Official TVS Thread!!!
Old Oct 2, 2014 | 01:07 PM
  #9276
mrbelvedere's Avatar
its never to late jap
Old Oct 2, 2014 | 01:51 PM
  #9277
Staged07SS's Avatar
Administrator
Administrator
x2!! Come on back to us, lol.
Old Oct 2, 2014 | 01:55 PM
  #9278
06blackg85ss's Avatar
Originally Posted by 100% METH
Was Anthony running only one pump with 55gph?
The shurflo 300 psi pumps can only provide enough pressure to about 30-34gph. You'll need to run two pumps otherwise
single pump, 3 nozzles. and pump isn't the standard shurflo, forgot the make but it's rated 55gph @250 psi
as for my car, no meth for now, just good ol e85 and some cooling magic
Old Oct 2, 2014 | 02:35 PM
  #9279
100% METH's Avatar
Anthony isn't running the AIS Shurflo pump?
When you have Advise's car on the dyno , you guys should figure out where straight water becomes the limitation, then add methanol into the mix...
Old Oct 2, 2014 | 02:55 PM
  #9280
100% METH's Avatar
Originally Posted by JapEatr
i would not have gone turbo if there was a 1900 fit
where were you in 2010ish when I had one on my car?
Old Oct 2, 2014 | 02:58 PM
  #9281
yellowsupercharged06's Avatar
Ant's car is collecting dust for a while
Old Oct 2, 2014 | 03:07 PM
  #9282
Area47's Avatar
Rent me! per hour
Our e85 that different than yours?
Trevor tested the station by him and it's 80-85% ethanol
quality of fuel, and how it is cracked as well.
Old Oct 2, 2014 | 03:27 PM
  #9283
100% METH's Avatar
I'm not saying you're wrong
But we were able to continue building power because his iat2 would peak 115 on the dyno by 7500.
Just my guess
Old Oct 2, 2014 | 03:42 PM
  #9284
JapEatr's Avatar
South Central *********
we shall see, i would go back to a blower if something stellar comes this way
Old Oct 2, 2014 | 04:21 PM
  #9285
Josh@ottp's Avatar
The 1900 will be 500+ whp capable on a LSJ. I will be running one on a LE5 automatic though.
Old Oct 2, 2014 | 05:03 PM
  #9286
SSfamilywagon's Avatar
Originally Posted by Josh@ottp
TVS 1900 is where it's at. I do like my TVS 2300 though.
This is where its at!! I wanna see one done. More so on a 2.4 or bigger
Old Oct 2, 2014 | 06:42 PM
  #9287
So no on the m112 huh lol. Damn. Idk what P.R is
Old Oct 2, 2014 | 09:15 PM
  #9288
Pr is pressure ratio. That side refers to boost pressure.
Old Oct 2, 2014 | 09:56 PM
  #9289
armcclure's Avatar
Old Oct 3, 2014 | 08:19 AM
  #9290
100% METH's Avatar
(2.4 PR) 20.5 PSI @ 17.5K RPM is above 60% still at peak (tvs 1900)
7000 rpm x 6.78" ATI / 2.7 pulley = SC 17577.77 rpm
Local sees 14-15 psi on a TVS 3.15 pulley/LE5/2.5 LT/CD/ZZP 2.5 Catback
I don't see 500whp without some revs and a balanced bottom end and built head.
400whp shouldn't be a problem on good gas though
wonder how much that auto trans robs
Old Oct 3, 2014 | 09:00 AM
  #9291
Josh@ottp's Avatar
A stock lsj with a 1900 won't make 500, that's not what I am saying.
Old Oct 3, 2014 | 09:02 AM
  #9292
he says capable, on a LSJ. He didnt say stock LSJ
Old Oct 3, 2014 | 09:03 AM
  #9293
Josh@ottp's Avatar
I doubt the 4t45e will handle the full brunt of a 1900 for long either. I will rebuild it and see what it can take though.
Old Oct 3, 2014 | 03:38 PM
  #9294
26gen4's Avatar
Why in gods name would someone want a 4 speed
Old Oct 3, 2014 | 05:27 PM
  #9295
Josh@ottp's Avatar
I'm an auto guy. Mostly because I am lazy, but they are also faster.
Old Oct 10, 2014 | 09:30 AM
  #9296
Josh@ottp's Avatar
I have 4 TVS blowers that will be here next week. Two of them will be 1900 units.
Old Oct 10, 2014 | 09:33 AM
  #9297
100% METH's Avatar
So what's the deal with the bypass on these
similar to the magnuson? Internal? Wack the IM bypass and weld shut?
Old Oct 10, 2014 | 10:40 AM
  #9298
Tjolley's Avatar
Old Oct 10, 2014 | 02:42 PM
  #9299
I'd like to see some pics of these bad boys for comparison
Old Oct 11, 2014 | 03:25 PM
  #9300
ThexGovenor's Avatar
My TVS is off... sad day.
