Plug Gap for LSJ turbo
Old Apr 15, 2010 | 02:33 PM
DVSk8er's Avatar
like it says i need opinons on plug gap for a lsj turbo swap. car is running about 22psi and also has meth. the plugs are autolite 3922.
Old Apr 15, 2010 | 11:50 PM
Matt M's Avatar
Id start at .035".
Old Apr 15, 2010 | 11:54 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
What turbo?
And I agree with Matt. I think I set mine to .032". I'm pushing 20psi out of a PTE SCM5031E. No spark problems here.
Old Apr 16, 2010 | 04:24 AM
Maxim_X's Avatar
.28 without issues.
Old Apr 16, 2010 | 08:15 AM
DVSk8er's Avatar
its a 50 trim precision. I have tried .35 and .30 and i still have the same breaking up issue around 5500. I'm starting to think plug gap isnt my problem. today on a second gear pull it threw 2 codes which are p0103- maf circuit high and p0231- fuel pump low circuit. But when the car was on the dyno two days ago it was breaking us same as now but no codes. my afr was right around 11.5 through the pull and zero knock. so any ideas you guys have let me know. i'm open to anything. i think the maf high might be related to my meth nozzle location. i have it just before the throttle body then if looking at the car my maf is about 5 inches to the right.
Old Apr 16, 2010 | 08:35 AM
rico's Avatar
dump the autolites get ngks one step colder
Old Apr 16, 2010 | 08:39 AM
DVSk8er's Avatar
yea there hard to come by around here. what would be causing the two codes
Old Apr 16, 2010 | 08:42 AM
rico's Avatar
ottp and zzp sells them lol i always get mines online. matter fact i beleive i think i have brand new sets at home from when i got my kit
um one is a maf sensor maybe maf settings/tune? maybe needs to be cleaned? or like u said maybe because or where ur meth nozzle is?
Old Apr 16, 2010 | 09:01 AM
DVSk8er's Avatar
well found some ngk bkr7e's so gonna pick them up and try a plug gap .35
Old Apr 16, 2010 | 09:06 AM
rico's Avatar
i think i have mines at .32
Old Apr 16, 2010 | 09:26 AM
DVSk8er's Avatar
alright gonna try that at lunch time. i hope thats what my problem is. this car is starting to **** me off. soon i'll be making my third trip to the tuner
rico's Avatar
i feel u its always something trust me i know
Old Apr 16, 2010 | 09:28 AM
Matt M's Avatar
If you are having misfire issues, don't be afraid to close the gap some. Try .028"
The MAF issue could be from Meth spraying or dripping on the MAF, but that usually results in an over-rich condition as the MAF reading spikes very high when water or meth touches the sensor.
Old Apr 16, 2010 | 09:30 AM
rico's Avatar
^ try that he would know better than me
Old Apr 16, 2010 | 09:36 AM
DVSk8er's Avatar
yea its weird car ran better with worn out autolite 3922 gapped probably close to .38 or .40 then it does now. maybe i should start around .38 and see how it goes
ok so i need to move the maf tube farther away then. i'll have to give that a try. any advice on the fuel pump code matt
Old Apr 16, 2010 | 10:41 AM
Matt M's Avatar
I don't know about the fuel pump code. I've never had that one come up before.
Old Apr 16, 2010 | 10:44 AM
DVSk8er's Avatar
great no one knows why its coming up. if something was unhooked or loose it would come up all the time correct not just intermittenly
Old Apr 16, 2010 | 03:50 PM
Are you leaving the washer on the Spark Plug threads, or taking it off?
I'm not sure why you would still be having problems. I'm on a Precision 50trim as well, .032 worked fine for me. How much timing are you running? How much boost is it hitting?
Do you still have a Cat? What size exhaust piping are you running post-turbo?
Old Apr 16, 2010 | 04:09 PM
DVSk8er's Avatar
yep leaving the washer on the plugs. just put in one step colder ngk. going to try a .28 plug gap and see what happens. as for timing i'm not completly sure i didnt do the tunning. tune time performance did it. as for boost right now its set around 20 till i figure this out. and i have a 3in downpipe no cat then still a 2.5in cat back. yea i know the cat back sucks but i doubt its the reason
Old Apr 16, 2010 | 06:03 PM
Maxim_X's Avatar
I had really strange issues like spark blowout for almost a year in high boost when I ran a small exhaust. I ended up changing the entire setup except for the exhaust trying to figure it out.
Is your gate rerouted or open dump?
Old Apr 17, 2010 | 04:55 PM
DVSk8er's Avatar
its dumped to atmosphere. plugs are ngk's gapped at .28. it seems to be a little better. i definately think it might be cause my meth nozzle is to close to my maf
Old Apr 17, 2010 | 10:10 PM
Rodimus_Prime's Avatar
should the washer not be left on the plugs?
Old Apr 18, 2010 | 02:49 AM
hungryhip-ccp's Avatar
i have to run .28 or it breaks up a little, im on 3" crush bent exh. also if its way rich like 10.8's - 11.2's then it does it. if i keep it .28 and run 11.7-12.0 it pretty much never breaks up all the way to 8k.
the last time mine did it at the top of third is when i blew my sleeve, so be careful.
Old Apr 19, 2010 | 08:12 AM
DVSk8er's Avatar
yea i'm being careful. i think i figured out that my meth nozzle was way to close to the maf. i dont know why i thought it was a good idea to put it there. every time the meth was spraying it was soaking the maf. turned off the meth for now and it pulls great till either i get wheel spin or clutch slip
DarrenGC
Dec 24, 2021 01:55 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Sep 27, 2015 08:53 PM
