The quest for 600whp
I have the OTTP braided clutch line. You will love it. Pics of it installed if you click 2009 SS in my sig.
The line goes from the master to the bleeder block though. It won't help with the Clutch pipe issue. It will fit the f23 or f35 bleeder. I bet it fits the f40 too.
I definitely recommend deleting the bleeder. That way ya kknow...... well.... i think that's obvious. I deleted the bleeders on my brakes.
Disclaimer: This is sarcasm. I did not delete the bleeder screws on my brakes
because bleeders are so prone to leaking......................
it's not even close to being worth it when you compare the hassle of having to deal with it. You should delete yours then..
No, you won't, because it's a dumb idea & YOU know it
You're just here to stir the pot.
did i say that bleeders were prone to leak no i ******* dident bleeders are not considsidered a leak point a where the lines connect are leak points because the connect points are weak points in the system and how do you know whats worth dealing with and what is not your the bucket of dicks running your mouth stirring the pot spouting all this wisdom due to your lack of automotive experiance and yes it could work out quite well
