Performance mods ?
Old May 26, 2014 | 01:16 PM
Mike098's Avatar
Performance mods ?
2006 cobalt ss/sc : current mods are srs catback exhaust and k&n typhoon intake
suggestions on injectors and lowering kit and also stage 2 clutch kit??
Old May 26, 2014 | 01:17 PM
search the forums. These topics have been covered multiple times.
Old May 26, 2014 | 01:22 PM
owlwyn's Avatar
You don't need injectors till you down size your pulley, and you can either buy some coil overs or lowering spring but that depends on your budget and how low you wanna go. And clutch wise, I'd say your stock should be fine unless it's already slipping, or you plan on buying a stage kit for it anytime soon, then I would personally recommend the GM upgraded clutch (zzp sells it pretty cheap) since it'll hold all the power you want unless you want to turbo swap or put a tvs on it.
And if you want to know more the search button is fairly useful once you figure out to use it properly. lol.
Old May 26, 2014 | 01:28 PM
googling with site:cobaltss.net is way better than the search function here, hell the stickys in this section cover most of those questions
Old May 26, 2014 | 01:34 PM
owlwyn's Avatar
Google is way easier, and the top results are almost always from here. And there's a sticky for a guide to how to mod these that is Very Very useful. Use that stick OP.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
HEATON
Oct 16, 2015 07:21 PM
Oct 13, 2015 09:32 PM
Tupp
Sep 30, 2015 08:18 PM
