Oil galley plug
Old Apr 1, 2011 | 11:01 PM
kxrida2000's Avatar
Originally Posted by 05Slowline
alright man i appreciate it, do you even have a wot box hahaha?
not hooked up haha i was feeling lucky and figured i could get away with it once(which obviously i was wrong cause it shot second gear through my case and wasted my clutch and flywheel too...i just got the wotbox delievered today btw
Old Apr 1, 2011 | 11:11 PM
05Slowline's Avatar
hahaha damn you got my luck haha
Old Apr 2, 2011 | 09:09 AM
05Slowline's Avatar
up
Old Apr 2, 2011 | 10:34 AM
05Slowline's Avatar
Old Apr 2, 2011 | 10:39 AM
kxrida2000's Avatar
Ill be at my garage in like 10 minutes and ill let u know
Old Apr 2, 2011 | 12:12 PM
05Slowline's Avatar
up
Old Apr 2, 2011 | 12:56 PM
insylem's Avatar
Hey let me know, I need to tap into that too!
My Shop manual says the threads are 12 x 1.75 (Metric)
I baught the ZZP Fitting that converts it to a -4 AN.
Also found 12 x 1.75 metric fittings that
convert it to 1/8" NPT Got some of those
on order too.
Old Apr 2, 2011 | 01:53 PM
kxrida2000's Avatar
Metric 6 is the size
Old Apr 2, 2011 | 02:11 PM
05Slowline's Avatar
you tried standards too? metric 6 feels like it fits but slides in the bolt hole and then ends up roundin it
Old Apr 2, 2011 | 05:34 PM
05Slowline's Avatar
ok well finally got it out
it was really easy once i decided to get the torch out. got under, and torched the bottom of the galley plug where the coolant crossover tube is i think, for a good min or so, took a torx-40 3/8 drive, ****** came out like butter.
so anyone who wants to take one of them bolts out, torch it first for a good mine, torx-40, there ya go.
Old Apr 2, 2011 | 05:49 PM
  #36
05Slowline's Avatar
you guys use any teflon tape on the feed fitting or should it be good just tightened down
Old Apr 2, 2011 | 05:56 PM
  #37
kxrida2000's Avatar
use teflon tape...mine must have been different though cause metric 6 fit tight cause no stardards fit for me
Old Apr 2, 2011 | 05:57 PM
  #38
05Slowline's Avatar
yeah who knows, obv a few different types can do the job, without heating up the plug with the torch they all sucked ***** for me though haha.
Old Apr 3, 2011 | 12:04 AM
  #39
insylem's Avatar
Ill have to get some teflon tape. Ill try this project this weekend, by weekend for me is wensday / thurdaay when my car will be on a lift for an Oil change.
Question: Wich galley plugs are easyer to get to, the exhuast side? or the intake side? Im guessing you have to get to them from below?
Old Apr 3, 2011 | 07:52 AM
  #40
05Slowline's Avatar
mine were all easy my blocks bare lmao
with the header on idk. i torched the bolt from below took it out from the top
Old Apr 3, 2011 | 10:23 AM
  #41
Tennpenn83's Avatar
Originally Posted by klloyd
It's probably that 40 that fit snug but you might have stretched it a little with that hex....I say that because I have done it before. Hell I almost did it on the coil pack cover because some ass bag super torqued them down and the hex I had at the time fit pretty good.
this is why i changed out those coil pack cover bolts to regular, old-fashioned 6-sided socket head bolts
Old Apr 3, 2011 | 10:33 AM
  #42
05Slowline's Avatar
tis why i am missing one of them hello drill bye bye ridiculously torqued down bolt.
Old Apr 3, 2011 | 11:43 AM
  #43
05Slowline's Avatar
seems like it won't go on snug to the point that you can't turn it anymore but it's seated I assume that's normal and trying to snug it is gonna cross threads?
Old Apr 3, 2011 | 12:31 PM
  #44
05Slowline's Avatar
and another dumb question my zzp mani came with 4 silver nuts, did you guys use those...i assume it goes bolt that screws into mani -> silver nut -> through tubro -> mani?
Old Apr 3, 2011 | 01:49 PM
  #45
05Slowline's Avatar
also did you guys use teflon tape on the oil feed fitting that goes in the turbo/how far did you thread it in. some places say use it others say don't so just looking for a second opinion before i do it lol. tia
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
