polyurthane or zzp?
Old Dec 30, 2010 | 01:00 AM
DEZZIE41's Avatar
Arrow polyurthane or zzp?
which is better polyutrathane inserts or zzp billaet engine mout and rotated front and rear tranny moutns
Old Dec 30, 2010 | 01:13 AM
i have the ttr upper motor mount, and ttr poly trans inserts and have ZERO wheel hop. why spend more when you can get the same result for less? not saying anyone elses products are bad because they do the job too but ive had mine for four years now and could launch it at redline all day every day with no wheel hop
Old Dec 30, 2010 | 01:14 AM
DEZZIE41's Avatar
whos ttr and what did they cost?
nvm lol turbo tech racinh
Old Dec 30, 2010 | 01:15 AM
lol you got it
Old Dec 30, 2010 | 09:31 AM
TurboTechRacing's Avatar
Thanks for the referal!
Here is a photo of the product:
Here is a direct link:
Turbo Tech Racing Solid Upper Engine Mount Chevy Cobalt/Redline/HHR 2.0/2.2/2.4L Manual Trans - Turbo Tech Racing, LLC
Old Dec 30, 2010 | 10:22 AM
Red05SS/SC's Avatar
I have the same combo and it works great.
Old Dec 30, 2010 | 08:42 PM
Joemaster70's Avatar
how hard was it to apply the inserts?
Old Dec 30, 2010 | 09:41 PM
As long as you have a bench vise or a press (or a freind has one of the two) it is very simple. Press out the old, and press in the new.
Old Dec 30, 2010 | 10:00 PM
ULWizSS's Avatar
I just recently installed my front and rear trans mounts from ZZP. It took about 35 minutes a piece.
Was starting to get a little wheelhop at at track on the stock mounts so i got a black friday sale for 160 shipped from zzp.
Amazing difference on the street though with minimal vibration.
Gonna slap some drag radials or slicks on it next season and get into the 12's
Old Dec 30, 2010 | 10:03 PM
chris88z24's Avatar
oem+driver mod unless you track the car more than you daily drive it.
Old Dec 30, 2010 | 10:25 PM
I stabbed mine out with a screw driver, and played my insert over the mount and stepped on it. Went in no problem
Old Dec 30, 2010 | 11:15 PM
now being that inserts are not aftermarket mounts, will this work the same with a aftermarket downpipe so the flex won't break, or do i need a TTR or ZZP tranny mount or Engine mount
Old Dec 30, 2010 | 11:23 PM
red06SC's Avatar
neither
they both contain polyurethane
get a td or rotated mounts
Old Dec 30, 2010 | 11:30 PM
Omnigear's Avatar
^this
Old Dec 30, 2010 | 11:39 PM
SprChrg4Life's Avatar
i played with all the options... tried the torque dampener, that thing was whack... didn't work 70% of the time depending on the road surface, and it looked kinda doofy in the engine compartment too. then got the upper mount from ttr, it got the job done 90% but i still had some hop so i then made my own tranny inserts. got some poly, baked my mounts, slapped em in, WOAH. no wheel hop, but too much vibes...
took the tranny mounts i made out, threw in the poly inserts from ttr (at this point i have ttr upper, nd ttr tranny mounts if u got lost lol) THEN i even went as far to take my tranny mount that is under the fuse box out, filled that with quiksteel and replacec. i had no wheel hop! vibes were terrible, but no wheel hop... after a year i was miserable and couldn't take my car being a rattling shitbox. i even bought a torque wrench to tighten down everything perfectly and in the right order, JUST so I'd know I did the install perfectly and that it was my setup. next...
i now have stock upper mount, and rotated stg 2 mounts from OTTP. next to no vibes, and no wheel hop 95% of the time, regardless of road surface. I can combo this setup with the solid mount i still have, but i haven't because i like having next to no vibes or rattles. the vibes r fine but man do the rattles SUCK!
try the poly trans inserts, they're only what $50 + shipping? if they get the job done and the rattles/vibes r in check, ur done. if not then go for the rotated mounts they are a dream.
srt-10's Avatar
Dezzie ill help you out on this one. Do you plan on tracking your car? If not, just buy the ingalls TD. If you are planning on tracking the car, get the TD with stage 2 transmission mounts. You will get some vibs but its the best way to go.
Old Dec 30, 2010 | 11:45 PM
Td sucks. Get the ttr mount
Old Dec 30, 2010 | 11:59 PM
Ottp selling their inserts for 30$ each which seems like a steal, but so how do i get these mounts out jack my car up and keep the car on jacks and engine on a jackstand?
Prothane Manual Transmission Mounts - Over The Top Performance
Old Dec 31, 2010 | 12:06 AM
DEZZIE41's Avatar
no track wiht this car just street
Old Dec 31, 2010 | 01:59 AM
srt-10's Avatar
doesnt suck on the street, just the track. I bought it used from my friend, never had to dial it in and never got wheel once with it on while on the streets.
Old Dec 31, 2010 | 10:34 AM
chris88z24's Avatar
You just gotta know how to pre-load the mounts, lol.
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Sep 27, 2015 08:53 PM
