p0304 misfire code
Old Dec 19, 2010 | 08:14 PM
Black05's Avatar
p0304 misfire code
Looks like my cylinder 4 is taking a dump on me. Got brand new spark plugs, and it ran ok for about 10 seconds, then immediately went back to misfiring.
I'm looking towards a faulty injector being the cause, but what other diagnostics should I be running?
Old Dec 19, 2010 | 08:23 PM
ULWizSS's Avatar
Just saw a issue where a tune was not fueling fuel trims and was causing a missfire. But yeah start with your basic and rule things out.
Old Dec 19, 2010 | 09:54 PM
Black05's Avatar
I've been on this tune for a while now, so I can rule that out.
Pulled the rail and I found:
That 0-ring is in perfect condition, but that's a lot of buildup around it.......
Anyways, is it possible Coil packs could be an issue here? There is no smoke coming out of the tailpipe (from what I can tell).
Old Dec 19, 2010 | 10:35 PM
SCcobaltSS's Avatar
Swap the coil pack from #4 to another one, if the misfires follow it you found your problem.
Old Dec 25, 2010 | 05:05 AM
Black05's Avatar
Waiting 10-25 miles before checking that code again, to see if the misfire went from 4 to 2.
Anyone know if a Leaking/blown head gasket could be the cause? I could have sworn I smelled coolant on rare occasion. I'm paying close attention to the coolant levels to see if it goes down, but I haven't driven it enough to check.
Old Dec 25, 2010 | 10:33 AM
mrbelvedere's Avatar
do a compression check
Old Dec 25, 2010 | 08:05 PM
Black05's Avatar
That was my next step. Cyl #4 picked an absolutely horrible time to go out
Old Dec 25, 2010 | 08:36 PM
these engines arent hard to rebuild and the **** around the injector is typical
Old Dec 25, 2010 | 08:43 PM
Black05's Avatar
I meant that it went out right around the holidays. Busy, low on funds, and everywhere is closed on Christmas Eve/Christmas.
Old Dec 26, 2010 | 09:59 AM
i feel you on that dude
Old Dec 29, 2010 | 03:44 AM
Black05's Avatar
Compression Test Results
Cylinder 4: 55 PSI
The good thing is that i'm not losing any oil, so that rules out Rings (pretty much, anyways). Unfortunately, i'm not losing coolant either (pretty much removing a head gasket possibility). So the likely cause is a faulty Exhaust Valve.
Either way, it's not going to be cheap
Old Dec 29, 2010 | 09:08 AM
yes the rings are gone and probably a piston ring land that is why the cylnder pressure is so low
Old Dec 29, 2010 | 04:58 PM
Black05's Avatar
My friend was talking about how he blew the lands out of his pistons, and it had similar symptoms. Is it possible that I wouldn't lose oil, even with blown rings?
Old Dec 29, 2010 | 05:26 PM
yup i had 3 comp rings broken and a ringland and dident lose oil
Old Dec 30, 2010 | 01:19 AM
Black05's Avatar
But, what if I want it to not be rings?
Please?
If it is a piston ringland/ring, that means heads pulled, re-sleeved, new rings, and likely new piston/rod.
If it's an exhaust valve, it's much, much cheaper. Still have to pull the heads, but i've been meaning to anyways.
ARP head studs, cometic head gasket, possibly a new 4th cylinder replacement(or Exhaust Valve).
Yay! ****!
Old Dec 30, 2010 | 08:34 AM
i doubt the bore is hurt you wouldent need a new rod just a piston and a rod bearing and rings foe that cylnder and its not a bad valve
Old Jan 14, 2011 | 10:18 PM
Black05's Avatar
Turned out to be a chipped exhaust valve, possibly a cracked head.
Just replacing the head gasket/ARP studs and labor was 1300, so it'd be close to $2,000.00 if the Heads are cracked.
Magnaflux will reveal all on Monday.
Old Jan 21, 2011 | 11:53 PM
Black05's Avatar
Cracked head replaced, New valve/guide/spring, cometic head gasket, ARP head studs, and labor cost me right around $2,000.00
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
717ssbalt
Oct 2, 2015 04:01 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
