P0171 Lean code
Old Jan 17, 2009 | 10:48 AM
  #51
flash13brandon's Avatar
Originally Posted by wtpcobaltss
ok ive thrown this code before when i hooked up my tech 2 in shop.... we also have the whole ob2 online thing for gm and crap but anyways it told me all the reasons why it could be throwing this code i dont remember some of them but my problem was because i put some lucas fuel additve in my gas and caused it and i quote ( to much alchol)
True, but I haven't added anything to my gas. I've tried different gas stations and same issue.
Old Jan 19, 2009 | 02:42 PM
  #52
Update: Did a compression test and all the cylinders were 220 or 221. I'm still throwing the P2261,P0171, and P0300 codes.
Old Jan 19, 2009 | 09:17 PM
  #53
silverbullet08's Avatar
i had the exact codes and problem you bearly hear a mis at idle and it goes away as you rev.
mine was on cylinder 2 the injector oring went bad.. the injector actually wabbled around in the hole so i replaced the oring and put a litle white grease on all of them before i reinstalled the injectors. took about 45mins to fix. not a beig deal. all the codes went away after i fixed that. i didnt think to look there cause there was no oil or gas leaking but i think it just disapated after leaving the cylinder or something. try it i bet it works.
Old Jan 19, 2009 | 09:19 PM
  #54
Awesome bro. Cause I was spraying brake cleaner to see if it would leak into anything indicating a leak and it acted like it got into injector 2...could you visually see something wrong with the oring and where did you get a new one at?
Old Jan 19, 2009 | 10:36 PM
  #55
Corvettespirit's Avatar
GRABBER BLUE MUSTANG GT
engine is ****
Old Jan 19, 2009 | 10:39 PM
  #56
Has anyone ever told you if you don't have anything nice to say, then don't say anything at all.
Old Jan 19, 2009 | 10:42 PM
  #57
all you need is a good tech to find what wrong with your car i am
Old Jan 19, 2009 | 10:54 PM
  #58
Well when are you able to help me out? lol
Old Jan 19, 2009 | 10:59 PM
  #59
PMED
turbochargedss2012
Sep 20, 2023 12:17 PM
tomj77
Oct 4, 2015 11:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
