p2228 code
Old Jan 31, 2011 | 06:45 PM
selfinfliction's Avatar
Originally Posted by myfakeevo
cool kid. you use a search button and came across everyones generic problem. Why dont you continue to take your car the shop while the rest of us that actually work on our cars have a conversation.
dude i've had 2 cobalt ss', this one i bought with 11 miles on it the first month they were released by gm in 2005. I've been through 4 motors, 3 transmissions, 3 different types of blowers, 2 turbo kits and a partridge on a pear tree... and you know what all of this means?
it means i'm smart enough to use the ******* search button and research issues myself before making threads asking for help and then telling them they have no idea what the problem is.
now go clean your air filter, plug up your sensor or tighten the bolts.
Old Feb 1, 2011 | 12:22 AM
myfakeevo's Avatar
all i got out of that is, that you break **** and cant shift.
and i have a 600hp chevy sedan 210. Whos got the bigger **** now...no body cause your an idiot.
Old Feb 1, 2011 | 03:34 PM
mrbelvedere's Avatar
clean ur sensors
Old May 4, 2011 | 03:03 PM
CobaltArmyDude's Avatar
great info guys! just had P0068 and P2228 pop with the reduced engine power. cleaned all my sensors, disconnected the battery for a while..put everything back together and its all gone
Old May 4, 2011 | 08:43 PM
myfakeevo's Avatar
their info didnt help, my problem was one of the connections to the pcm wasnt fully on. i tested the wire to the sensor and got zero volatage. fully connected the bottom connector better and got rid of the code.
Old Oct 15, 2012 | 10:06 PM
turbosmart4's Avatar
Well I have this code now.......
Old Jan 9, 2022 | 12:20 PM
jared t's Avatar
Same here
yeah i got that before too, ended up being the air filter was damp (had an aem dry flow).
before going too far into the troubleshooting steps, just clean your air filter, or replace it if you don't have a reusable
i had the same code replaced all 3 map sensors two were clogged but I still had the code checked the filter and it was almost completely blocked
Old Jan 20, 2023 | 10:34 AM
annamartino's Avatar
yellow dragon
Jun 2, 2020 07:13 AM
jonxxxedge1
Dec 13, 2009 10:34 AM
*boostinss*
May 27, 2009 02:00 AM
boostnss
Sep 29, 2007 10:36 PM
1gmfanatik
Feb 9, 2007 11:44 AM
