Question For Cammed Balts
Old May 9, 2008 | 09:54 AM
EdCobaltSS's Avatar
i have 272 cams, and 10:1 compression pistons, and a 2.85" pulley among other things. we finished the install on my cams, and i changed the plugs, the car pulled great right up to 8000 rpm's, but when i changed the plugs last night, now the car sputters really bad up above 7000.
If there is anyone with the same generic setup, i need some information on plugs, 1 or 2 stages colder, and what gap?????
Old May 9, 2008 | 10:07 AM
Omega_5's Avatar
If you don't get an answer form anyone, you may have to do the trial an error thing.
Get a set of each (1 step and 2 step colder plugs),
Start with one set; gap it, try it... pull the plugs, re-gap, re-try... and keep going with that set until you think you've found the sweet spot as far as the gap.
Try with the other set, and repeat the whole process.
Every car is different, so it's best to find it out for yourself.
Old May 9, 2008 | 10:17 AM
EdCobaltSS's Avatar
yeah, i know this, but i was trying to find something close as a type of "quick-fix" because i have a lot of driving to do this weekend, and dont really have time for trial and error.
thanks though
Old May 9, 2008 | 10:22 AM
06black's Avatar
raise pulley size for a definite fix.
sounds like spark blow out, either play with your dwell timeing(best fix) and/or check the gap on the new plugs Vs the old plug.
same EXACT plug as you used before? did you cut the electrode down to prevent dripping?
Old May 9, 2008 | 10:43 AM
EdCobaltSS's Avatar
no, different plugs, the ones i had before were gapped different and were 2 stages colder, now are 1 stage colder.,
and that whole pulley size, nah, i aint gonna be changin it anytime soon, car pulls like a raped ape when it runs right
Old May 9, 2008 | 10:50 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Just put the old plugs back in. Spark Plugs are good for a REALLY long time.
Otherwise, go to AutoZone and buy a Spark Plug gap checker, and then gap them to .35.
If problem continues, go to .32... at this point I would think you are having knock problems and I'd put the old plugs back in.
Old May 9, 2008 | 11:03 AM
06black's Avatar
i'll try to help you here, fallow along.
you put different plugs in, hotter ones at that, and now you wonder why the car feels like dog ****?
your cylinder temps are going ape **** with the hotter plugs, get a set of two step colder plugs(like you had before) cut the electrode tips down a bit and re gap to 30-32
the reason i suggest pulley size change is simple, when you lower your boost number, your temps (in the cylinder) drop, thus eliminating your spark blow out issue.
as you said, you have some driving to do this weekend, if you cant find a set of your old plugs (2 step colder)then raising pulley size will eliminate this problem of yours so you can drive where ever you wish, safely.
Old May 9, 2008 | 11:05 AM
No ****... why DID you put hotter plugs in?
Old May 9, 2008 | 11:08 AM
Area47's Avatar
Rent me! per hour
circle gets the square. also. if you do mess with dwell timing. be nice with it.
mine are gapped to .035. also running near stock dwell timing.
Old May 9, 2008 | 11:26 AM
EdCobaltSS's Avatar
i had a different issue with the car and the MAF, but ive since fixed that, and while i was trying to fix it, i put the 1 stage colder plugs in it, i guess i thought that may have been contributing, but i will put the 2 stage colder plugs back in, and i just checked the gap on the old plugs, and 2 were at .033, and 2 were at .040
Old May 9, 2008 | 04:14 PM
myoshizawa819's Avatar
thanks though
....so keep it below 7 grand
Old May 9, 2008 | 04:17 PM
EdCobaltSS's Avatar
yeah, um no... lol
Old May 9, 2008 | 04:56 PM
Blown 4-banger's Avatar
Yeah, be careful with the dwell timing. I had really bad spark blow out every time at exactly 6600 rpm, a small change to the spark dwell table fixed that problem right quick
Old May 9, 2008 | 05:43 PM
EdCobaltSS's Avatar
Thanks
06MetallicBalt
Jul 20, 2025 08:47 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
roth
Sep 26, 2015 12:16 PM
