The quest for 600whp
How are these injectors working so far? I was going to go with them but didn't want to cut myself short on the fuel setup that's why I went with the 160lbs. Also on I side note I took your advise and got a bigger turbo lol
Haven't pushed them yet. I really need to get re tuned for more boost. I'd imagine I'll run out around 20psi or a little better. Eventually I'll get bigger ones. That's great to hear man!
Oh I thought you had the 1200's. Is your turbo BB? I have had a lot of friends with BB Precisions that have smoked like crazy until they found the right restrictor/drain line combo.
it probably isn't the turbine side of the turbo. oil that goes thru combustion is blue, oil that is just burned it grey. it's either rings or the compressor is throwing a good amount of oil, should be easy to find out. may as well do a comp/leak down too
pull the snail if the manifold has burnt oil in it then you know where to go from there
23psi, with my eth hooked up Temps now drop during a pull. Having some issues though, may make a thread later with details
Arm's engine test results showed leak down around 2% and compression was 205-230
it is a problem but how much of a problem is the question you need to do a hard pull and key it off at your shift point coast to a stop and pull the plugs all of them to see if your getting an even burn on all cylinders
