P0017 crankshaft code help??
Old Jan 16, 2013 | 07:05 PM
Stepchild21's Avatar
Hey just curious if anyone else has encountered this code and what they have done to resolve the issue. I just reassembled my engine and its been on since I got the car running. The car runs great idle doesn't fluctuate whatsoever. Although it takes 2-3 times of turning over to start.
Here's the code when scanned :
P0017 crankshaft position
Camshaft position correlation bank 1 sensor b
I'm fairly descent with tools, and I've been pouring over the threads the last two nights but can't find the answers.
Any help would be greatly appreciated !!
Old Jan 16, 2013 | 09:57 PM
silvercharged's Avatar
Gotta redo the timing its off by my guess 2 teeth. Been there done that.
Old Jan 16, 2013 | 09:59 PM
turbosmart4's Avatar
Clear the code first.. I cleared mine and hasn't come up in a while but yea might mean ur timing is off
Old Jan 16, 2013 | 11:55 PM
Ahhh crap that was kinda what I was guessing it would be. Will it harm the car if i keep it like this for a week or two? Just starting school and time is something I have very little of right now.
Old Jan 16, 2013 | 11:56 PM
Also I have cleared the code once. And it came back on as soon as I started the car again.
Old Jan 17, 2013 | 12:56 AM
mrbelvedere's Avatar
if you haven't messed with the timing check the cam positon sensor if could be bad but if it needs retimed here is the sensor retime procedure
GDS
Old Jan 17, 2013 | 09:13 AM
That's my problem. When I timed the engine I set the camshafta at 10 and 2 and the. Crankshaft at 5, but I did not set the notches on the cam position sensor. Idiot move by me.
Thank you so much !!! Ill have to do this this weekend
Old Jan 17, 2013 | 12:04 PM
your welcome
GDS
Old Jan 17, 2013 | 12:08 PM
Powell Race Parts's Avatar
Click mr belvedere to the rescue
Old Jan 24, 2013 | 09:53 PM
574's Avatar
574
Sub'd for later
Old May 6, 2013 | 09:22 AM
thejoey12's Avatar
I have the same issue with my car and when I try to line the can sensor up it won't go back in correctly.....I need help with this guys its my daily driver
Old May 6, 2013 | 09:39 AM
walrus's Avatar
Also make sure that cyl #4 is on top dead center.
Old May 6, 2013 | 09:46 AM
thejoey12's Avatar
How do I get it to go there
Old May 6, 2013 | 09:54 AM
Staged07SS's Avatar
Administrator
Administrator
By rotating the crank pulley.
Rotate manually until the timing mark on the pulley lines up with the timing mark on the front cover of the engine.
You will need a little mirror to see the timing mark on the pulley and front cover.
The position of your cam gears will look like the photo below when at TDC for Cyl #1 & #4.
Your cam position sensor/housing will look like the photo below when setup correctly.
Old May 6, 2013 | 10:51 AM
number 4 tdc compression stroke
Old May 6, 2013 | 11:02 PM
thejoey12's Avatar
you guys are awesome that check engine light is gone however now my car won't start and isn't throwing a single code.....nothing sounds out of the ordinary when i try to crank it it just won't turn over ......everyonce in awhile when cranking it will start to roll over then just stop and continue to crank
Old May 7, 2013 | 07:13 AM
Staged07SS's Avatar
Administrator
Administrator
The cam sensor is out of time....
Re-time as per me & Mrb's instructions, and you will be good to go.
Old Aug 6, 2013 | 01:51 AM
thejoey12's Avatar
The car wouldn't crank because of a bent valve
Old Aug 19, 2013 | 10:34 PM
francis89's Avatar
Does this get fixed at all mine is still at the shop but the guy told me it aint my timing chain cos my sensor is not getting enough resistance idk it could be the harness?
ballin on the budget!!
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
