Official TVS Thread!!!
Old Jul 18, 2014 | 03:12 PM
  #9001
ThexGovenor's Avatar
Originally Posted by noorj
nolan are those 1200's ev6 or ev1?
The same harness the 80#s use. EV1. harnesses can be bought for about 20 from zzp though if you have EV6. The injectors are fantastic. Just wont be needed if I switch back a m62 on pump.
Old Jul 18, 2014 | 03:31 PM
  #9002
RooTBeeR's Avatar
Originally Posted by Area47
It is. Also need to grind out the divided housing to run the internal gate. meh.
60lb min for the 7 blade, 54lb min for the 8 blade.
I have the 7 blade.
Internal gate? I like.
Ok, enough Turboh Talk in the TVS thread.
Old Jul 19, 2014 | 10:04 AM
  #9003
Tjolley's Avatar
Hopefully this weekend we can finally turn Steves car up. After he relearns how to drive it!! Lol. The stainless line going straight to the TOB seemed to really improve the clutch pedal feel way more than I thought. Lol
Last night he finally turned up the timing a lil on out way back from the train station. Gona crank up the base pressure to 60 psi since the car just about has the injectors maxed.
saw 75% at 6000 rpm. More then likely explains the breaking up above 8000 rpm.
Old Jul 19, 2014 | 10:09 AM
  #9004
InfraRedline's Avatar
Turn that biotch up. Quit pissing the EGT's off with low timing, and turn the base pressure up, make sure you've got the fueling, make sure you've got clean spark and there will be no reason for it to break up.
Old Jul 19, 2014 | 10:12 AM
  #9005
Tjolley's Avatar
i put a aem 340 pump in it wen i did the fuel system. As long as the car is above 1/4 tank there's no problem.
I'll have a fixed for that shortly
Old Jul 19, 2014 | 11:17 AM
  #9006
Yeah you should have everything needed for the task.
I have fueling even when the gas light is on But I'm using a 2nd pump to keep the canister full.
Old Jul 19, 2014 | 11:40 AM
  #9007
Tjolley's Avatar
U have a stock pump floating around the back of the tank??
Old Jul 19, 2014 | 02:33 PM
  #9008
100% METH's Avatar
So fun driving it around today
Haven't driven it in a long time
Old Jul 19, 2014 | 03:42 PM
  #9009
armcclure's Avatar
More or less... Yeah
Old Jul 21, 2014 | 09:55 AM
  #9010
Yeah just my old Walbro 255 in the rear of the tank feeding the canister where the 450 sits.
Old Jul 21, 2014 | 05:39 PM
  #9011
IonNinja's Avatar
Originally Posted by Hockeyman
March of 2013 was the last time the front cover was off. Anything more than 50% throttle it looks like seafoam smoke with a blue oil tint. Haven't done any tests yet.
You sure it's not just valve seals?
Old Jul 25, 2014 | 10:28 AM
  #9012
Sinnah's Avatar
Hey guys. I have sold my TVS. it was sad letting her go. But if you guys haven't seen my for sale thread I have a Return style for sale for anyone wanting more fuel for e85. PM me.
Old Jul 25, 2014 | 10:47 AM
  #9013
Hockeyman's Avatar
They are Viton and only 2yrs old
Old Jul 26, 2014 | 02:22 PM
  #9014
100% METH's Avatar
PTE 5431 - 26-27 PSI
That SRT4 dynoed 409whp; Trevor knows the torque
Trevor won the dig, but had complete loss of traction in third losing the roll. The stage 3 cams must be kept above 5000 to keep the car alive.
Old Jul 26, 2014 | 03:22 PM
  #9015
RooTBeeR's Avatar
put the window up next time lol
Old Jul 26, 2014 | 04:11 PM
  #9016
100% METH's Avatar
Trevor said it was 90+ degrees at 1 am
Old Jul 26, 2014 | 04:44 PM
  #9017
Tjolley's Avatar
Yea it was hot as hell last night.
Old Jul 26, 2014 | 07:47 PM
  #9018
SSfamilywagon's Avatar
Sounds like us. Even at night we stay in the 90's. Hard to keep cool lol.
Good runs guys
Old Jul 26, 2014 | 07:52 PM
  #9019
JapEatr's Avatar
South Central *********
Welcome to tx
Old Jul 31, 2014 | 05:00 AM
  #9020
Tjolley's Avatar
So tonight was the first night of spraying Steves car. Went very very well like I expected. We r running the car very rich. it seems to really respond to a 11.0 afr over a leaner 12.0 or 12.5.
Started out with only 18° in it to make sure everything was functioning properly And the fuel didn't get wild.
Tossed the 50 shot jets in and did a few pulls. Car felt great afr seem to not flinch much I thought it was going a little rich but actually didn't move..
Stuck 23° in it and the car really responded to it. Didn't hear the engine change much if any but the car definitely accelerated way faster.
Gona let it cool over night and I'll pull the plugs in the morning to see how things r looking before tossing the 70 jets in.
Old Jul 31, 2014 | 09:10 AM
  #9021
100% METH's Avatar
Damnit.... I can't get up there for at least another week!!!
Did you film some pulls with the GOPRO?
Old Jul 31, 2014 | 09:25 AM
  #9022
mrbelvedere's Avatar
its pointless to pull the plugs after it has set over night the plug reading wont be close to accurate you need to kill the engine at top of pull then pull plugs
Old Jul 31, 2014 | 10:47 AM
  #9023
It's also difficult to read the color of the plugs when running E85 since they always just look mostly white, with a tiny bit of gray, but you can tell if you are pushing the ignition side of things too hard by looking at the plugs, even if you aren't seeing any knock. But you probably won't be able to tell much after just a few pulls.
Also, my car always liked a richer AFR too, but that was with no bottle. I always ran 11.0-11.3 for the most part.
Old Jul 31, 2014 | 11:04 AM
  #9024
mine always look white no grey at all afr is 11.3 but when it cools off its 12.3 lol
Old Jul 31, 2014 | 11:24 AM
  #9025
By gray I mean ever so slightly gray, you'll see if you look very closely. Depending how long you run your plugs.
It's just a little bit of piston material Jk lol
