OTTP Long Tube Header
indid and the guy was like"i cant do that that in 3" it wont fit! thats 2.25" i cant fit 3" i there! cant u just get a pipe for me that i can put in there for u???" im like yeah, nm, thanks man
Um, you said you were gonna use your balt as a track car, maybe you'll take it to a couple meets and dyno days? I was assuming that you ment cause it was makin decent power, not cause you have a mass produced header
actually.... i do. i had two cobalts. a white ls and my laser blue ss. ss is totalled so i'm driving the ls till i go to basic then i'm buying another ss.
Last edited by EXsoccer1921; Apr 25, 2010 at 02:42 PM. Reason: Automerged Doublepost
hahn 3". unless you're above 3-4k while accelerating fairly hard. its actually pretty quiet. i never had any trouble with cops and on many occassions they were directly behind me
my cat even broke apart and blew out and i never noticed a change in sound
Last edited by EXsoccer1921; Apr 25, 2010 at 03:32 PM. Reason: Automerged Doublepost
no i said the header dumped behind the wheels will be only for the track and ottp's long tube for the street, but that maybe i'll put the dumped one on for dyno days and meets. not the car will be only for the track. hahah
I wanna go with a chambered design, lowest sound, while having max flow, if I lose 5 hp cause its chambered boo-hoo, btw that hahn fit shitty too, I had to pull the modular piece out so far that there has been a leak at that clamp since day one, once i put the long tube on im welding that bitch and saying bye bye leak finally.
