Official TVS Thread!!!
Old Sep 30, 2014 | 10:44 PM
  #9226
Bluelightning's Avatar
Got Bewst?
Originally Posted by mezzanno
Paul, anthony and myself are building the most badass cooling system for a supercharged cobalt, at least that I know of. It wont be cheap but iat2s will be below ambient.
Already been done by Flatgod
Old Sep 30, 2014 | 11:23 PM
  #9227
100% METH's Avatar
Originally Posted by TStone
MrB is the only one even pushing the TVS now a days....
What am I doing ?
You're leaving a few people out sir
There's Richie, Trevor, Anthony, Paul just off the top of my head :p
Old Oct 1, 2014 | 12:02 AM
  #9228
Tjolley's Avatar
Only thing ive done so far is break ****. Lol
Not for long though
Old Oct 1, 2014 | 12:10 AM
  #9229
Anyone have any tips or advice for me? Im going to be purchasing an Eaton m112. My friend and i are planning fab up a mounting plate, inlet and still make the bypass work somehow. This blower is almost twice the size of the m62 and considerably larger than the tvs. Im kind of worried about that, kinda not. Because it will take more power to turn it probably but then again it will make more power and safer power on the same boost. Thoughts? Would i blow?
Old Oct 1, 2014 | 07:05 AM
  #9230
mrbelvedere's Avatar
I don't know if running a 112 would be worth it
Old Oct 1, 2014 | 07:07 AM
  #9231
Staged07SS's Avatar
Administrator
Administrator
x2.
A bigger blower is not the answer.
Old Oct 1, 2014 | 08:16 AM
  #9232
100% METH's Avatar
That particular "bigger blower" is not the answer
*Note* Conditions may vary
3.1 Pulley - m62 (assuming full catless 3" exhaust)
- 13629 s/c RPM @ 6500 rpm w/ OEM Crank Pulley
- 1.8 PR 11 psi / 1.9 PR 13 PSI (Roughly 825 m3/hr (485 CFM)
- 54% Efficiency at redline
3.1 pulley - M112 (assuming you can get it down to 11-13 psi using a 3.1 pulley - Notgonnahappen.com)
- 1.8 PR 11 psi / 1.9 PR 13 psi (1450 m3/hr = 853 CFM - This will never happen on our 2.0L at 1.8/1.9 PR - You would be over 30 psi with our engine)
- 48-45% efficiency at redline
You see the downward trend here? If the M112 already sees sub 50% at only 11-13 psi... try and plot where it would be at 25-30 PSI
The only trade off is that you'll be spinning the m112 slower (Hardly a trade off; cost you money and robs more power)
Old Oct 1, 2014 | 08:24 AM
  #9233
I also think that there is more power to be had on the m62
Old Oct 1, 2014 | 09:02 AM
  #9234
100% METH's Avatar
Definitely
The 5th gen m62 is well within our displacement limitations
If (BIG OLE IF) you can keep it PR low enough and continue revving... it's not a bad little blower.
Can't escape the blower constantly wanting to cannibalize efficiency at X P.R. vs RPM
A Eaton R900 would of been a better candidate over the m62 from the factory.
Old Oct 1, 2014 | 09:12 AM
  #9235
Tjolley's Avatar
School has started ppl lol take ur seats
Old Oct 1, 2014 | 09:20 AM
  #9236
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by 100% METH
Definitely
R900 is prob similar to my H62.
Old Oct 1, 2014 | 09:22 AM
  #9237
100% METH's Avatar
Prob not far off
It flows less at 1.9 PR and 13,600 rpm
but it's efficiency is higher
Old Oct 1, 2014 | 10:11 AM
  #9238
Josh@ottp's Avatar
That's actually not a fair comparison. At the same flow rate of 485cfm you quoted the 112 is more efficient than the m62.
Old Oct 1, 2014 | 10:20 AM
  #9239
100% METH's Avatar
Nope...
Regardless it wouldn't be a fair comparison because realistically you wouldn't see 11-13 psi out of a m112 on a LSJ
You would need to run a 5.3" pulley at 6500 to see 7971.69811 M112 S/C RPM for a near equivalent cfm
Quite the centrifugal you got there... I mean roots..
Old Oct 1, 2014 | 10:55 AM
  #9240
armcclure's Avatar
So just to push your buttons flit, why not list out that same comparison, but an m62 vs mp1900.
Old Oct 1, 2014 | 10:57 AM
  #9241
100% METH's Avatar
Give me a sec
What PSI you looking for?
Old Oct 1, 2014 | 11:09 AM
  #9242
armcclure's Avatar
Give me a sec
Just an exact replica of the post you made comparing the 62 and 112 maps, but with a 1900 and corresponding flow/scrpm/pr/etc.
Old Oct 1, 2014 | 11:10 AM
  #9243
06blackg85ss's Avatar
well initial run with the tvs this morning went better than expected. way lean above 5500rpm, but that will be fixed for the drive home. Feels pretty decent, sorta understand peoples love for these things.
But we shall see what a stock motor can do with one I guess. Gonna push thing thing for 400whp, and then i"m never touching another cobalt again lol.
Old Oct 1, 2014 | 11:12 AM
  #9244
100% METH's Avatar
lies and slander...
you'll be back
Old Oct 1, 2014 | 11:22 AM
  #9245
Josh@ottp's Avatar
Nope...
You would need to run a 9.4" pulley to 6500 to see 4,494 M112 S/C RPM for a near equivalent cfm
Your math is wrong there. Either way you would have to run an under drive ati and a large pulley. That's not my point though. The m112 will make more power and be more efficient than a m62 if you actually want to make power.
Old Oct 1, 2014 | 11:26 AM
  #9246
Josh@ottp's Avatar
I should add though that the 1320 will make more power than the 112. So unless you have lots of free time and like throwing money away I wouldn't bother with it.
Old Oct 1, 2014 | 11:47 AM
  #9247
100% METH's Avatar
(Desired Engine Rpm X Crank Pulley Diameter) / Supercharger Pulley Diameter = Supercharger RPM
(6500 X 6.5) / 9.4 = 4494.68085
(6500 X 6.5) / 3.1 = 13,629.03225
Old Oct 1, 2014 | 12:10 PM
  #9248
Josh@ottp's Avatar
You calculated the m112 off of 485 m3/hr not off of 485 cfm. Because you didn't read the graph right your answer is wrong. Now you follow me?
Old Oct 1, 2014 | 12:14 PM
  #9249
100% METH's Avatar
Why didn't you say so
one sec...
ninja edited
You're looking at 58% efficiency @ 1.9 PR 13 PSI by 7971 m112 s/c rpm
So who ever wanted the m112...
Go with a TVS
Being different is not the answer
Old Oct 1, 2014 | 12:23 PM
  #9250
100% METH's Avatar
m62
Flow - 825 m^3/hr (485.57 cfm)
PR - 1.9 (13 PSI)
SC RPM - 13,629
Eff - 56-54%
SC PULLEY - 3.1"
tvs 1900
PR - 1.9
SC RPM - 8,047
EFF - 73-71%
SC PULLEY - 5.25"
