Port and Polish question..?
Old Jul 17, 2009 | 08:46 AM
Brian MP5T's Avatar
Originally Posted by drew1991sf
i lost about .5-1psi when porting mine but it made it more effiecent
Loosing 1 Psi is an EPIC LOSS no matter how much more efficient you think it is..
Old Jul 17, 2009 | 09:21 AM
383_Stroker's Avatar
I've still not been swayed to the otherside of the discussion btw.. I need this explained to me, if I'm wrong..
I still think that if you port the blower and allow it to flow more air (which is what porting does.. and what it means when you throw the efficiency word around) that it HAS to make more boost, not less if you change nothing else.
The supercharger is what supplies the air (while under boost), the engine is what creates the restriction on the airflow... So, if you make the SC supply more air.. without changing the engine (the restriction).. the pressure will raise because you are supplying more air and not letting it exit any faster..
I think i've said the same thing 10 times in this thread now..lol
Old Jul 17, 2009 | 03:51 PM
drew1991sf's Avatar
....not really. it ran alot better and seemed a bit faster.
ya but the car needs less pressure to create the same amount of work
Last edited by drew1991sf; Jul 17, 2009 at 03:51 PM. Reason: Automerged Doublepost
Old Jul 17, 2009 | 04:56 PM
Zach06CobaltSC's Avatar
Originally Posted by Stiner
He asked about the supercharger and the throttle body. Ofcourse more boost doesn't equal power but you do no where boost is measured from right? You do realize that if you ported the SC and made no other changes and lost boost your car would be slightly slower?
Ported the SC can be a DYI, porting the head for most people isn't going to be free.
Are you sure you can tune these cars?
I am positive I can tune these cars bud. I know hes asking about the s/c and throttle body but if the OP is going to have any work done he might as well have work done that is going to benefit him. The most restrictive part on the lsj engine is the head, if he pays to get it ported or has the knowledge to do it himself he will see MASSIVE gains, unlike porting the s/c or tb.
Also I highly recommend NOT porting the s/c and throttle body if you don't know what your doing and you haven't ported things before.
Old Jul 17, 2009 | 06:31 PM
WickedSS2005's Avatar
I don't recommend porting a head yourself..... ever. Unless you've done it many times before. It's not as simple as shaving some metal unless you are ONLY porting the exhaust port openings
Old Jul 17, 2009 | 07:04 PM
+1, never touch a head yourself unless you have plenty of experience in porting. I still highly recommend the op skips the petty tb and s/c stuff though and ports the head. For 450 bucks you can get a ported head that flows around 300 cfm. I will have mine here in a couple days and will put up some pics. I will also have dyno results soon too.
Old Jul 17, 2009 | 09:16 PM
Your head vs. my ported head.
And, porting the s/c is fine to do. It's not a HUGE performance mod, but every little bit does help and lower IATs (5-10*) and slight improvement in efficiency is always a plus. Will only help.
Old Jul 17, 2009 | 09:21 PM
Who did your porting tom and what did it cost?
Old Jul 17, 2009 | 09:40 PM
Euthanasia. And let's leave it at sponsorship status. No, it wasn't free. But he has done a WONDERFUL job on my supercharger. I have a vid of the head... give me a second
Who did your's?
Last edited by WickedSS2005; Jul 17, 2009 at 09:40 PM. Reason: Automerged Doublepost
Old Jul 18, 2009 | 05:17 AM
Euthanasia also did my head. Notice how the video before that has my name on it.
http://s164.photobucket.com/albums/u...lsjexhZach.flv
http://s164.photobucket.com/albums/u...IntZach002.flv
This guy truely does amazing work. I will have the head back in just a couple days, fully assembled with 78lb valve springs too =D.
Old Jul 18, 2009 | 11:10 AM
  #36
red06SC's Avatar
lol at misunderstanding of PSI...straight up ricer logic...
PSI is a measure of RESISTANCE!
Originally Posted by JAYNO20
what kind of differences do you notice?
higher (would-be) trap speed, likely due to lower IAT2s
no loss in manifold pressure
if you plan on doing it be VERY, VERY careful
better to take off not enough, than too much..
Old Jul 18, 2009 | 11:24 AM
  #37
lsjwannabe's Avatar
The reason some people lose boost and the reason some gain is where the time is spent porting. The thing is the m62 is a pretty decent off the shelf blower in terms of how it does its job. If your loosing boost you probably spent more time on the outlet (less pressure) and vice versa.
Old Jul 18, 2009 | 12:31 PM
  #38
drew1991sf's Avatar
zach are u gettin ur intake mani ported too?
Old Jul 18, 2009 | 03:06 PM
  #39
No, I don't really see any point of porting the intake manifold until I go tvs.
Old Jul 19, 2009 | 02:04 AM
  #40
GTPUSER's Avatar
Meeeehhh... the blower is not a restriction on the system, it is the reason boost is made in the first place.. if you have less boost and all you changed was the blower, you're not putting as much air in.. and not making more power..
Unless i'm retarded.. then.. ignore me..
After thought: If boost was measured on top of the blower, pressure would lower, yes.. but boost is measured after the blower, in the intake
Or if this was a charger (such as a twin screw) that built pressure in the blower, PERHAPS it would lower boost to port the outlet.. but.. a roots type doesn't build pressure in the blower itself
If you are grinding down and getting rid of material there is going to more volume that the blower is pressurizing, so the pressure isn't going to be the same, just a tad less.
Old Jul 19, 2009 | 02:18 AM
  #41
drew1991sf's Avatar
o i gotcha
Old Jul 20, 2009 | 11:14 AM
  #42
Brian MP5T's Avatar
You really don't understand how this works do you..
Because the Pressure is taken AFTER the SC, then a loss of pressure does not mean a reduction in resistance... Idiot.
It means less volume of air is entering the engine, which means less fuel can be burnt.
Old Jul 20, 2009 | 11:36 AM
  #43
red06SC's Avatar
Yeah, I was a little...out of it....and realized this later, but I decided not to edit.
Old Jul 20, 2009 | 11:39 AM
  #44
At least someone shares my logic on this..
Old Jul 20, 2009 | 12:01 PM
  #45
Brian MP5T's Avatar
"Ricer Logic" You really should check the link in my signature.
BTW: This is the first time I have ever been flamed incorrectly and a person actually fessed up to being wrong.
Kudos to you sir. Sorry for calling you an Idiot.
If you move the casing further away from the screws by polishing it, there will be more room for the air to leak back in the wrong direction and the screws will have to move faster to create the same pressure.
Similar to paddling up stream with a smaller paddle.
Last edited by Brian MP5T; Jul 20, 2009 at 12:01 PM. Reason: Automerged Doublepost
Old Jul 20, 2009 | 12:05 PM
  #46
red06SC's Avatar
Yeah, I was highly intoxicated and ranting atm...everyone got trolled in every post I made...
There is a sweet spot for opening up the outlet, I believe Eaton has suggested somewhere around 1/8", I personally did 5/32" and noticed no pressure loss. Most people take off way too much material.
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
