car though
Fitted my slicks last night and tested em on the street She's ready for the track this weekend! I have 2 days of racing to accomplish what I want to do. I have a trailer if need be...
