Official TVS Thread!!!
Old Jun 4, 2012 | 06:00 PM
  #751
100% METH's Avatar
Originally Posted by mrbelvedere
after a bigger fuel pump i can see that
add some meff
Old Jun 4, 2012 | 06:27 PM
  #752
thewizard's Avatar
Got any dyno numbers or track times?
Not recently. It was into the 14s NA, and the 13s with a somewhat stock M62 setup, but I think if I were to run it now it would surely grenade.
Old Jun 4, 2012 | 07:18 PM
  #753
TStone's Avatar
Originally Posted by 100% METH
add some meff
This is the answer to everything!
Old Jun 4, 2012 | 11:52 PM
  #754
IonNinja's Avatar
i'm curious what kinda power that makes on a stock L61
Old Jun 5, 2012 | 12:04 AM
  #755
100% METH's Avatar
can't afford 80s? - meth!
dont want to tune for injectors - meth!
tired of knock? - meth!
dgaf?! - METH!
any questions? - 100% METH
Old Jun 5, 2012 | 12:10 AM
  #756
Bluelightning's Avatar
Got Bewst?
Lol +1 to all of the above
Old Jun 5, 2012 | 12:29 AM
  #757
thewizard's Avatar
Methanol does make wonders. Speaking of that, anyone have a 10gph nozzle available?
As far as power on a stock L61 goes, I will hook my GTech up to see what it comes up with.
Old Jun 5, 2012 | 01:59 AM
  #758
100% METH's Avatar
Call Rodney at ais, he will sort you out
Old Jun 5, 2012 | 03:16 AM
  #759
zrated89's Avatar
i has a 10 gph as well
Old Jun 5, 2012 | 06:29 AM
  #760
thewizard's Avatar
Thanks for the tip on AIS, I'll check into that. I've dealt with Snow and Devils Own in the past, but like to diversify to see what the market holds.
zrated, are you saying you are using that size, or do you have one for sale?
Also, I assume you all are running your nozzles pre-blower? I wish I didn't have to pull my spacer so I could keep my second nozzle in there. I tried to find a smaller tensioner pulley so I could do that, but havn't had any luck yet.
Old Jun 5, 2012 | 10:56 AM
  #761
Got Bewst?
Pre blower ftw
Old Jun 5, 2012 | 11:21 AM
  #762
TStone's Avatar
dgaf?! - METH!
Ahhaha BINGO!
Old Jun 5, 2012 | 12:41 PM
  #763
ebristol's Avatar
dgaf?! - METH!
Old Jun 5, 2012 | 12:43 PM
  #764
RooTBeeR's Avatar
Bunch of meth heads!
Old Jun 5, 2012 | 12:56 PM
  #765
zrated89's Avatar
i have a 10 and a 14 that i will sell since my car is going on E85 when shes back on the road. I need to pick up a 3gph nozzle as i will be running straight water on E to help with the intake temps
Old Jun 5, 2012 | 12:59 PM
  #766
freakta's Avatar
how high were your intake temps getting?
Old Jun 5, 2012 | 01:02 PM
  #767
zrated89's Avatar
on the 2.6 down the 1320 when i lost the motor i seen 164 at the end of the traps. But my meth also wasnt working correctly and since i drove her to the track she was heat soaked. I started at the tree with temps around 130 iat2 so they only climbed about 30 degrees down the 1/4 mile
Old Jun 5, 2012 | 01:03 PM
  #768
freakta's Avatar
thats not as bad as i expected
  #769
zrated89's Avatar
on the street though they never go past 100. 120 at most tuning the car with back to back pulls. At the track though u cant keep air flowing accross the heat exchanger so u soak a lot more. Not to mention humidity and high DA that day didnt help. The best time to run my car is when the track first opens or in the fall before it closes no sense in running when its 100+ degrees out
Old Jun 5, 2012 | 03:09 PM
  #770
advise's Avatar
I had my meth kit with just water and has a 5* drop in my iat
Not worth it
even used a 5 gph same thing
Old Jun 5, 2012 | 04:02 PM
  #771
100% METH's Avatar
should of stepped up the nozzle
a 5gph does nothing when your @ 24-25 psi.
On 50/50, you wont even see a 3% change in fuel with the pulley your using.
Old Jun 5, 2012 | 06:37 PM
  #772
euthanasia's Avatar
I agree with boost that high you can run a 10gph.
What h/e are you running?
Old Jun 5, 2012 | 09:04 PM
  #773
zrated89's Avatar
zzp stage 3
Old Jun 6, 2012 | 01:20 PM
  #774
microgab's Avatar
Alright so for a DD with a TVS 2.8/2.9, with all cooling mods (phenolic spacer, dual pass, heat exchanger, 3" downpipe) and running on E85...would meth help with a stock motor/head? I'm currently building my DD and I want to get everything before I tune
Old Jun 6, 2012 | 01:46 PM
  #775
thewizard's Avatar
PM sent
