Only boost with boost bypass mod.. What do I need to replace?
Old Mar 1, 2009 | 11:12 PM
RedEcotecSS's Avatar
What exactly should I replace? I am confused between the bypass valve and the bypass solenoid.. Thanks for any help!!
My car will only go above 10psi with the boost bypass mod (blocking off the vac hose)..
Old Mar 1, 2009 | 11:19 PM
ls1fbody's Avatar
Haz l33t wheelz.
you probably shouldn't be blocking that hose, the system is that way for a reason. I though this was found out long ago?
Old Mar 1, 2009 | 11:23 PM
Yes, I know. But this is the only way to test and see if this is exactly what is causing boosting problems. Now I just need to know exactly which piece to replace.
Old Mar 2, 2009 | 03:42 AM
fzn14's Avatar
Tttuuuunnneeee
Old Mar 2, 2009 | 06:14 AM
ls1fbody's Avatar
Haz l33t wheelz.
oh, sorry i guess i misread the op.
have a buddy watch it when you rev, see if it tries to move. Pull it out and see if it's clogged or dirty. Even with it blocked, you still only get 10psi?
something isn't right. The actualtor is what mades it move, there may be something in the vacuum/boost lines. Try seafoaming it, see what happens.
Old Mar 2, 2009 | 11:02 AM
No, with it blocked (Bypass mod) I am seeing 17psi again. I think the solenoid is fucked.
Old Mar 2, 2009 | 11:17 AM
Dainslaif's Avatar
Sounds like a bad noid. Try swapping it with someone else's and see if it works.
Old Mar 2, 2009 | 11:18 AM
1badBlueberrySC's Avatar
Originally Posted by fzn14
Tttuuuunnneeee
It's not the tune newb.... It's my tune, ran it in my car for over a year! So go somewhere else!
JR, just go to the dealer and pick one up! It's the noid for sure!
Old Mar 2, 2009 | 11:54 AM
any ideas how much one will run me? callin the dealership here in a bit. definitely wont go get it today tho with this damn snow!!
Old Mar 2, 2009 | 11:58 AM
How much did you get Jr???
Old Mar 2, 2009 | 12:01 PM
we got about 5 inches of snow here.
Old Mar 2, 2009 | 12:05 PM
I'm searching for your solenoid!
hey man thanks a lot!!!
Old Mar 2, 2009 | 12:10 PM
No prob.... we only got 2-3" of snow here in Raleigh
and take off your stripes!
Old Mar 2, 2009 | 12:13 PM
haha i am seriously thinkin about it..
find anything?
Old Mar 2, 2009 | 12:14 PM
waiting for some replies ha ha ha
Old Mar 2, 2009 | 12:15 PM
ahh gotcha
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
justinchinn
Oct 2, 2015 12:18 PM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
